my smith kanapadz replication
  • SR 193 SR193 : White HV Flyback Transformer
    Above image that TanTric is referring to below in quote.
    Originally posted by TanTric View Post
    vidbid,
    when you mention "that looks the the white HV Flyback Transformer on the lower platform of the SR193"
    where do you see that in the SR video? i just see 2 transformers, a small one visible, and a big one down the glass table!
    See post. SR193's finger is point directly at it.
    SR193 points to white HV Flyback Transformer on the lower platform of the SR193 device.
    The red arrow in the above image points to white Base wire to NPN Transistor of the Modulator Amplifier Module from the output of the Frequency Generator Module. Refer to the Alex Schematic for reference information.
    VIDBID
    • SR 193 SR193 : Lamp
      Originally posted by luno
      It's standard Russian bulb 220 v
      Thanks, Luno, for specifying the the type and voltage.
      VIDBID
      • http://www.energeticforum.com/renewa...sink-hole.html
        This is a relevant thread. Please pay particularly close attention to slide 7 when you get to it, though do not skip through any of the others, it is a progression of thought, and all parts are necessary in understanding.
        Slide 7 would be an advanced embodiment and could be accomplished after the fist embodiment is created and understood.
        • Originally posted by Armagdn03 View Post
          Thanks for posting that Armagdn03, I've taken all the posts and put it into a word document for easy reading and have a file with your name on it... lots of good stuff in there !
          Oddly enough I've been investigating similar ideas, although my knowledge is limited, I've been working toward a resonant feedback idea not completely unsimilar to an audio feeback disturbance using 2 coils. The ground capacitance seems almost simpler to initiate.
          Great work as usual !
          ________
          • Russian patent RU2141718
            Hi everyone,
            I found very interesting Russian patent RU2141718
            Thanks for that.
            Looks interesting.
            Partial English Translation via Google Translate
            VIDBID
            • Possible Design for to Power the Frequency Generator and HV Formation Module
              anyone can help?
              i reversed my step down transformer (I/P 220 50hz O/P 10V 1A) , and im feeding it with a variable wall adapter 3, 4.5, 6, 9, 12V ... the transformer is 10W, and it is consuming that, and maybe more at 12V it can reach 1.5/2Amps, depends on the load... but my output, that should be the same 10W is not solid... with a neon on the load it shows 110VAC, but with my 25 W (220VAC) Lamp, it only shows 45 V across it, lightning barely the filaments!
              i putted a diode to half way rectify, and measured the current with an analogic amp meter, and it shows 30miliAmps, but the DC voltage, is still 45VDC, should not be only half if compared with FULL AC?
              I should put 10VDC x 1A (10W), and get 220VAC at 45miliAmps (10W) onload! but fore shore im doing something wrong!
              the circuit below shows a pull-push circuit activated with 50Hz signal from timer circuit, but i cannot even put the push pull combination to work, it only works if i use just the one transistor (NPN), in standard setup... (timer output to base/ emiter to negative/ colector to primary / primary to positive)
              somebody can have an idea of what probably is wrong with it? please?
              EDIT: if i try to measure the output without load... my DMM get nuts! maybe wrong frequencys, but i used all the values exactly as the diagram!
              DC to AC Inverter by IC 555 and TIP41 TIP42
              This entry was posted on Saturday, July 19th, 2008 at 12:03 am and is filed under 555, inverter.
              This be basic AC inverter Circuit. Convenient for the initiator who have to is extremely fond of something experience. Because of use IC 555 highly popular, perform produce the frequency ,then enlarge with transistor NPN and PNP number TIP41 and TIP42 drive the coil transformer. Get by can pay Voltage output about 120V to 230V at frequency 50Hz . By have R4 perform control the frequency and should use. Voltage supply about 5V to 15V the detail sees in circuit picture sir.
              Good job. I think this is a design worth looking at.
