Would PMH do anything to smoke? A lot of smoke would reveal laser direction easier.
gravity waves found
Originally posted by sucahyo View PostWould PMH do anything to smoke? A lot of smoke would reveal laser direction easier.
What about putting the rig near a cloud chamber?
If by some chance it is able to cause curvature in space-time on some level, then we may be able to see some particle tracks as they're affected by the curvature. It would be strange if the tracks actually curved but I think it would be an interesting to test to do. Who knows what we may see"Amy Pond, there is something you need to understand, and someday your life may depend on it: I am definitely a madman with a box." ~The Doctor
hi all,
in an attempt to clarify wether what is apparently being seen is real or merely an artifact of the camera or video codec etc....
make a mock up of the PMH....using say...cardboard toilet rolls cut in half....held together with the same cable ties or tape etc...
place them side by side...film the real PMH so as the "glimmer" is visible...then simply pan over a little to the mock up......and compare
hope this helps
problems...
i just wish bruce would come back and let us know what he has found out...i am building two devices right now, one to send to matt and jetijs and a larger model for my own tests...the device needs to tested by someone else....i will take this to a university where there can be better photographs and video made, and much better testing than i can do...i will try to video the devices before i energize them, as well as after
...this device does some things that are not easily explained...this has been overlooked or dismissed by main stream science....if it was easy, it would have been "discovered" long ago...many scientists have studied this type of thing, the similarities to others work tells us this...i would like to see this open doors to what we do not yet understand...but moving too fast may hinder rather than help...like i said before, i do not have much money, but i will invest all of my resources that i am able to, to further our understanding of what is going on with this device...please be patient...i thank everyone for their help, i could not have got this far without help....and many thanks to ENERGETIC FORUM for letting me post here....sorry if i do not get back to everyone with their suggestions and testing methods....i am trying to do as much i can by myself, and i am driving my girl crazy with all of this...so please be patient, OK....david
Patience
Originally posted by david lambright View Posti just wish bruce would come back and let us know what he has found out...i am building two devices right now, one to send to matt and jetijs and a larger model for my own tests...the device needs to tested by someone else....i will take this to a university where there can be better photographs and video made, and much better testing than i can do...i will try to video the devices before i energize them, as well as after
We will be patient David. I feel for you. I did see Bruce sign in twice over on Overunity Forum but he has not posted anything. Does not make sense to me for someone to accept a device from someone and then just not get back to them. We do look forward for all the next tests and results. Thank you for sharing.
TruthBeKnown
Originally posted by CatLady View PostWe will be patient David. I feel for you. I did see Bruce sign in twice over on Overunity Forum but he has not posted anything. Does not make sense to me for someone to accept a device from someone and then just not get back to them. We do look forward for all the next tests and results. Thank you for sharing.
TruthBeKnown
hope this helps
But if CatLady gets a rig to test, I will do this with my mock-up and the rig she gets."Amy Pond, there is something you need to understand, and someday your life may depend on it: I am definitely a madman with a box." ~The Doctor
levity?
the force that pushes heat up, or rather away from the center of mass was coined "levity", opposite of gravity....i think i said that right?.....any fluid movement causes distortion...when water moves, when air moves, although not as visible...differing pressures or density cause molecular movement in fluids...but all matter can be fluid...EM radiation can propagate in a vacuum, i think thats right.....so far......ill be back later today.........david
Hi David, hope all is well with you.
I just forgot to mention that I tried to magnetize my 3 laser cut wheels and put them on a rotating platform and get it to rotate up to 3000RPM. Did not see anything, but sensitives claimed they see all the room filled with wavelike light distortions emanating from the device. I wont rest till I see this with my own eyes. I am trying to get some tool steel now to cut the same wheel from that material. This will enable me to make strong magnetic poles on each of the segments, like on the wheel at Coral castle.
Thank you all
JetijsIt's better to wear off by working than to rust by doing nothing.
Originally posted by david lambright View Postthe force that pushes heat up, or rather away from the center of mass was coined "levity", opposite of gravity....i think i said that right?.....any fluid movement causes distortion...when water moves, when air moves, although not as visible...differing pressures or density cause molecular movement in fluids...but all matter can be fluid...EM radiation can propagate in a vacuum, i think thats right.....so far......ill be back later today.........david
However, as that link shows, it can also mean "a lightness in weight". Of course, this can also refer to "weighty matters" like serious legal concerns. For example: "The Lawyer brought a bit of levity to the case when he called Krusty the Clown to the stand"
In most scientific circles, the opposite of gravity is called antigravity and 'Levitation' is the act of applying a force in opposition to gravity, like the Maglev transports.
As far as fluids go, it looks as though you have a good handle on that"Amy Pond, there is something you need to understand, and someday your life may depend on it: I am definitely a madman with a box." ~The Doctor
Thank you all
Jetijs
Perhaps you could get the sensitives to do an experiment to find out. Maybe place the device under one of two boxes and see if they can tell which has the waves. If they can't, then we can deduce that either the waves are absorbed or the sensitives are not able to detect them when they are covered up. But I do think it would be a very good test, especially with different materials.
