Hi all.
Today was another day full with playing around.
I fixed the pieces together using the hose clamps very tightly, then I used zip ties and fixed the pieces in that tight position. Then I removed the clamp. Three layers of zip ties held the segments together so strong that it was even very hard to slide them between each other even a bit. This is much tighter than ever before. Unfortunately still no result. This time I used only one coil to energize the rig. Then I tried to put the pieces on my rotating wheel to see what happens on higher RPMs, I bolted the ring down using 4 screws and washers. Before I could spin it up to about 300RPMs by hand, this time I could go up to 600RPM before vibration became a serious issue, but still no results. Here are the pictures:
To be sure, are you accomplishing magnetic lock, or can you check for this at all?
Else, perhaps it's to do with David's "loose" fit on the cutting board. On the simpel ring, the lock seems to be directly associated with a contraction of the path of megnetricity (if that is the word here). I am not sure this dynamic is there in your setup. The way I visualize, the segments want to "set" themselves. They seek the path of lowest (or highest) resistance, and the loop is a fact.
Thanks Cloxxki.
So far nothing has worked for me, so the problem could be anything, from the rotor beneath Davids setup, to the loose fitting. Might still be that the location has a major effect on this, although channeling info says it should work also in "non powerful" locations. Will see what the laser cut rings do, whenever I get them
Jetijs
I saw it! Better than in your very first video's.
At first I believed because I (want to) believe people, now I believe because I saw what I think you saw. It's quite beautiful. I'd rather call it streams than waves as I saw it on the video though.
It seems to manifest itself in the shades of black. Perhaps a camera known to have great dark color depth could be used to uncover this even better.
i am uploading 4 new videos that were taken outside, using different methods, to capture this stream of color...good idea on that type of camera....david
Thanks Cloxxki.
Jetijs
Let me ask this question - why do you, guys, use one coil to energize PMH? While Leedskalnin himself made it very clear that two coils are needed, located as close to the curve of the U-shaped core.
ABC
P.S. I'm going to open another thread on the Leedskalnin theory
Mark: do you wish to be labeled/ thought of as a TROLL also, as many on this forum are showing themselves to be as we come closer to the truths? Laughing at an idea like that is a no no if you are really on our side. If you're not with us, GET OUT!
