gravity waves found
  • #46
    more info...
    i am a plumber,the pipe was in the yard,galvanized steel...the wire is insulated copper unwound from a transformer.I have been playing with a large quartz geode, about 14lbs and its really interesting!..effects; turning the rock over and around changes its weight ...the rock ,sitting close to the rotor gets two "warm spots",not on the surface but a couple of inches away....a large magnet when touched to the surface, the rock makes a hissing "noise"and is magnetic for a while and also it"relaxes. i am playing and typing at the same time and realize that the quartz is vibrating!...i think i can solve my camera problem......more video soon?.....david
    • #47
      I see that David's rig has a different height to length ratio on each segment compared to others I've seen based on the Lizzy gen.
      Perhaps there is a need for that taller material?
      Also, David's have a smaller contact area between segments where the two radii meet since they are curved. Perhaps Jetijs could insert a small rod (16 penny nail?) between each segment about midpoint and see if it has different results for the small contact.
      Two things I'd like to see:
      1. Secured Laser pointer passing next to the rig shining on a target behind the rig. So if left and right are X and up and down are Y, the laser points Z on an XY target.
      2. A fish scale or hanging postage scale or even a balanced board extending over the rig with that quartz geode on it. Then we could measure the weight change
      The last video sure does have a lot of blurry action around the rig - so if that is what David is seeing first hand, it would seem he has captured some of it there. It is difficult for me to distinguish between the movie resolution software adjustments (because the camera seems to be moving very slightly) and the actual effect.
      Thanks David for all your hard work getting those images to us
      • #48
        HD video...
        see it on potatoheadist`s channel on you tube...leedskalnin did it this way is the title,let me know if you can see the effects .....david
        • #49
          more info. on my generator..
          i dont think it matters about the coil. on mine,its open but does not need to be there. after charging,the copper wire can be removed. this force "grows" when subjected to extra gravity..spun...i just got an idea....watch for video.....david
          • #50
            Thanks David,
            Here is the Direct Link:
            YouTube - leedskalnin did it this way!
            I did watch it up to 720P but I don't see the color change,the reflected energy or the 'heat wave' effect - it could be my monitor - I'll try and view it again on another system tomorrow.
            Cheers!
            • #51
              it is the wave seperated from heat that i discovered.
              • #52
                Affect the effect.
                Does the speed of rotation of the device affect the effect? I.e. Slow V's fast or stationary? If you have more than one energizing coil does that make the effect stronger?
                It appears that the HD video does show something ...very subtle...? Perhaps it's a phenomenon that can be better seen only with the naked eye rather than with digital photography?
                Still, great to see the HD video. I eagerly await some other peoples replications and more video clips from you to show these odd effects, what interacts, reflects, reacts or other strange stuff not yet known...
                • #53
                  as far as i can see and feel, because this wave must mimic IR light.this wave must absorb and radiate just like heat.Magnnetisim is a wave form so this new wave must do what magnets do.....i predict that this discovery will unify physics!!!!
                  • #54
                    David
                    The platter that the device rotates on(sander disk) is it made from aluminum?
                    Kind regards
                    John
                    • #55
                      I am surprised the disc doesn't slow down when you are using it to partially overcome gravity pull on a weight. Is the rotation irrelevant then?
                      As I responded to your latest HD video, please consider demonstrating by suspending your weights from elastic bands. You'll have a familiar counter force not affected by the gravito effect of your device. Less weight (m*g) on the weight when in the field, will mean the elastic band will lift it. Beautiful would be a horizontal level guide rail to hand the elastic band from. If you device works, the demonstration will be spectacular. Everyone knows how elastic bands feel.
                      Thanks!
