gravity waves found
  • Originally posted by zapniv View Post
    like this looking Measuring instrument
    small and cheap
    and belive there will be somekind of Oscillation at scale
    While I like it, it cannot determing a difference between a stationary 4th stage 1950s rockets, and the same when spinning around its axis.
    Yet, thrown into vacume by a given propulsive force, both will result in different orbit paths. Which according to Newton, should not happen. Spin does not affect weight.
    Also, 2 repelling magnets can be forced together. They'll fall, I think is was, slower, than the magnets seperately. But this should not happen. Yet it does.
    Something's amiss, and both spin and magnetism seem to be playing their roles in it.
    David is getting visual (of all the wavelengths we do not see) effects from "mere" locked magnetricity. Spin was likely added by Ed's setup being on bearings?
    • this one should do it!!
      northwind suggested infrared a while back...i tried an old cheapy scope but it was too blurry...i think it is time for a FLIR GF series cam ?...thanks mark...david...YouTube - infrared video
      • Originally posted by david lambright View Post
        hi...i did better this time...http://www.youtube.com/watch?v=6Pr2FFcb46E....also bruce, #2 is in the mail...i went ahead and paid the postage ive got the ups tracking #, i can tell you when to expect it...i wish i could be there at THE moment you see it!.....david
        Hi David,
        That is very good news! I am looking forward to it. You certainly did not have to pay the postage!! I will pay the postage to the next person that it is to be sent to.
        When can I expect it? Please PM me.
        Kind regards,
        Bruce
        • wit!
          i always do charge it both ways, just to make a good "flux path".....a small plastic compass works well...you will get it!...david
          • Computer error... bump!
            • Wilhelm Reich Orgone Draw Bucket
              David,
              Good job! Yes, they are visible.
              Seeing the tube directing energy from your PMH reminded me of the Wilhelm Reich Orgone Draw Bucket apparatus.
              Posted about this sometime ago:
              http://www.energeticforum.com/renewa...html#post36345
              You might find incorporating the draw bucket and your PMH together produce a more effects in some way.
              IndianaBoys
              • The fact that we are seeing a rainbow effect would indicate a dissasociation of light. Just as a prism does when white light strikes it. It seperates all the different light wave frequencies and causes all the different colors. Water is the only other variable. Is it real humid where you live?If not, then it must be using moisture from the atmosphere to cause this effect.Interesting that it would effect both gravity and light.This would seem to suggest that both are interconnected in some way. I will build one to experiment with when I get the time.Thanks! Good Luck. stealth
                • David,
                  your last video, i could definitely see it, it looked to me almost like dry ice was pouring out of the end of the tube and downwards.....but it wasnt as thick as dry ice would be..a lot more.....wispy.
                  i wonder how jet is coming along?
                    i am glad you saw it!...i believe too much input power is over kill... ...david
                    David, I am not sure about that. I have a giant PMH built from a 2" diameter steel rod and it has two coils on it each about 1000 turns of wire. I also had the impression that too much current might be an overkill, but then I tried to lock this huge and heavy U shaped piece on a steel bar and let it hang on its own weight. I used a small 9v battery for this. It would lock and hold its own weight, but I can easily break the lock. This 9v battery can supply about 300mA of peak current. Then I tried the same using a big 12v battery with way higher peak currents and I also achieved a lock, but this lock was way stronger. If the previous lock could barely hold the U shape piece hanging, then wing a 12v battery I had to put considerable force to break the lock. So I guess the bigger the energizing current the better. Will post picture tomorrow
                    Jetijs
                      Jetijs
                      i will try on a smaller scale,2" is HUGE...you are correct, though i wonder about limits...is there a point where lock will not get stronger?...my largest dia.PMH is a mere 5/8 "...like you said, different voltages and different amperage DO create a stronger lock...i believe there is a saturation point..super cav suggested a leyden jar spark to energize the pmh....i have not tried that yet...i did try a peizo to energize a small pmh but no success yet....any thing is possible...we just have to build it....i built and energized a small device...40mm dia.....i will post a video....jet you have been working so hard on this project ....my thanks goes out to you......david
                        Dave - I get it that the level of 'lock' is not critical to the 'effect'. I guess it's just a question of experimenting to see which is the more effective. I'm also surprised to see how much work Jet has done on this. Amazing stuff Jet. And Dave, I've also been working very hard here.
                        • Originally posted by Stealth View Post
                          Hi Stealth. Not sure of your point here. Water is hardly the cause of gravity as gravity is a understood as a universal field and there is no known saturation of space. I think that the effect is unrelated to atmospheric conditions as Dave is not able to duplicate the Schlieren effect.
                          • wit...i know you have ...you will get this!...david
                              • Hi all
                                Today I tried to put the segments together in reverse, like this:
                                I had to magnetize it, remove the coil and only then put it on the rotating platform, because the coil would be in the way otherwise. I still don't see anything, but the sensations are about the same. Then I thought that maybe the aluminum rim of the fan has some effect on this, so I removed the rim:
                                Still nothing. Will also remove the plastic blades.
                                No luck yet, but we will get there eventually.
