gravity waves found
  • Device to assist in seeing subtle energy
    These goggles appear to assist in seeing this energy:
    PranaView Aura Goggles
    PranaView Aura Goggle [pv-1] - $200.00 : PranaView, Advanced Aura Goggles
    See the Human Aura
    High performance goggle-style multi-element glass and plastic aura filter. Excludes all but near infrared and near ultraviolet light, forming an extreme purple. This activates the human eye and brain to reveal what we call the Human Aura.
    Personally investigate the mysterious sources of life. Conduct your own studies probing the connections between thought and matter. Repeat Dr. Walter Kilner's famous Dicyanin experiments. See for yourself what mystics and artists have reported about the aura since the dawn of time.
    Here is a link to an Instruction Booklet about the goggles:
    Here is a first revision of the "PranaView" Aura Goggle Instruction Booklet 01 of May, 2010. This will ultimately be included as a physical booklet with each aura goggle, but for the moment here it is as a .pdf for review & comment.
    http://primummobile.org/tiki-downloa....php?fileId=24
    IndianaBoys
    • last post on this thread....
      Goggles?? BEAM ME UP SCOTTY..... There is no ....
      • Originally posted by thekubiaks View Post
        We mock that which we do not understand
        • Thanks everyone .
          Interesting, looks like a good way to learn to see aura. Some comment:
          - Royal rife has a way to make ultraviolet and infrared to become visible, it is nice if they utilize it
          - excluding color band may prevent us from seeing the aura color?
          If my aura filter method is correct, I guess comparing original to converted can also be used to learn to see aura.
          • Did a quick search and found these aura goggles for about $25.
            Aura Glasses - You Can See Auras
            Never used or owned any of them so I can't comment if they work.
            I was wondering...if at the center of the PMH someone could place some sort of an orgone collector, made out of resin, crystals and metal shavings, I think they call them Orgonite HHG on youtube.
            I also read that aluminum and newspaper layered would also work. Make a round (40 or more?) layered aluminum foil and newspaper sandwich, the same diameter as the plastic cutting board and place it in the center of the PMH and see if a stronger, vortex could be seen.
            • Originally posted by david lambright View Post
              a little lower, at ground level...i know the photo is grainy, but the smear is there...david...yes to the block in the center of the photo..."under" the block, a little left, at ground level....i wish i could get a better image or enhance this photo...thanks
              Is it the octopus like shadow?
              • Here, ive done this to try help pinpoint the exact location.
                Adie
                Always thinking outside the box!
                ASUS M4A87TD motherboard
                AMD Phenom II x6 Turbo Core 2.8/3.3 Ghz Overclocked to 3.5 Ghz CPU
                RIPJAW 4GB 1600Mhz DDR3 Memory
                Gforce 9800GT 1GB Graphics
                Windows7 64bit OS
                20" LG LCD 1680x1050 Monitor
                • hey Been reading alot about gravity
                  Hey new here
                  Been looking around the internet and I think this video Kinda explains what your talking about
                  take a watch
                  YouTube - Hutchison demonstrates Zero Point Energy
                  • Just testing to see if we're up. Am back but not sure if we can connect now as the international cable link is down. Here's hoping.
                    OK ITS WORKING.
                    • Here's the FULL CIRCLE 6,12,24 Progression. Doubles at each new level. This is significant for many reasons and on on many levels. (Literally and figuratively. LOL) I'll get back here.
                      • You're back then Rosie... now do try to behave yourself!
                        • Originally posted by Farrah Day View Post
                          LOL HI FARRAH. Indeed.
                          Still doing battle with sundry glitches and whatnots. But there's nothing so sweet as freedom of expression. Just need to structure in some constraints and modifications. LOL. LOTS TO DO FARRAH. But I'm getting there.
                          • Originally posted by witsend View Post
                            This won't pass Sesamy Street comprehension levels.
                            I see a central one circle. Then 6 surrounding it. Then 12 surrounding that. My kindergarten logic says the next will be 18? From 2nd to 3rd level doubled because the distance from the center also did.
                            I am be looking at this wrong...
                            • Originally posted by Cloxxki View Post
                              No Cloxxki. Next level is 24 next level is 48. We've done it. Didn't bother to show it though. What I'm trying to point to is the symmetry. Blows me away. I need it for my field model. Never knew it was available from NATURE. I'm still waiting to hear from that math boffin. I'm sure it's well known. But it's just so NEAT.
                              Also interesting. Number those circles 1 - 3, 1 being in the centre. Second circle same size therefore 6. NOW. You get a perfect circle on the 3rd level with six provided their circumference is precisely 3 x bigger than 1 and 2. Another blow away correspondence. My own feeling is that it's possible to work out the circumference without using pi. But I'm working on it. LOL. It's more than a little presumptuous considering I can barely count let alone do arithmatic. But. There you go. LOL
                              BTW - the relevance to the field model is that I believe it's best expression is in fractals. So I'm trying to find such natural symmetries so that we can 'use' the shapes to better explain the concepts. It's our opinon (Donovan and me) that fractals are the best way to explain the particle model.
                              EDIT. SORRY. I'm dealing with half circles. The actual number is 2 x 2. My complication comes in because we also have to 'halve' the force. The point being that each of the circles is meant to represent a dipole. Therefore one half of each circle opposes the other. One half of each field opposes the other. But I'M WAY OFF TOPIC. Sorry for that.
                              • Cloxxki - this may explain what I mean.
