gravity waves found
  • i can do better..
    you can see a flow at the upper left....you can see one of the zip ties on the side of the device..this was done using ians method, with a 4" mirror....ian uses an 18"....24 might work better...i said that before....greenpowerscience mylar+vacuum method ....that would make things easier...more soon...david...YouTube - schlieren & ian...thanks...
    • Originally posted by CatLady View Post
      We need to keep searching for the truth.
      LOL Cat. You seem to have a knack at finding appropriate comments.
      In defense of the internet I would say this much. It is a means of recording our history of sundry developments with reliable reference. Otherwise - as so often happens - the development of new insights and new technologies - would and could be misapplied, misinterpreted or, God forbid, misappropriated. In this way no-one can ever assume that Dave's discovery is less than his own work and - hereafter - it will be acknowledged as such. The proof is here and available to us all. This is regardless as to whether it ever reaches mainstream or not and regardless as to what he subsequently finds as an explanation of these anomalies. That he has found it and made it available to us all to explore is a tribute to his integrity and to Open Source principles. Yet again. Thanks Dave.
      • if you saw it!
        Originally posted by rave154 View Post
        David,
        i think the best/easiest way to determine wether or not it is the camera alone producing the odd optical effects is as follows...
        take a piece of card, circular, roughly the same diameter as your rig, using a thick marker pen just roughly draw the same shapes as you have when looking down at your rig, ie :- the circle of outward pointing "U" shapes....mount the whole thing on a nail which is pointing upwards....to enable you to spin it... doesnt matter if it wobbles ( your rig wobbles too )...
        spin it & film it.
        Hope this helps
        thank you for all your good ideas ..i did not mean any thing by the box stuff...i know that when you see this energy wave you will under stand also ...thursday is coming and i want to try many expirements...the schlieren photography method by ian works great...i just need a bigger mirror ..watch the video[bad]...in the upper left you can start to see a flow pattern...your input on this project is needed....thanks for helping... this is so new that we have to make new terminology ....david
        • terms...
          magnetic lock;..as in locking a PMH ..... energetic wave;.. the wave form seen distorting either light, space or air..... i know there are more words we have been using to describe this new energy.....what words do you want to use for ease of understanding.........david
          • jet..
            how are your projects coming ...i have heard that others are getting results?...i know the ferrite thing works ...has any one got anything,elect., out of it yet?...i think someone else has but is keeping it low for now?...you guys are great...thanks for letting me post on your forum....thursday is coming.... ....david
            • i like your descriptors.....i dont know if i said that right?...david....PS...new vid...YouTube - ian & schlieren
              • David,
                Please research existing technology dealing with Gravity. A great place to start is John Quincy St. Clair john quincy st. clair - Google Patent Search
                Most devices by St. Clair and others have a few common themes. Bucking coils is one of them.
                Please also look into Ley lines.... They show how the Earth's magnetic field is really constructed. Along the way you'll find how gravity actually works. It's a reuniting of Magnetism and Electricity where they no longer occur at 90 degrees to each other, but rather are are 0 degrees off.
                Also, modern science is using this same design...
                look up Superconducting Gravity gradiometers
                they are used both for gravity detection and.....guess what else................
                brain activity mapping. Yes, our brain waves ARE GRAVITY WAVES
                • Light
                  Pure white light is made up of 7 different colors,7 different wavelenghts,7 different frequencies. You can see these after a rain,when the sun shines. It is called a rainbow.If you change just one of these wavelenghts, or frequencies, you can change the properties of light.If Dave's wheel is capable of changing gravity,more or less, then it may be capable also of changing light, or at least the way we see light. I propose that gravity does have an effect on light. Antigravity should make light invisible,at least to the naked eye.Gravity itself is not visible,neither is magnetism. These are wavelenghts far beyond our vision.I would ask David to use a fresnel lens above his machine to concentrate the light and possibly intensify the effect. This should either rule out light distortion or positively identify it as such. If you don't have a fresnel lens, put some water in a clear dish in order to view it from above.If it has no effect on light,then you may be dealing with another phonomena.Good Luck. Stealth
                  • You won't get much gravity effects until you spin the wheel with 2 bucking fields concentric to it, preferably in the middle. You need pulsed DC into the bucking coils with it spinning. a rotating magnetic field plus a linnear bucking field(preferably with a capacitor plate on each end connected to each coil) is the standard recipe for a wormhole. All the extra energy that Leedskalnin, Tesla, Schauberger, Stan Meyer and others used was energy from hyperspace accessed by a wormhole.
                    If you don't believe me, perhaps you will take John Hutchison's word for it.
                    When he made a working model of the ARK OF THE COVENANT, it created a small wormhole through which angelic beings came and went. These are his statements.
                    Ark of the Covenant
                    • Originally posted by david lambright View Post
                      Thanks David -
                      Also here is a very good video describing the Schlieren stuff I thought I would share:
                      YouTube - Schlieren photography of moving air
                      • Originally posted by Harvey View Post
                        Thanks David -
                        Harvey,
                        Thanks for posting that video.
                        One of the best I have seen presenting the Schlieren technology yet!
                        Do you have a similar source for "seeing" magnetic waves?
                        IndianaBoys
                        • energy plume?
                          the image testing so far show a definite energy plume coming off of my device..the videos are done with a 4" mirror! the vids show barely any thing...more vid soon
                          • Originally posted by IndianaBoys View Post
                            Harvey,
                            IndianaBoys
                            i would like to see that also...david
                            • harvey...
                              thank you so much for getting this new technology aimed at all the applications this will advance also if you are getting those effects try the steel above the device...there is a point of "lock", for lack of a better word, at about 10 degrees off axis, north...this lock provides the best visual distortions....all the links you post are the sciences that will be affected / will affect this new energy... ...david
                                Harvey,
                                IndianaBoys
                                Your Welcome =)
                                The best I've seen yet is the Pinestone apparatus:
                                http://s81.photobucket.com/albums/j213/pinestone/?action=view&current=flux.jpg&newest=1#!oZZ1QQcurr entZZhttp%3A%2F%2Fs81.photobucket.com%2Falbums%2Fj 213%2Fpinestone%2F%3Faction%3Dview%26current%3Dweb addresstag.jpg%26newest%3D1
                                For some reason his website has been taken offline and I can't find the kewl you-tube vids he once had up. But here is a link to some of the vids:
                                Magnetic Warp (Three Magnet by Hand) | SciVee
                                To see waves with his device would require an EM signal of reasonably large magnitude and low enough frequency for the oils to respond - but it does work well with magnets, and if you motorize a magnet you could probably test the frequency limitations.
                                Ah I found it - it was sirzerp, not pinestone channel =)
                                YouTube - SirZerp's Channel
