my smith kanapadz replication
  • Originally posted by romerouk View Post
    Hi,
    This is my first post here.
    One thing I can tell you for sure, inverters bought at the store will not work or maybe just for few seconds and will end up in smoke.The waves created by the SG and the coils interfers with the electronics in a standard inverter. You can build yourself an inverter that will work fine here.All you need is a normal transformer with 2x12v output and use it in reverse. You can drive it easy with a flip-flop circuit.I built a powerful one by cutting the high voltage part in a MOT then I had to wind 14+14 turns.Works great driving it with TL494Cn and irf540. For more power add more transistors in parallel for every channel.Make sure the circuit is going to be shilded with some aluminium foil.
    Success!
    Welcome romeroUK
    Some here are interested to see if the kapagen can make Heat, to heat water or to heat a room?
    Is there an easy way for you to get a simple heater for testing?
    No fan or electronics that can burn out. This would also maybe show OU output compared to plugging into a wall.
    Keep up the good work!
    Regards, Mike R.
    • ground
      this maybe is a stupid question, but i have to ask before i do something wrong, because im not an expert, just want to be shore...
      the output HV side of the MOT, have one side grounded to the core... that side should stay connected to the core and then connected to the ground to?
      or what the side that should be connected to ground?
      i have other ideas in mind, but while i wait for parts will use the romerouk standard circuit to see what i can get...
      hugs and thank you all
      • Kapanadze patent WO 2008/103130
        Thanks vrand,
        I love the tittle of the patent WO 2008 / 103129, simple but clear :"Independent Energy Device"
        We want Energetic Independence Now !
        Not much details on the HOW it works, and the English is very bad, but WO patents are easy to obtain.
        He says in the patent WO 2008/103130: "in other words to produce more amount of energy than the received energy."
        and "This device can also feed the initial power supply."
        and in patent WO 2008 / 103129: "The present invention is a device both self sufficient (self-feeding) and producing ready to use electric energy"
        "A very small part of this electric energy generated is used by the device to feed itself"
        "It is possible to obtain energy in desired amounts of KW from the device."
        Haven't seen yet the WO 2008 / 103129 patent's diagram on this thread so I put it here, from rexresearch.com wo2008103130
        This post isn't intended to start a polemic on the OU or not OU subject, but just for reference.
        • Originally posted by juju View Post
          It goes through the core and then it´s soldered to the core strain which in turn goes through the core again into the ground. But there is a second ground too where the load is connected to (still, folks will come up with one sooner or later).
          • Here are the diagrams that I am using currently. Don't ask me about the MOT2 output as i am not going to talk about yet.
              im a little bit confused with your explanation,
              one of the end wires of the 2000V output coil (MOT), is grounded in the MOT CORE, so that wire must remain grounded in the MOT core... and from there goes true the TC CORE... and then comes back true the core and goes to the ground... thats correct?
              here is my coil... sound cable, my core is more thin, because i want to experiment with various ~types of cores inside it!!
              hugs
                I have been looking to find the diagram for you and no success at this time... but I found another one I have used some time ago and is much more simple and the components are easier to get.Transistors can be irf 530, buz11, irf3205, any of them but don't mix them. Use at least 2 transistors in parallel for each channel, more transistors = more power, it depends of the transformer you have too.Time to go to bed now for me...
                Hi romerouk, good to see you here also. I'm outside the 'matrix' here and thanks for that simple inverter. I am fascinated with what can be hooked up to the second MOT output. I guess I'm going to have to get with the program on this and try building one soon.
                What do you think of ossie callanan's schematic he says he got from JLNaudin where he has the diode directly across the output of the first (or only MOT in that diagram) MOT? Actually I guess there is a cap in series first but it still looks odd to me. From what I've seen of MO schematics they usually have the diode across the Cap or between one output lead of the MOT and the ground frame of the MOT.
                  hugs
                  Hmm,
                  maybe with different words
                  One end of the secondary of the MOT goes into the big coil´s core, THROUGH it to the other side and THERE gets soldered to the core strain of wires or whatever you have in there. And this strain is connected to ONE of the grounds.
                  • Hi juju
                    as you, i have made also a trip to Kapagen
                    Yes i have also the problem with the MOT secondary. And yes it is bound to the MOT core. You really have 2000 volts in the core !!
                    But if you see romero videos he can switch on and off with the uninsulated fingers , and he is still here and can help us to go forward thanks Romero hehe
                    but surely we are handling with very high voltage, i personnaly always make the experience with heavy caoutchouc shoes and plastic gloves. Never knows !!
                    good luck
                    Laurent
                      hi laurent, you r doing great!
                      the problem is not just the high voltage, but the high current... thats why i thinked twice before goind on this!
                      now is getting dark here... so i will try my coil tomorrow, i will use a special circuit with fuse and resistance to lower the consumption...
                      what about your results? consumption/output ??
                      one doubt, you have a fuse in the output high voltage coil?
                      hugs
                      EDIT: sorry my english xenomorph, i should use more the translator, my first language is not english, im portuguese... i think im the only one here in the forum! LOL, hugs
                      • Juju, i think we can all put in a certain effort to overcome language barriers.
                        My first language is also not english, english just connects many peoples.
                        It helped me watching Romerouk´s videos to figure out the winding exactly.
                        Maybe just have a look at them again.
                        • Hi juju
                          i don't understand how you wound your kapagen coil. If you are on the romerouk design, or also Jl naudin coiling , i can be of help, but if you go on your own winding system i am not sure to be of any help.
                          my replication is strictly based on the romero indications. So i think that the results can be compared
                          I am on the very basic MOT to KAPAGEN and try to get the best of it. And after if this set up shows really promising results go ahead to finer technologies
                          all succes to you
                          good night
                          Laurent
                            Laurent my coil is almost a complete copy of yours and romerouk, is wounded the same way, same kind of wire... the difference is that my core is a little bit more thin, and have some more turns to compensate, i maked that so i can try different kind of cores that i allready add that mach this size. I putted a bit less turns in the thin windings, and just more 2 turns in the thicker windings.
                            the schematic is exactly the same, i just changed 2things in the design, if the results differ, i will se if it better, or worst... im shore in both ways there will be no much difference, just trying different aproaches! everybody should folow ther one ways, if you notice, the device that everybody got to replicate as nothing to do with the 2 devices allready seen working, the kapanadze and SR coil are much smaller that the "KAPAGEN", was also refered that both used cores inside that can be seen on the videos!
                            can you answer my questions? iff you can tell me whats the total resistance of your coil, from beggining to end that will be great also!
                            • hello
                              i will use the published circuit of JNaudin, with the steel plate down and grounded to transformer cause is the more efficient till now...
                              can i use 3 diodes in series (1N5408 1000Volts each?) the output of my MOT is 2150Volts AC, as i will be rectifyng to half dc, i will get 1000Volts is that correct? the diode in the diagram is correct? Can i also use the 2150AC 0.95uf MO cap??
                              how do i discharge that thing after operating? because the discharge of my fuji camera cap is very brut and is only 300V, i cant imagine this one! it does have some kind of resistor that was grounded to the iron box of the MO!
                              please just give-me some cleareance, and then i can go try to not fry myself!
                              hugs
                              • i hope that this helps alot of ppl
                                Uploaded with ImageShack.us
                                I got this from The Worldwide KAPAGEN successful replications
