gravity waves found
  • jetijs!!!
    good news!....matt should be getting the device in the mail very soon!....you are next after that......david
    • Originally posted by david lambright View Post
      i believe Ed heated those segments past their Curie point before he assembled his wheel so that the iron was "fresh", with no permanent magnetism....scotty [loadstone?] shows that a PMH can be locked with a single long wire that goes through the center of the PHM...
      I tried something a little "out there." A few years ago I found a hematite ring while on a SCUBA dive. Monday I decided to wrap the ring with copper wire and follow the same process for creating a PMH (via car battery). Note: there is no break in the ring, just a continuous circle. I charged the ring a few times. I assumed the ring would interact with my other PMH in some way. But it doesn't appear to.
      However, I can tell you that after charging the ring I have a strange sensation in my left hand when I wear it. I cannot detect any electric or magnetic behavior in the ring, but I can tell it is doing something on my hand. I urge you to try this and see if you have a similar experience. Get a cheap hematite ring from a jewelry store or over the internet and charge it up (then wear it for a few days).
      Can anyone suggest simple tests that I can perform to check the ring for some type of charge or radiating energy (other than magnetism)? Should I be worried about wearing it now? The closest thing I have to a voltmeter is a cheap current tester for checking battery cables on my car.
      -Van
      • One of the interesting things about Hematite and Iron Oxide in general is that it is a paramagnetic material.
        The differences between this material and the 'soft iron' used in many of Ed's experiments are many, but the two primary things to note are:
        Paramagnetism:
        1. Internal magnetism is linear
        2. Internal magnetism is lost when the external field is removed.
        Ferromagnetism:
        1. Internal magnetism is recursive, very non-linear
        2. Internal magnetism persists after external field is removed.
        The linear aspect of paramagnetic materials is rather important, because it stipulates that you can never get an internal field greater than the external field, they are typically 1:1.
        With ferromagnetic soft iron, this isn't the case. The resultant field can actually be stronger than the H field used to create it, however the curve does flatten out at the saturation point after the H field is removed. But while it is in place, the combined field can be stronger.
        This means that conventional magnetic flux will not remain in the toroid ring of hematite after the external field is removed. Theoretically, all of the energy used to align the domains in the paramagnetic material, is returned to the source when the field is allowed to collapse, less that energy converted to heat (or other EM radiation). This is the principle of ferrite core transformers.
        However, let us imagine that some of that charge energy is not converted to heat, and is not dissipated. Consider the possibility that these little domains that have been physically repositioned, end up resonating back and forth after they are let loose. Imagine, that instead of getting warm, the ring gets cool and these domains all start interacting with each other in a supportive way while using external thermal energy to keep the process going. Now imagine, that once setup in this resonant manner, the "output" is some higher energy emission, say in the THz range - small bursts of energy when ever the domains reach some maximum threshold. Then, if this worked, the only way to stop it would be to chill it, take away the energy that keeps it going. Thus charging it while it is hot, or striking it to make it ring at a specific frequency while it is hot, may cause it to go into this perpetual process of converting external thermal energy to some other form of EM energy.
        I'm not saying that this is what's happening with the rings being experimented with - but I am saying that it could be a scientific explanation if all the conditions were right. Understanding how a single atom transfers thermal energy to its neighbors is important to comprehending how this could take place.
        • Imbued Ring?
          Originally posted by Harvey View Post
          "...Now imagine, that once setup in this resonant manner, the "output" is some higher energy emission, say in the THz range - small bursts of energy when ever the domains reach some maximum threshold..."
          Once again, Harvey you fascinate me with your creative thinking and amazing insights!
          As far as the ring's temperature, I cannot detect an unusually cool surface temp., as we saw with the traditional PMH. Wearing it could mask the thermal "sink" proerties (so to speak).
          When I touched it after charging I immediately felt something in the pit of my stomach (I could have just as easily been reacting to the EMF sparks created by the battery).
          However I do feel as though there is thermal activity occuring in it as I am typing, with it on my finger now. (I can't decide if it's warming me or I'm warming it.)
          I would like to try creating resonance in the ring to look for changes in behavior. Do you think I could accomplish that with a simple stereo speaker or do I need something more like a tuning fork?
          I never beleived that stones have special (ie. mystical or supernatural) properties. Now I am starting to wonder...
          PS. Sorry for sidetracking David's gravity waves thread, I think this is connected (although not directly).
          -Van
          • There are several different forms of resonance involved in your ring.
            1. Body: This is the resonance that would occur if you suspended the ring from a string and then proceeded to strike it like a chime. It will 'ring' at its resonant frequency as the actual body changes shape and the energy interacts with the surrounding air to produce longitudinal sound waves.
