gravity waves found
  • sorry about the audio
    the distortion of image under the stone i like a liquid. when i move the stone around in the field, i sometimes see eddys [whirlpools]from the corners. this is exciting. this energy is like a mirage. and a mirage is a reflective surface. add a circular eddy and you get a lens. it has been hard enough to get the image of this field, getting images of the eddys i am sure will prove to be difficult, but i will get images of this phenomena.
    • video
      A TRULY VISIBLE MAGNETIC FLOW [enhanced version] - YouTube
      • David what class of iron oxide did you use? If you dont know can you give a company name or the chemical formula if it was stamped on the container?
        Also the id of the rock. It looks like it may be hematite.
        Thanks!
        Btw: This may be a fine thermal reaction. You could freeze the rock and test to see any differences.
        • Fe3O4
          alpha chemical, black iron oxide, Fe3O4. the rock has shell fragments, sedimentary i think. if you make one, energize it like a PMH, and you will see what i have been talking about this whole time.
          • Thanks David!
            • David I watched your youtube vid with a rock you said was levitating. If so all you would have to do to demonstrate this would be to hold the rock above the generator with a spring scale attached, even a fish scale would work, if gravity was reduced on the rock weight on the spring scale would decrease.
              • curious one
                it is not that easy. how long did it take me to finally get good images of the the visible distortion that i see? i will find a way to demonstrate the weight reduction i feel. i will not rest until i do
                • I agree with David here - the attraction could be quite small so a very sensitive scale may be necessary.
                  Then we also have to ensure that the device does not act as a squirrel-cage fan creating a suction in the center that would draw the crystal toward itself by air pressure.
                  I had envisaged a balance beam (easy to make with a bag of sand, a fulcrum and a stiff pipe or conduit) that would have one end hover above the device. Then it is just a matter of sliding the device under it and starting it spinning - but then I realized that we have to address the air flow . . .
                  . . . perhaps a plastic sheet between the two to block the air flow
                  The fulcrum can be a hanging wire or fishing line; or even a knife edge under the pipe.
                  Accurate to one grain of sand
                  • new video
                    laser video # 1 - YouTube this video is crude at best, but please check it out
                    • Originally posted by david lambright View Post
                      This may be caused by your heartbeat which slightly deflects the beam by changing the pressure in your arm, hand and digits.
                      Try swinging the laser on a pendulum instead
                      • Dave heres a prism idea. Take a right angle prism,or equilateral, and use a white light source or even the sun to see any possible interactions with the individual spectrums or frequencies. You could also try the laser to it.
                        • https://www.youtube.com/watch?v=ml_anVVlYAg check this video out
                          • i am reflecting sunlight off a CD....why? i don`tknow
                            Lol!
                            I would still try a prism with the separated spectrums.
                            I use an old color crt monitor to check remanence on rods. Might be interesting to see what the wheel and tube patterns look like on it.
                            • I have a new video on my YouTube channel that is alright, it could be better though.
                              • Good to see your still working with this Dave!
