Thank you for the reply Harvey.
I try to notice nature, differently now since some of my expeiments.
One thing I specialize in is Ancient Hebrew before Paleo and modern Hebrew, and it is in pictograph. I am one of maybe a dozen in the Us to do so.
So wht does this have to do with gravity her one may ask.
Well each letter represnts a congnitive idea, a number, and from my research -- a note, a color, a frequency, a scent a smell, a taste, a body part, and now I have discovered also a radionic potential. In light we have 16 visible colors and 8 near infrared each one about 24 degrees apart as represented by a spiral or scalar wave. At 380 nm the cornea filters out the detrimental UV and at about 1200nm the vitrious humor filters out the mm waves that are detrimental. As also the earths atmosphere is a filter. So we exist in a wavelength filtered inviroment and body.. We exist in a narrow spectrum of radiant energy for the most part.
So ther are two missing letters from the Modern alphabet, the Ghayin and the Tann. So that makes 24 letters, hence 24 differernt parts to the outside of the gravity wave machine.
Take for example a cube and place 6 pyramids on it you now have a tetrahexahedron of 24 faces. Now place this inside a cube. Then take four other cubes and place that one cube at the center of those four cubes, so the one cube with respect to the others is 180 degrees out of phase and in each of the other four cubes is a tetrahexahedron.
So if I take a line from the center of the first cube through the center of the meeting place of the four cubes and then take a line from the edge of the first cube to the central outer edge of any one of the four cubes then I wind up with 22.5 degrees which happens to be th incidentaangle for light in a prism or a rainbow. This same line also operates on the inverse square law. But if i take a starting point on the bottom square at the tip ot the tetrahexahedron abd spirap aournd the other potnts of the same in its square and then expant to the outer points of the oter four squares in a spiral, then i get a scalar wave. The scalar wave does not see impedence as the linear wave and does not perceive time space boundries and most likely can even exceed the speed of light.
So it occured to me that a scalar axis 90° from the time axis both of which straddle the propagation axis.
So any movement of any wave in space is affected by the other four planes.
So also keep in mind as the sea shore 45 degrees to the right and left of the viewer put the viewers axis center at 22.5 degrees ot eh perception angle to the incident waves. Also keep in mind that the Scalar and time planes are at 45 degrees, in keeping with the tetrahexahedron, to the XYZ axis. So the XYZ are all 90 degrees but the two intersecting T and S fields are 45 degrees to the XYZ.
So now as to your other point. In nature there are static fields thaa serve as potential energy. This energy has to move first by a disturence in the sea of fields as per Direc's Equation.
The moveing of the Static produces and E field that upon its movement then sets up a magnetic field. So the magnetic lags the e field. In lightening, also a tesla coil, first we get E field movement and then a current. In the ocean we have to have a field that attracts or repels the dihydrogen oxide, as it is a bipolar molecule, and then the current is the action of the wave. The moon sets up a gravity field which has to contain an efield and a Magnetic field and a gravity fiels as a result. So gravity has to have a Time , Electric and magnetic component.
So as far as electrostatic, let us consider:
1) the Electron and its counter the Positron, or a minus and plus of the same entity.
2) the Proton and its counter part the anti-proton or a minus and plus of the same entity.
3) the time line parallel to these two
4) the scalar lin at right angle to the time line
So the earths surface has the sea of electrons (as per Direc) but with the immediate surface as more positive with the positron side up, and then deeper in the ground the electon and then the postitron and then the electron and so on. So the earth is essentially a negative ground, but with the surface the more positive. The sky is the same with the antiproton towards the earth and the proton more towards the sky stacked in the same manner. The separation of the atmospher of dihydrogen oxide and o2 and nitrogen is separated by the repulsionn of the positives from both particles.
There is a normally a static rest until a distrubance from gravity in the form of a wave, and then there is an electrostatic imbalance set up which causes an E field movement first followed by a magnetic field which we see as lightening, which sets the fields back at rest.
Also the 3, 6, and 9 that Tesla found i have found in the 24 letters. Each not as defined by light starts and 3, then 6, and then 9 up the scale of all 24 and repeats 8 times and is the light scale frequency through which the universe resonates. I have 4 gigs of research on this so it is a lot to get into right now.
So just my thoughts and observations.