              VIDBID
              • SR 193 / SR193 Video - Spoken English Translation with Commentary
                Youtube: SR 193 / SR193 Video - Spoken English Translation with Commentary
                00:05 I shall now demonstrate my replication of Kapanadze machine.
                00:20 I use central heating system for ground, because all pipes are grounded.
                00:35 Ground cable is TP5 twisted pair.
                00:40 All wires are twisted together and connected to the pipe.
                00:55 Ground wire goes into the center of device.
                00:58 This is output transformer.
                01:04 I will tell this right away, transformer has ferromagnetic core. I tell this because otherwise many people will start again building various resonant contours.
                01:20 I wanted to use battery for startup, but sadly its dead.
                01:27 Here are startup wires.
                01:33 Power source.
                01:36 Start.
                01:40 Now we have 20V in startup wires.
                01:54 With 20V I charge ~4700 microfarad capacitor.
                01:59 Capacitor will charge and I will use it for startup.
                02:04 Two buttons, right one for start, left on for stop.
                02:10 I messed up so stop does not work.
                02:13 Now I'll start the system.
                02:25 We see fan that is cooling two high power transistors.
                02:28 Here is our belowed spark gap.
                02:35 I connected 150W bulb.
                02:40 Cannot get more (yet).
                02:47 Now we can disconnect power source.
                02:59 I can short the wires to show that capacitor is now empty and unused.
                03:02 System still works.
                03:05 Look at spark gap.
                03:10 Switched off power source.
                03:17 I can touch the ground wire. No shock. Despite wishes of some Internet users (sarcastic).
                03:31 As I told you, device is not too complex.
                03:34 This transistor is used for (Translator: signal?) generation.
                03:37 Here is HV transformer.
                03:42 HV transformer makes HV and SG ignites.
                03:40 As you see SG is not powerful. SG does not need to be high power.
                03:56 Spark gap just stimulates the process that takes place in
                ferromagnetic core.
                04:04 After that all is connected, thereunder is transformer for 220V.
                04:10 Transformer is powered by output coil.
                04:15 Output coil also powers the bulb. (Translator: I think he means thru 220V transformer, not directly)
                04:20 Here we see 150W of power.
                04:25 Paper is burning.
                04:29 From output transformer power goes to 220V transformer below and closed loop is formed.
                04:36 We can say this is free energy.
                04:44 Cannot stop it right now, will short the wires, otherwise it will all burn. (Translator: I think he means because of smoldering bulb box)
                04:44 I'm stopping the system.
                05:00 Wires were not shorted.
                05:17 I'm shorting and discharging capacitor.
                05:22 It's all discharged and device is sopped for good.
                05:26 As you see bulb heats strongly.
                05:31 Let's unshort the wires.
                05:40 Trying to start, does not start.
                05:46 To start again we must use power source.
                05:51 Ok, it's all connected again.
                05:55 Power on.
                06:00 Voltage is 12V.
                06:04 Source is rated at only 1A.
                06:09 In theory you can use any small battery to start it.
                06:16 For start you must only charge the 4700 microfarad capacitor.
                06:28 Start.
                06:46 Will take off startup wires.
                06:52 OK, it burns very nicely.
                06:59 That's all, will fight the flames now.
                07:00 Bye.
                VIDBID
                • SR 193 SR193 : New Information
                  Hi everyone,
                  I joint here some information about Kapanadze Generator given by SR
                  Thanks to Luno
                  Good Job!
