gravity waves found
  • good night everyone... Do you have a moment
    Hi Everybody, Can you help me out and take a look at a blog site that I am working on. It is to do with Pulse motors and magnetic coils, Bedini Motors, and ideas on making systems work better. If you could take a moment and link to my site and comment I would greatly appreciate your input.
    PULSE MOTOR, FREE ENERGY & OVER UNITY
    Thank you all and take care.
    Please comment
    • Originally posted by argonian1 View Post
      are you serious with this? lol
      imagine a plexi glass tube filled with air and a balloon, which is free to move inside the tube. the balloon is filled with helium and the glass tube is turned very fast around its own axis. the balloon will obviously turn inwards towards the center of rotation and not outwards, because helium is lighter than air and the centrifugal force pulls the heavier molecules outwards.
      same stuff is going on with candle flames. they are lighter than air (candles' flames burn away from earth (center of gravity)) and when spun the flames turn towards the center.
      gravity waves, seriously?
      yes, i am totally serious.......david.....gravitational anomalies by the bucketful......would you like me to send you an oxide core device to test yourself???.....let me know....david
      • Here is a way of taking the Earth's Magnetic Pulse, which one can in principle resolve deflections as small as one ten-millionth of a degree. This device can test both the horizontal and vertical components of magnetism.
        I think one of the factors which has an influence on gravity is the vertical component of magnetism. However, the attraction it exerts on a body is, with small variations, the same as that on any other body. Thus, it is that the speed of fall in a vacuum is constant. However, this attraction is not due to mass, it is caused by the magnetism with which the whole body is endowed.
        This will allow us to test small variations in both the vertical and horizontal components, which the PMH may influence just like a magnetic storm high in the ionosphere, with a device which employs one of the most sensitive instruments in science at a reasonable cost.
        GB
        • Just a quick note to say that I uploaded MP4 vids instead of the 3G2's and now the audio works. I don't know why You-tube stopped supporting the 3G2's but there 'ya go
          @David,
          I may want one of those oxide rings after all - I dug some more and I don't have the aluminum tubing nor can I find the Developer (which is some type of ferrous compound that I cannot recall now) but I guess it got used or tossed.
          • Hi Harvey,
            Did you sand the surfaces where the pipes make physical contact? That's assuming it was necessary with your material. I recall David did this with his.
            -Steve
            http://rimstar.org http://wsminfo.org
            • harvey,
              nice work, looks really neat.
              can you take a digital still from above while its spinning to see if you also get the elongation & contraction in the image...and then..take a still of a rotating piece of card with some curves drawn on..to see if you get the same....this will prove once and for all what is going on.
              • Hi Jetijs
                fantastic catalogue of fotos thank's
                At all
                For myself i go on to test with pmh in ice and to try to understand what is going on here.
                I have made some different config of pmh. The last and small one are made with a shakles from which i remove the axel, They are cheap and work very well.
                I make only one coil of 100 turns 0.3 mm copper wire(wound in 2 minutes) and it works very well. from 4.5 to 24 volts.
                I tried different basis config from bar to tubes to ring to washers etc.. everything works fine.
                pix 2 and 3 show a config with a basis square and the result once iced. Very strong assymetry
                The assymetry is different depending of the orientation of the pmh poles and the earth magnetic orientation. Seems to have a major importance.
                For instance all my last test are made with the N pole of the pmh regarding to west. (that is to say that i have checked that the freezer do not disturb the earth orientation.
                If i put enough water in the container, i often remarked that a kind of ring appears in the ice, often in oval around the basis.
                In pix 4 and 5 , (same config as previous pix ) the red arrow show a part of this oval ring, and if i crack the ice i can see a real tunnel in the ice . Very weird. Can somebody explain it ?
                Last pix is a mini pmh on a washer basis , and a nice assymetry in the icing.
                Yep this pmh is very impressive
                Hope this helps
                good luck at all
                Laurent
                • Woopy,
                  Good work!
                  Not sure if you shield the container while it is freezing?
                  If not, suggest you wrap it with saran/plastic wrap to keep the wind off the water as it goes to freeze.
                  IndianaBoys
                  • Hi Indiana
                    thank's for input
                    but what do you mean by the freezing wind.
                    just for info i have 2 freezers and they are situated one regarding the other (opposite to each other) and the result are about the same if i freeze an experiment on one and than do the same on the other one. (so long i respect the earth orientation of course)
                    But effectively i would be very interested if you can explain some more to avoid basic error
                    Thank's
                    Laurent
                    • Hi all
                      some more pix of this afternoon test
                      i do not see any influence of air movement in my different freezer
                      and any
                      way my question is the same
                      what is this ring of air all arround the basis of the pmh
                      the 3 pix shows the evolution during the freezing process.
                      1 after 1 hour all is frozen apart one specific part (dark zone)
                      2 after 2 hours all is frozen and the dark zone is now elevated , (higher than the rest of the surface)
                      3 and you can see in pix 3 the circular tunel of air surrounding almost all the contour (see the red arrows)
                      please consider this as an important question as to solve the leedskalnin beautifull energy solution
                      thank's
                      good night at all
                      Laurent
                      • Very cool experiment woopy. Just for fun could you add more salt or sugar to the water and see if there's a difference.
                        • Originally posted by stevend View Post
                          Hi Harvey,
                          -Steve
                          rimstar.org - Solar/wind, composting, non-conventional energy/propulsion Wave Structure of Matter (WSM)
                          The pipe was relatively clean, but yes, I did clean the oxide off a bit anyway.
                            Hi Indiana
                            thank's for input
                            Thank's
                            Laurent
                            Woopy,
                            Just wanted to rule out the freezer fan blowing on your experiment and affecting your freezing patterns of water.
                            IndianaBoys
                            • Originally posted by rave154 View Post
                              harvey,
                              I'll see what I can do - but my other test with the mock-up did not show the contraction and expansion. I have a few different digital cameras I can try (phones and such).
                              I have another HDPE disc I will try also without the magnets inside also.
                              Thanx
                              • Various Vids
                                Hi Guys - I have a few more vids up.
                                YouTube - Lambright - 003
                                YouTube - Lambright - 004
                                YouTube - Lambright - 005
                                The last link is a play list of various colormodes - most of the vids in that list are between about 40 seconds and 2 minutes long but I did spend about 7 minutes on the first Sketch Mode vid. Originally I had intended to stitch all seven into a single vid but the playlist made that unnecessary.
                                Let me know if you guys spot anything that you would like me to focus on.
                                I am going to try and borrow my sons HD camera and see if there is any contractions or elongations present in a motion lock mode. Also, I still have my cardboard mock-up that I can do some comparisons with.
