Originally posted by david lambright
You ask how much 'heat' it takes to bend light? I don't know that 'heat' CAN bend light. I rather doubt it. Light always travels in a straight line. It can be deflected off different materials and, from different densities such as water. This may give the appearance of a 'bend' I suppose. But light itself always travels in a straight line. The only thing that is understood to 'bend' light is gravity - and then the understanding is that light will follow the line of gravity. This much of Eistein's theory has been conclusively proven and was the very test that rocketed him from relative obscurity to immediate international fame.
There is nothing between your camera and your rig other than air. If there were 'heat' being generated anywhere between these two then the air molecules - atoms - would be dispersed and agitated that one would see interference. This would - at it's most - cloud and obscure the sight of the rig. It would be a rare 'heat' phenomenon that first put any such photographed objects into clear focus let alone give them a 'shape distortion' with the clarity that both your photographs and your videos do.
The simple fact is that unless light is actually being 'bent' there is no known explanation for the distortions that you are both seeing and showing - and that with such extraordinary clarity. To me the example that defies all sense is the 'lambright wobble'.
Then regarding the anomalies of weight. I take it that there is a tangible 'pull' of heavy objects towards the centre of the rig. You do not need to weigh in on the degree of 'pull' - but it would be nice. Meanwhile I trust to your reporting of this as well as others. Such 'values' are subtle. One does not doubt that one magnet can pull another magnet towards itself. Nor does one doubt that metal objects can be 'drawn' towards a magnetic field. Neither event change the apparent 'weight' of either object. Yet no-one in their right mind would deny that 'pull'. What is intriguing here is that the 'pull' is not confined to magnetisable material. It seems to 'cross all boundaries' which, in itself - speaks to a gravity field rather than a pure magnetic field. If this same field is also changing the molecular distribution of air around the rig it would speak to the effect even more strongly. But that 'bending of the light' that would be required to give those distortions? That cannot be explained by the redistribution of molecules and atoms in that 'atmosphere'.
So take heart David. You're at an early stage of something. Don't be persuaded that the effects are trivial. If we were to ignore all such events as trivialities then I very much doubt any scientific progress would ever have been made. I think I know something of how you feel. You have definitely NOT won the Darwin award.