                  Google Translate Translation - Russian to English - Part 1 of 3
                  Postovete to the Administrator at Farum Neht Energy is immediately and trace
                  Uspeshnata th replication generator energo Available at Tariel Kapanadze
                  (Informatsiyata Mauger yes bde Prieta for izklyuchitelno important and osnovopolagascha for vsichki interesuvaschi CE and raboteschi on thematic)
                  There is literally paruchasov ago had a little experiment: I took 2 transformers 220 \ 12 ipodklyuchil such a way that would be the first step down from ~ 220 to ~ 12V, the authors raised up to ~ 12V ~ 220V, two transformers of equal power primerno20Vt. At the beginning of the second troy-pa (~ 220) to connect the heating the lamp at 220 15Vt.Zatem from the source of explosives began to apply the weak level (permanent napryazheniya2-3kV) at the beginning of the second transformer, which is connected to lamp (razryadypoluchilis such as weak as in the movie Tariel Kapanadze but etomzamechen interesting effect: increasing the brightness of the lamp flashes. TsitirovatNou-HauKapanadze we also revealed: the so-called Tesla transformer in his device is actually a well-described in this topic konvergatorom testatiki. with the aid "resonance" frequency setting up Kapanadze vozbuzhdeniyakonvergatora (ferromagnetic material in Mr. ѐ m). But he, like Melnichenko, does not know the physical nature of the phenomenon. resonance in the classical sense is not imeetnikakogo relation to the power of the circuit BTG. Actually osuschestvlyaetsyasoglasovanie traveling wave in konvergatore and exciting e ѐ pulses naobmotke. When you set up and there is a process of collecting energy . estab ѐ tsyavpechatlenie "resonance". GeneratorKapanadze as testatika legally be reproduced lyubymzhelayuschim. Their physical principle (gathering energy from the surrounding prostranstvav form a compound of the EM field) is given in this book 7 years ago and opened dlyasvobodnogo use. Here, in our topic, We also revealed for the first time ikonstruktsiyu konvergatora. In the book she was not given, now is the time. I think you can ask here [link] if it is really his akkaunt.No whether he chooses to tell us? As far as I know, Tariel Kapanadze izobrelsvo ѐ offspring in 2003 as though he was operating facility, but to this day ontak and was not able to promote his generator. I think he's already mnogonastradalsya with him. By the way video hit the internet quite by accident and do not wish Tariel, we could never find out about Mr. ѐ m. Note how vremeniproshlo from the first sample before the release of records 6 years old, Dear Forum Participants, I wish to state that principle and ustroystvaustanovki Tariel Kapanadze for me now is not a secret. And it nerozygrysh. I have this shined a lot of his time, it was hard just to filter the entire garbage chtovylivaetsya at such forums where the futility of the information reaches 98%, nokak says: there is still a ray of light in this realm
                  swamp (I joke about myself). I am deliberately not going to post information about the technical side iprintsipe of this setup that would not get information "free riders". But it is not going to hide and be silent. Those who "deserve" too early to come late, come to the principle. Under the "dignity" I understand the level of brain activity. I am ready to help people, those ktodeystvitelno able to think and understand the essence. I want to meet some "dresskod" access to information, that is under the "dress code" ponimaetsyauroven thinking. I want to say that I do not plan to profit from this knowledge, and even in myslyahne was I a man for whom wealth is knowledge, but not rotten money. Kakby this may sound pathetic, but true. Here are some of the misconceptions and nevernyenapravleniya: 1)
                  VIDBID
                    Part 2 of 3