            2. Magnetic: This is the resonance that would occur if the device were placed inside an MRI machine (and fully secured to prevent movement). A magnetic resonance imaging machine aligns all of the domains (or even the atoms themselves) with the strong external field for a fraction of a second, and then measures the resonant frequency produced as they return back to their original structure. The machine also measures the relative time lapse of differing frequencies to provide a 3D map of the interior materials.
            3. Structural Wave Resonance: This is the harmonic response resonance that would occur if we place a repetitive synchronous wave of stress energy in motion around the ring. This particular excercise, if not properly executed will result in shattering the material. You must allow the energy to dissipate at a rate equal to or greater than the energy input because it is synchronous and can be additive.
            4. EM Wave Resonance: This is the resonant action I mentioned in my previous post. This is similar to the Magnetic Resonance, but instead of relying entirely on physical motion and magnetic interaction, this takes us to a lower quantum level where energy is absorbed and retransmitted from the atoms themselves. In a typical system, the structure is quite disordered and energy can interact at many angles and timings in a scattered manner. These types of interactions cause internal heating similar to what our skin does when UV and IR EM waves are absorbed. But in a wave resonant structure, the incoming energy causes alignments to occur in the material structure where repeating motions synchronize and the scattering begins to cohere in a specific direction. This is what occurs in a ruby for example, and the output energy in that case is a laser. That level of escalation is referred to as lasing. However, we are not limited to just a single homogeneous beam. For example, in a spherical object, the input energy could move inward where it becomes more dense as it approaches the center. Upon reaching the center, it could either pass through itself, or cause the material to emit a higher energy band outward in all directions. The cross section of a torus is identical to the cross section of a sphere. Therefore it too, could have a similar reaction in the plane of the cross section.
            5 Electrical Resonance: Similar to magnetic resonance, an applied electric field is used to align electrically polarized particles within the material and measure the action that occurs when the electrical stress is removed.
            In my previous example of heating the device and then striking it, I was combining EM resonance with Body resonance. Hoping that the body resonance would setup a wave resonant action around the loop that became recursive and used thermal energy to keep it going and building. In this case, it was hoped that prior to any structural failure, it would release the energy in some other form. Hoping that as it cooled to ambient, a phase shift would occur that prohibited any further thermal energy from leaving while maintaining the other resonant factors. In simple terms, we heat it to help put it in the resonant mode, and we keep it resonant as it cools below ambient. If the structure is able to use temperature to keep the resonance going, then it may emit other energy, especially if the frequency is above the response of atmospheric gases thereby limiting any energy losses to the air molecules in contact with the ring. Since it would be absorbing thermal energy from those molecules, the action could be to retransmit that thermal energy at another frequency that is not absorbed by the air, like RF or other light spectrums. But it could be too even THz may be transmitted that may interact with the air or other contact materials in non-thermal ways.
            Your hematite ring is no doubt a conglomerate of many different materials like quartz and other things with hematite being the predominant material and the lattice structure of the material inconsistent, amorphous. So it will be unique in how it responds to energy input.
            One thing to note, regarding wearing these things, is that they can be porous on a molecular level where sweat can enter the rock by capillary action and evaporate away on the exposed surface. This action will definitely remove heat from the rock and quite possibly leave salt deposits behind. So that would have to be taken into consideration if cooling is observed.
              Thanks David
              Good to know.
              • transparent?
                john hutchinson has made metal transparent...i was playing with a lead fishing weight, eight ounce and i have it tied to a string...spinning the weight near my device very fast....it seemed like the lead started to get transparent....this effect was while looking at the center of mass....strange....david
                • Originally posted by Van T Stride View Post
                  -Van
                  Freeze some water with it. Clear ice = female, foggy ice needle = male. It is possible for you get both. Magnetic or electric wouldn't produce this kind of ice, at least very very weak.
                  I believe that Philadelphia experiment to make a battle ship dissapear is using very strong female energy. But when the ship made to appear again many of its passenger going nut because of strong male energy.
                  I believe that Edward Leedskalnin utilizing female energy to nullify environment effect to the rock, not anti gravity, but a bubble where gravity have no effect, maybe light too.
                  • Ice and The Generator
                    Originally posted by sucahyo View Post
                    Thank you. It is different. That should be PIP (polycontrast interference photography). However, I think picture reading is less effective than ice experiment or pendulum reading. I never see polarity shown on PIP picture which I think very important to know for our experiment.
                    I now believe that gravity effect is related with energy that can produce clear ice. And it is definitely not magnetic nor electric.
