gravity waves found
  • Originally posted by teslaproject View Post
    Cloxxki
    No, I can tell you with certainty that once the PMH is 'locked' and field is in motion, you CANNOT up the ante and try rev the field. You don't have to take my word for it but do some research on the simpler Leedskalnin PMH or build your own. You just have to understand the physics of it and after sitting down for some while, much of the mysticism flies away. Look at it like a electromagnet. I assume you know about permeability, inductance and saturation. If this is the case you will then realise that the PMH (in any shape or form) has it's limits and once 'energised' (or saturated) cannot be powered any higher. These are simple facts.
    TP
    Thanks for pointing the way TP. I have a long back start in physics, but trying to catch up.
    From what you say (and will blindly trust until I've been educated better), greater effects will only be possible with an updated design of different parameters your listed. I'll wrestle with that idea for a while. Thanks again, J.
    • when you had the camera in the over head view with the quartz, i "think" i could see what you were talking about, however, it might have been the spinning pipes sections playing tricks on my eyes....
      I agree, the spinning pipes playing tricks on my eyes is the only effect i have seen so far from my rig and this effect should be eliminated for proper study.
      What I wonder now. David hasn't had to re-energize his device for several days he says. Would there be a way to energize it to a greater degree, or is there only so much a locking magnet can take? Like a maximum capicity? If the device could handle higher current, it migh give off greater visual effect?
      I agree with teslaprojects comments because there will be a saturation point for the givin thickness of metal in the device. However i would like to add that in most of the devices i have seen the magnetic current limit is usually a factor of how much surface area you have in contact between your pieces of metal. Davids curved pipes offer a very small contact surface area so there will be a small limit of this magnetic current. My ring has the surfaces sanded flat through the thickness so my limit should be a bit higher. Jetijs bent bar design has much more contact surface area so he should have a much higher limit. Of course the metal thickness plays a role too however i feel most peoples designs dont offer enough contact area to fully saturate the thickness of their metal. And getting absolutely perfect contact is very difficult without a machine shop. And of course if you design a bad charging coil or use to low of a power source you could be under charging it, but i dont think that has been the issue here.
      • optics
        this wave form mimics every wave form.it must reflect, refract, focus etc....cody try a mirror , a concave mirror and a flash light reflector[parabola] ....spin your rig ...hold mirrors near rig..if you imagine yourself directing light...when you feel a push away...stay there, the push should stronger...tricky eyes is what i noticed first....try the mirror.......
        • too twitchy
          Originally posted by sturgeon View Post
          There is something strange about the way the rock is moving from 4.50 in this video;
          YouTube - potatoheadist's Channel
          As David is saying, it feels as if it has given up its mass, the rock looks as if it has very little mass. Too twitchy for something that heavy surely?
          s.
          WAY too twitchy!....videos are uploading now...david
            David, this implies that with a big lense above your device, you might create a focal point of strong anti-gravity. If so, G might become negative.
            A more simplistic approach : if 10deg off center is now a hot "ring" if you will for the effect, a gravity wave reflective cone, angled in 5deg or so, or indeed even parabolically so, could concentrate the effect nicely. A perpetual rocket launcher?
            • i wonder....
              what kind of effects will we get if we spin an energized rig on a different axis??
                Or you could use a magnifier to study the focusing of this wave. There are quite large ones and suitable for this setup. Here's one kind...
                Lighted Magnifier - Lighted Hands Free Full Page Magnifier
                Should be interesting to hold an object with a spring weight measure at the focal length of this lens.
                • i like the christmas ball...like "total internal reflection"...good thoughts!!..i am looking forward to your expirements!....david.......my newest prediction..able to store gravity and magnetisim on a chip ...just like light!...i do hope that medical imageing will be affected by this technology.........david
                  • cloxxki,...never believe you come across any thing other than brilliant!...when i was experimenting with a single junction ring, i did try different metal foils in the junction...with good results...an increase in effects?..when i was dressed in full protective anti zinc gear w/ approved respirator,i carefully sanded the pipe at contact points....some down to steel some not....not sure if this will help......david....also try a piezoelectric spark to pre energize your rig.......
                    • Has anyone thought a little more about other possibilities with this device such as radios? Leedskalnin had a bunch of radios and odd radio parts hanging on a wall in his living quarters. Why? What did he use them for? Another well known is the tripod with a mysterious box on the top of it. If I remember correctly, it was believed he had a long cable or wire coming from this box atop the tripod and had wound a few loops of the same cable around the object(rock?) he was moving.
                      • David's latest video:
                        YouTube - FILE0028.MOV
                        Sunlight reflected from a CD onto the device and surroundings. The smart folks here may share interesting findings. I was intrigued by 5m03, not sure how to see that.
                        • Apologies for yet another brainfart.
                          Imagine steel coil spring, nice and heavy, bend around to form a torus/donut shape. It might even be laid out along the latest vortex math teachings of Randy Powell. Chop this up, and energize to lock together. Current flow might be minimally effected, due to helical path and smooth transitions. Furthermore the coil shape should be ideal to take up stretch for the magnetic lock. Or does a harsh stretch work better?
                          • What!!!!
                            someone try this....get a small magnet and hold it near your computer screen of my generator turning......please reply.......david
                              Are your saying that your video can affect magnets that are near the screen. I'm as open as you get to these type of experiments but this one is too far out . BUUt I did do it and found no effects.... .
                              David with each video it's obvious the effect you are speaking of is either hard to capture or not capturable with a camera because so far I looked really hard but nothing out of the usual can be seen.
                              • i knew i was crazy....any body need a used ED GENERATOR??...lol........david.......free?...