                    Parametric resonance. I am always amused by the fact that the majority of the participants of the Forum actively obsuzhdaliparametrichesky resonance oscillating circuit. My attitude toward dannymobsuzhdeniyam skeptical, because not all that teaches physics is falsified. Moyarabochaya profession is directly related to engineering sciences, such kakelektrodinamika and Toe and I have some idea of the oscillatory circuit vkotorom no CE. Yes, I agree that physics is not perfect, but she still teaches Koech. Yes, the device Kapanadze have resonance, but it is not parametricheskiy.Vy remember about all kinds of resonances, and where they occur, may srazudogadaetes talking about. 2) electric arc, more discharge. Many simply fanaticism sobirayutklassicheskie transformers with arresters arc seeking in them the principle of rabotyustanovki Tariel Kapanadze is too confusing and even what! Yes, dugovoyrazryad important to install, but it plays quite a different role, he is not involved vkommutatsiyah. Those who collected these transformers, must have burned quite a few devices need to understand that they have collected is not something that Kapanadze, drugimislovami is just RF transformer with High Voltage Output, dannyytransformator good only for toys. 3) Many people think that can not be output frequency 50 Hz with a secondary obmotkitransformatora installation Tariel (hereafter UT), and this too is fundamentally wrong! I want to say that for the formation of sinusoids used moschnyebipolyarnye PNP transistors and NPNprovodimosti, each in its half-wave, and how it works with the transformer is not going to say. 4) Kacher and other Labuda, but an interesting toy, but it is only a toy, and Set Betting is no. Many forums are trying to stick feedback to UT-etotozhe wrong, there is no feedback and no need to reinvent the blogs lowercase ikadrovoy sweep them invented long ago and Tariel do not. 5) Output transformer UT hardly be called Tesla transformer, noobychny Philistine may think so. But the principles they are quite different. 6) In UT no nanosecond pulses and WASO has no relation to UT. I would say that 80% of the principle of the installation can be seen in a video installation of 100kW, which prevents us to understand? It is our understanding, rather mess of our knowledge, we kakroboty trying to compare our knowledge with what he saw, often silnozabluzhdaemsya. Tariel studied physics at school and thank God! We often than feel and assess the effect of climb for an explanation in the book. Submissions onashem world changed
                    and very fast, but for some reason it does not happen with physics, may here play badly effect of Edison? Take a look at history, most great discoveries were made not by learned men and ordinary people that the physics were not related. Do not run around like anybody, but if that someone is affected-proshuproscheniya. PS: Zabylskazat that one of the elements of this mosaic is in the video madsatbg If you knew how easy it ichuvstva that I feel simply breathtaking! Clip will be. As for Theophilus, his movie just a joke, without nichegoobschego with reality. We can say 50% Tesla transformer. But still they used slightly different guidelines than vtransformatore Tesla. Although one of the patents, Tesla is mentioned, but not vpatente Tesla transformer. All that said Kapanadze is true, then why nolyudi distort the meaning of spoken words. No. Everything is metered and is easily managed, delivered there may not be. Razryadkak times and encourages certain processes. No. I want to note that the "coils" while strain directly, without any converters, frequency of 50Hz. Lyuboepodklyuchenie load, even through dugune would do this, whether there is a resonance circuit. The video 100kW, main coils "I would call the bobbins (directly as vpatente Tariel) three, one nakazhduyu phase. As such, beat frequency was not there. Yes, like with the law of conservation of energy Sun ѐ in order. Hello. SR I understand that the role 2transformatorov performs coil? Please clarify what you mean. Hello velikimedo. Resonance oscillator circuit is not used. Hey people, you again somewhere in the cosmos has suffered. Look at what usloviyahsobran working model of the installation, there are nanoseconds, which resonances? Vsebukvalno done with an ax. " Throw your cleverness (oh sorry, education) far away and just think of the process: what motivates kgeneratsii electricity. Suppose there is some stuff that burns, NAAL it recovers quickly and again begins to burn, while vyrabatyvayateplo. Error that you are trying to associate your knowledge with printsipomraboty installation, and if not