                    See if you can accumulate your PMH wave by something like this bellow:
                    One face absorb, other face shoot. Made it with insulated copper wire. Maybe from bigger diameter, maybe 10 roll or more. It produce noticeably different ice pattern on each face:
                    So, here you are saying that using the coil shown above you created a "lens" made of ice which posses either male or female energy? Assuming that were true then is all "normal" ice exhibiting male energy? With your coil are you applying any voltage across the wire while freezing, or simply freezing it without energizing? Assuming the ice is used to absorb the energy from the device what should happen on the other side - a collimated beam? Do we know if leedskalnin utilized ice somehow in his work?
                    Assuming the energy coming out of the device is almost imperceptible except via a faint "turbulence" in the air around an iron or quartz object, would "focusing" the beam have any detectable result? I wish we could have access to better optical devices to properly "see" the effect, and then by seeing it intensify or reflect or refract, we should be able to think of practical applications.
                    I am also curious about the video where Dave shows energy dripping from the iron pipe. If the energy collects and behaves like a liquid, then maybe it can be captured in a container or made to move inside a closed system?
                    -Van
                      coil create polarized energy. ice show it.
                      The male ice is different from normal ice. Unless you are replicating, you won't know what I am talking about. male ice look like made of thousands of small air needle. A camera zoom might show it, but unfortunately I can not do it again now. I manage to capture the clear ice part with air helix from different experiment though:
                      without energizing. That is open coil. Try it yourself.
                      I use ice to show the energy, not to absorb it.
                      No. but it may explain why there is iron inside a wood near the PMH.
                      If I have money, I would already freezing various configuration of PMH to know how I can improve it. I would use ice pattern as guide.
                      The problem is how to capture it. And I don't think better optical help if we still use same CCD or CMOS technology. I recall Tesla use 30 minutes exposure on film photography, everyone have the camera and photo processing service?
                      If it is available everywhere, creating generator is better than finding a way to store it.
                      • The bell, the bell, the bell
                        It came to me this morning... maybe Ed L used the bell at Coral Castle to create DC pulses for charging PMHs? Imagine the bell is hanging above the PMH (or generator) and a wire is run from one terminal of a battery to the top of the bell - ideally attached so it doesn't interfere with the tonal qualities of the bell when rung. Then a second wire is run from the other terminal of the battery, coil around the PMH and back to the bell near the outter rim. When struck the surface of the bell vibrates. Bringing the end wire coming from the PMH into close proximity of the bell should produce the same frequency of pulses in the system. His door said "Ring Bell Twice" I'm not sure if that is necessary?
                        When I charge my PMH I have attached to one terminal a clamp with a steel bolt hanging off, and I will sometimes drag the wire along the raised threads of the bolt creating a poor-man's equivalent. But I beleive I may try the idea indicated above. Obviously the tonal qualities of Ed' bell would be crucial to the result - I doubt he selected it at random (and he may have modified it for his own purposes).
                        Van
                        • hmmmm
                          Maybe "Ring Bell Twice" means use the tame technique twice - apply the coil to each leg of the PMH and ring the bell.
                          We saw in videos posted by others that using two coils - one on each leg of the U shape, in a simple PMH, creates more strength and a more clear North and South polarity in the soft iron metal. Otherwise with a single coil we get the strongest region of N & S attraction on either side of where the coil was wrapped.
                          -V
                          • Ice effect with a coil
                            Sucahyo - I tried the copper coil in a shallow dish of water, and can clearly see the ice form consistently on one side of the coil as a cloudy mess, and more clear on the otheropposite side. I tried taking picutres of the bubbles, but digital camera can't seem to focus below the surface of the ice. I will post some pictures of this behavior. Next is to freeze the Hematite ring and the small oval PMH (seperately).
                            With the copper coil I found that making it into a cone also produces and exaggerates the effect in the ice. I am going to try mounting this type of coil inside the PMH for testing of the visual effect that David and I have seen with certain materials.
                            • What is the resistive force?
                              FYI...
                              Thinking about the feel that is generated by interaction with certain metals and quartz (or other heavy minerals) I wonder if this is would be similar to what is described in Science Fiction literature / films as an "inertial dampener." Not gravity - at least not in the sense that we think of it - and not necessarily anti-gravity , but maybe a force that can modulate the effects of motion or inertia. I feel the force most strongly when the stone is approaching the PMH at a particular angle and both the PMH and object must have a particular velocity. If the PMH is not spinning just so, or the object is not moving toward the PMH the resistive force is very slight, if there at all.
                              The resistive force and the visual phenomenon may appear together or seperately - I have seen it better at higher rotational speeds than when the resistive force is felt.
                              -Van
                              • Ice coil photos
                                Picasa Web Albums - Van T Stride - November 11, ...
                                Last edited by Van T Stride; 11-11-2010, 08:19 PM. Reason: Pictures were too big on the page