                      • #56
                        Hi guys
                        Today I sanded all the flat parts shiny and smooth and assembled the V pieces in a circle again. This time I also used zip ties and this time I wound three coils. This did not change much, because there were still very small gaps between pieces, because it is very hard to bend all the pieces to exact angle and exactly in the middle. I read "The ultimate reality" by Joseph H. Cater and his physics model matches exactly with what David says, so I think there must be something on it. He also states that gravity is just an EM wave in the range of lower infrared spectrum with wavelengths of 1-4mm. All the aether particles that make up this wave are affected by centrifugal and centripetal forces, so when you spin the wheel, the aether streamers are forced out at all the 24 poles, this creates a void in the middle and other aether particles are drawn in to fill the void. This is similar to Shaubergers water turbine where all the water is forced out the nozzles by centrifugal force and this creates a vacuum in the middle that sucks additional water up from the bottom. I think that it does not make a big difference if you have all the V pieces hold together by magnetism or if they are welded together or even if the whole wheel is cast in a single piece, what matters is that the magnetic flux once created can continue to flow forever. This means that also a big iron or steel gear should do the trick, it should just be cut in two halves and a coil should be wound on one of them or on both of them and then when energized, you just put a LED across the coil and pull the pieces apart, if the LED lights up, it should work fine. I believe the 24 poles are not due to some numerology or sacred geometry, it is just the minimum count of poles to get a certain frequency at max RPM's that the operator can spin the disc. Ok, now back to my experiment. I thought that to get the best coupling of the pieces I should compress them together by a vice and veld them together on both sides, so I did that and made two halves with 12 V pieces on each half. Then I hammered both halves till I got the best coupling on the flat surfaces that will make the contact. Then, to be sure, I wound coils on each of the V pieces, 10 turns each and connected in series. When the coils are energized, both halves jump together from a distance of 3mm, when the power is turned off, I can pull one half and the other is pulled along. This whole setup is heavy, about 10KG. Anyway, if I break the pieces apart, there is still some residual magnetism, but I can not pull the other piece along with the first when I move it, but after the coils have been energized, I can do that. But still, if I connect a LED across the coils and break the pieces apart, I don't see any light at all as I do with a standard PMH. I zip tied both halves together and energized the coils. Then I just put it on a horizontal wheel of a wheelbarrow and spun it. Did not see or feel anything. Need to think about this some more and try some different setups.
                        Jetijs
                        • #57
                          Jetijs, that's beautiful work!
                          Perhaps the support rotor material is vital here. Even if it lets magnetic and other waves through, having an volume taken up where it cannot accumulate/saturate, might be of importance. A slab of aluminum or teflon...
                          Hopefully David can offer you some pointers to get your setup to show anomalies.
                          • #58
                            I'd like to first say I think Ed Leedskalnin and things he did at the Coral Castle are fascinating and he really had something going on there. But so far I'm not seeing a thing in the videos that isn't explained by low video quality. I've also found 2 new videos david put up but hasn't posted here yet. Everything in them seems to be his perception but nothing is actually seen in the video except maybe the first one and that one was apparently done with a very low resolution low fps video camera like I've got in a cell phone video recorder. And with those types of video recorders you get effects that appear to distort images in such a way as it looks a bit like heat waves. I really don't want to be negative here at all and fully encourage david to show us more but please do it in a way that can easily be validated rather than just your own perceptions being recorded. Maybe you have acquired the ability to see aura's or energies that most people cannot see but so far I'm not seeing anything that isn't typical of relatively low quality video recorders.
                            What I would suggest:
                            1 - get a fish type weigh scale or other hanging scale and hang something over the device when it's getting lighter it will be obvious on the scale. If possible suspend the scale from some stationary object so that hand movements don't bounce the scale pointer or readout. Fairly cheap (around $8 IIRC) can be had from dealextreme.com - but will be slow in arriving from overseas.
                            2 - show a laser being deflected and/or set one on a small rolling device (maybe some round 1/2" copper pipes or AA batteries lined side by side) if it is being pushed back then it will begin to roll.
                            Please don't let my comments discourage you at all but it would be good to see something more concrete in the videos. I really believe your efforts here are sincere. I think it will help you to have something that is easily measured, recorded or in some way empirical evidence as opposed to a subjective observation.
                            • #59
                              yes it is....i am willing to let ANYone see,examine,whatever ...i live in salem oregon...is there any one close to here? i challenge anyone..see it with your eyes and then decide...e-mail me ...david.lambright@hotmail.com...do i need to post my address and phone#.....i will......everyone i have shown this to sees the same thing.....i can reproduce this ...PS i never used any heat to bend my metal ..i used a vice
                              • #60
                                I made a little setup too but have not been able to get it to work yet. I cant get it to lock and stay locked when i charge the coil, im sure its because the metal isnt mating up good enough, but this is very hard to do with 24 pieces. David do you have any tips for getting a good connection between the pieces. Maybe tomorrow ill try something more like what you have. did you just sand it smooth along the curved pipe, so that the curve touches the next pipes curved surface, or did you sand a flat spot on each pipe?