                    data on the nature of this action in the brain, tosootvetstvenno brain tries to apply existing knowledge. The problem of man Lisa Marchenko is killed he is trying to complicate everything, not thinking about that actually Sun ѐ elementary and simple. Hello, madsatbg. This scheme has no relation to the generator Kapanadze. umm, yeah, but oshibsya. But should have regard to whether the court vashegoponimaniya managering sleeps kotoryi std done with two transformers? excuse me if I'm wrong again. with respect madsatbg can say what they have. Experience itself to some extent pushed me ksleduyuschemu step. A sense of confirming the basic laws of physics? Any schoolboy knows that the electromagnetic field sovershaetrabotu and in the transformer and generator, but there are conditions under which the field feels bad to do work, then take some action, what would it moglosover**** work. An example of this magnet has a field, but if razmestitkatushku to Mr. ѐ m, then we do not get EMF that would happen generation nuzhnopodvigat magnet. Do I need such elementary things to write about? The words "Sorry, Mr. SR does not endorse." perceived as sarcasm votnoshenii me. So please refrain from such language. Regarding water, you're right e ѐ everywhere is full, on different forums that rezultatogranichennosti thinking, and we can not avoid it. It's like in society: estuchenye is stevedores. Everyone chooses his own path in life, someone beer nb ѐ t idevok walks, and who is trying to change the world dealing with science iliprodvizheniem new ideas. Although they both need peace. There is a saying: You want to feed the poor - do not give him fish, dayemu bait. Only that will evaluate the results, who approached him independently. The essence of the experiment was to test the reaction of iron in the discharge of transformer VVimpulsom. The first transformer was necessary only to separate the food chain. With regard to industrial frequency, the device is Kapanadze delaetsyaelementarno and less expensive than using an inverter. However boleeprotsess formation 50Hz is one of the highlights of combining 2funktsii: Formation of a sinewave (not unipolar pulses, while imennosinusoidy), whose frequency can be easily controlled and more important function, which I will not mention. Naturally there are obstacles introduced by the secondary field, which inogdavliyaet the reading, part of this interference is eliminated obschegovyvoda grounding transformer. In appearance many people think that they are similar (I mean the first to demonstrate ustanovkuKapanadze). Actually these are two different devices
                    and in the ispolzuyutsyaraznye principles. I'm generally a bad imagine working principle ustroystvaDonalda Smitty. I gave very serious information, saying that the video 100kW installation vidno80% principle. More detailed information will not be, especially about the "barrels", who sees the barrel, and who then something else. this is not the barrel is more vsegokondensatory? Let us not wake up to play a guessing. Hello SR, happy to see you again on the forum Do not pay any attention to the attacks - "for a broken two unbeaten give" If mozhesch, answer to my "indirect" questions, like "solve" itself, but hochetsyabystree. 1. Can I do odnimrezonatorom or use the second to match the load (load kakchast QA)? 2. 50 Hz to obtain rezonansnymsposobom or modulation of the RF oscillation network? 3. A special inclusion - razgonrezonatora, then connect the load (the load of the resonator)? 4. Type-resonance "ringing" circuit? 1. No. There unused resonance oscillating circuit and the load is not chastyunego. 2. 50Gtsformiruetsya easy way to resonance irrelevant. Kolebatelnogokontura not there. 3 .-> 2 4 .-> 2 recommend vsemvybrosit from the head of the phrase "resonance oscillating circuit. Slovorezonans has a different meaning in the installation. And again, hello. I want to clarify a few points: 1) Kapanadze in the first free ѐ m video says the truth, the only egoponyatiya and your can diverge, HP: the same resonance. 2) Kapanadze rightly so, that brought spark to the "street" (outside the box), because if the discharge does not light up, then the focal succeed, so it throughout the film worried for a spark. 3) The apparatus used two effects, only in combination they give rezultat.Duga has a wide range, few of these are resonance frequencies for the "ferromagnetic", which is defined therein protsessy.Voznikaet field. But the field is "m ѐ rtvoe and work practices can not, therefore, connects the second process. In sum, these two processes and provide dlyapolucheniya excess energy of the ferromagnet, and from the air, this energy neberetsya. And another thing: the ferromagnet can be regarded as material where very mnogomelkih magnets, which meant Hausa aimed in different directions and not mogutsozdat
                    resulting field. The first process allows them to relax, vtoroypovernutsya so that all these tiny magnets that create a result poleprichem powerful. If you simply say, it creates a powerful magnet with vozmozhnostyuim control.
