the photo is on the site EnergeticTube.com under david lambrights photos and description....my computer sucks ...and i have been kindof busy....trying to figure this out!...onites findings..if light[visible] can polarize , then this wave must also polarize. i was checking the effects of ovequartz,a 10 or 12 lb chunk held about 10 degrees off axis,about 24 inches above the rotating PMH produces an excellent effect,the wave gets so "thick" that an interference pattern starts to develop...physics law tells us that all that light being bent must produce color ..... it does.....i forgot to tell you about how it feels when the wave is most active...it feels like an energy moving through me!..i am telling you, this is the real deal ,no more guessing no more speculating Eds machine works! and about that video....most all cameras use IR for focus and this wave messes with all wave lengths .. then i thought about photonics...but then i thought about al nobel ... i know that this discovery will will be the source of much good , i am so excited ... when will some one build a model and verify every thing i have found so far.... will some one tell jon depew and other leedskalnin followers what has transpired...just thinking about the far reaching implications of this...i am literally shaking!!! some one please build and verify....this is so amazing.... more soon gotta go to work im a plumber.....david
There's one question I have. Are the sliced pipes hardened steel, soft steel, cast iron? The perpetual motion holder seems to work well with steel, but I haven't seen a PMH using brass/copper as these pipes are more common.
David,
I can understand you're shaking. Please keep nurishing your brain with food and water, and watch some reality tv to relax it :-)
In your experiments, did ever a potentially dangerous situation occur?
On the topic over anti-gravity, I've read on 2nd hand accounts of item launching "themselves" through walls or ceilings, never to be seen again.
One could surely guess on some precautions replicators could take, but perhaps you've already had some experiences to share for our replicating friends? I'd be wary of large amounts of energy being stored, while hoping to get "an effect". When it should occur unexpectedly, or in an unexpected direction, blood might be shed.
new video on potatoheadist!!!better quality but its hard to capture something that is usually invisible!!!...look closely ....more video soonest.......david....YouTube - video-2010-05-10-07-04-42
Reason: add link to youtube
this wave form is all EMF combined ...it must adhere to physical laws governing their frequency...math will prove this ...this is the real deal ..our understanding of the universe is going to expand FTL.........david
David
This looks really interesting. I think it is better to look at it in full screen mode. Not sure if you have directions mixed up from your view point, but to me looking at the video, the area vertically above the outer right hand edge of the generator, and coincident with the corner feature is showing an interesting effect, like swirling dust.
thanks for the new video and also the explanation on the coil.
Can you do some sort of a schematic / wiring diagram, because your pmh doesnt look anything like the other pmh's that ive seen....the ones ive seen are horse-shoe shaped with a bar going across the open end of the horse shoe..and coils wound around the two straght bars of the horse shoe.
Why is yours made of segmented peices of what looks like sawed off sections of a split pipe?
Ok, I worked hard this day
I made 24 pieces of 200mm long steel bars and then heated them in the center part red hot and bent them all into a V shape. It is hard to get all the parts equal, but I managed to do this more or less accurate. Then I wound a coil on one of those pieces and put all pieces next to each other on a table in a circle. Then I pulsed a high current in the coil, but nothing happened, the pieces did not stick together. Then I zip tied them all together to ensure minimal air gaps and tried pulsing the coil again, also nothing. I separated two pieces and pulsed the coil again and I could feel a little attraction between those separated pieces, but that was hardly noticeable. The problem is bad contact between the pieces, I will sand the flat parts smooth tomorrow to ensure a tight fit. Also I believe that the reason why Leedskalnin had two coils on his PMH was to ensure minimal magnetic resistance in the core at the magnetization time, because magnetism does not go too far on a steel rod, that is why using multiple coils apart of each other ensures a fully saturation of the core and I believe this is what we need. I will also wind coils on more pieces each equal space apart from each other. Will see how this works, if I will manage to get the PMH effect on this setup, I will put it on a rotating plate and then the fun can begin.... I hope.
Jetijs
Jetijs you may wanna look at this Video,
this guy use a different way, as its usual is. YouTube - pmh and vee magnets
He did magnetize Iron in a differnt Way, more with magnetic current,
not with curent let run it through, like the example in his book, he shorted the Batterie, and did hold the Iron Material beside.
Some Lecture: Ed Leedskalnin - Magnetic Current (Illustrated)
And good for Harvey too, to read, lol
And beside, seems the things what E.L discoverd are more at the buildings from Coral Castle,
lesser what he said about. Coral Castle Photos
For the Generator it look like it is the Magneto from H. Ford used in Lizzy I
At all this Photos are some, where you see in front from the Wheel laying a big Pice of Iron like a tube with Wire or something similar.
At the Wall are Glassbottles with Wires and different adjustable Capacitors.
Harvey, remember, at the Capacitors, how it stores Energy, at the Dielectric?
And Glass is one. And a Spring is at Coral Castle too.
And btw, when i look how much work David should do now, to show his Results and findings,
i have hard to think about, to post a Device, when it is promising, lmao
your machine is beautiful!..i am a little jealous..OK..sand or file the mating surfaces flat smooth and clean...put it all back together just like the photo but this time, close the open gap in the ring with zip ties like the rest of the ring..energize the ring with a DC battery,9 to 12 volts just a quick spark a couple of times will do....now then..put your hand near the ring..you should feel a kind of coldness near the ring ..... subtle...then start the ring spinning ..no motor ,just by hand.....now take a chunk of steel and hold it at plane...turn it different ways and you will start to feel this force acting on the steel....when you feel it push keep it there and it should and it should push harder....now...take a good sized piece of steel and hold it over the axis[or 10 degrees north off axis]...and you will feel it being pulled down to the the center..now look at the space in between.... you will start to see what looks like a heat wave...now you can experiment..in my last video i am using a chunk of quartz with excellent results...try different metals,crystals and dont forget the laser!!!....be amazed!! ............physical laws govern all waves and this wave must obey also ....if current flows around a wire so will this....Ed did what said he did and levitation is next...with out breaking any physical laws.....this is HUGE!!! any way try it out......thank you all david
Well done making this discovery! (Or rediscovering it if you will) I hope all who replicate it have the same or similar results as you.
Any reason why you used aluminium cores? (Are they aluminium)? Is iron ok (like Jetijs) or should it be only aluminium (non-magnetic metal)? Ok, they are galvanized iron pipes - my bad.
..So you wound the wire around the cores, and energized the coil with DC voltage, 9-12 volts. Is the coil then left in a open circuit condition? Or is the coil energized and then the coil shorted out (while the battery is connected) then the battery supply quickly removed. The inductor or coil should retain the energy better, as a inductor is discharged by open circuit, so if you keep the coil closed or short circuit, it wont discharge.. Just a additional thought..
Mind you I have not watched the second video as yet (need to get to my own PC). So you may have already answered some of these questions..
If all of this is true I would suggest to watch out for those invesitgating MIB types.. However it almost doesn't really matter now, thanks to you; the cat seems to be out of the bag.. Well Done!
@ Jetijs, Wow you knocked up that rig real quick!
@ all, let us give it a try!
This is what this forum is all about!!!!
Reason: spelling
