oil removal solution already here
Not sure if this thread was posted here but it is related:
http://www.energeticforum.com/genera...ns-thread.html
The fungus solution works. Is slow but works and is probably best for beaches
and the microbes for the water - microbes / enzymes have been around for
years. I worked with a man that was a scientist that was in the field of
enzymes that can consume oil in oil spills. It is nothing new, it works and has
been neglected.
Here is your solution for quick removal of the oil in the gulf:
YouTube - Implosion Pump better than Schauberger can clean up oil spill in Gulf
I won't post anything else about it. If anyone has an "in" to be able to
implement this solution to remove the oil from the water. It is THE most
efficient pump in the world...private message me. I won't answer
people's questions to satisfy curiosity about it. The solution is here.
I took this video years ago. Here is the youtube description:
This pump brings things into the airstream from an auger moves down a pipe and carries it out the end and the whole time, nothing touches the sides. The contents do NOT spin around like the WHORL pipe of Schauberger. Contents separate by mass. If you dump in mud, you get a blob of damp dirt at the bottom with a blob of water at the top coming out the end. Then, you can put a separator to split the dirt from the water. It can be reversed to suck a swamp dry or whatever you want. It can suck the Gulf oil disaster contents and spit out water and oil separated. Kevin Costner's "solution" is a noble idea but this pump has made that obsolete by many years as it has been proven for many years. The dirty oil water can be pumped through this and you will have water separated from oil at the end, which can be separated easily. It is THE quickest solution as it can pump 350 tons of gravel, grain, etc... per hour for the cost of about $15 of diesel or electric. The pipe can float on water with rocks moving through it and the pipe still floats. Oil is not a problem. I will NOT answer any questions about this pipe. If someone has the ability to get to anyone that can implement a solution, then contact me. I'm not going to answer questions to satisfy people's curiosity about this technology. You can see my friend holding the end blasting fine silt out the end at 125 miles per hour at only about 5 psi covering a damaged low tide area which CANNOT be dug out because trucks, etc... simply cannot get out there. Birds, plant life, etc... area already back and to think it was a toxic dump before that. Trucks can't get in there but this fixed the problem. That area CANNOT be dug out at any price. In any case, here is your oil spill solution. Contact me if you have an "in" to implement this stuff and I'll make the connections. You can see the silt coming out the end out the MIDDLE of the pipe - it isn't touching the sides and look at the diameter of the pipe!
I'm only posting this now because it has become a necessity!
been neglected.