                    VIDBID
                      Part 3 of 3
                      Well, on the matter of classical physics. As for my film, who hochetvidet its falsification, he always sees. Such is the nature of man. Another would ask the forum if possible not rastaskivatinformatsiyu this forum on other forums. PS: I read here about the alleged message on my business plan about etogoustroystva, tell you straight - I do not need to. Electricity me free and make sense to eat from this plant, I nevizhu and it seems it is harmful due to its emissions for two days it worked and dvadnya I have a fever and headache. PS: Clip Much Easier removed. When it comes to installing Kapanadze, what I have already received - tsennyeznaniya. Once again, I want to say how brilliant Tariel. Until such inclusion katushekmozhet guess just genius. I do not pretend to have his device and sobirayus.Vozmozhno these data useful to me in the future but not now. relationship with Melnichenko, this is what he is talking about domains. domains and it estmagnitiki. priests in resonance with chastatoy of sparks, the domains are ready to perform druguyufunktsiyu, ie will turn where they are ordered, and orders them later peremennoemegnitnoe field with a current of 50 Hz. In principle, the frequency can be for example i400 Hz. "Harmful" installation is not in the radiation. Such devices are never used nesmogut, but you can try. Now esch ѐ early to etomgovorit. SR, tell me, but you can get the effect on the ferrite smaller - on the ring, rod, or W-shaped? Simply find a handset or glue e ѐ of the rings (you taksdelali?) Is difficult. Is there a minimum threshold voltage after kotorogopoyavlyaetsya effect? Here, I can not say anything to advise, except experiments. The threshold is not vnapryazhenii, and the ability to create an RF field, which stimulates the ferromagnet.
                      taka kazva sine 50 Hz
                      I want to note that the "coil" is removed the voltage on the line, without any converters, frequency of 50Hz. Any connection of the load, even through the arc is not allowed to do so, whether there is a resonance circuit. SOS_SOS: (Second chovek for Coit assuming CHE e upcoming or e vzproizvel Kapanadze generator) Here esch ѐ food for thought, it may be useless ... Thue simply draw a transistor, further already set up, each in a little and all I understood tend to star ѐ zdam, as always go spaceships. But I'll just say ѐ Sun. With all the overlooked and that especially evident in the 100kW video. This Tesla transformer! All rynulis to build it and dostovat with a CE, but use? None suggested that the Tesla transformer is to install Capa total order that would at minimum cost to obtain the maximum voltage! So necessary for the identified nnogo effect. Since none TVSe TDKSe or you do not pull as much as necessary in order to create the effect on the same 5 kW. And see for yourself what sparks need to achieve the power of one hundred kilowatts. Think about and figure out what they napruga that penetrates a distance? Second, because everywhere there is the title of "modulating" part. Part of that sets ѐ t 50 Hz. without this part anywhere. Third, modulate spark even drumming, it's more talk than allow CE. And esch ѐ we should not any diodes, Sun ѐ that goes with the Tesla transformer. Sun ѐ it and gave ѐ tsya more ...
                      Ahhh, here esch ѐ one most important thing! You do not put so ѐ m Id ѐ those comrades!
                      VIDBID
                      • SR 193 SR193 : New Information - Parametric Resonance
                        The word Parametric Resonance found in above translation.
                        References to Parametric Resonance:
                        Parametric oscillator - Wikipedia, the free encyclopedia
                        Nonlinear dynamics
                        YouTube Video: Example of Parametric Roll Resonance of a Ship in Rough Seas.
                        YouTube Video: Parametric Oscillator
                        VIDBID
                        • SR 193 SR193 : the Relays and the Start-up Caps
                          I watched this YouTube video which is partially on Design Rules - Closed Looping Systems a few hours ago and was thinking about it when it occurred to me why SR needed to short the start-up caps in order to shut down the SR unit.
                          It has to do with the relays. According to the video, closed loop systems have to be intelligent systems, meaning sensing voltage. If they don't, they can burn up the generator or the load. They need an internal control mechanism.
                          I am thinking that when the voltage output from the output coil reaches a certain high value, the unit senses this voltage and somehow causes the relay to trip, and the system cycles over to start running off the the start-up caps. The systems starts running off of the start-up caps again but then quickly switches over to run off the output coil and runs until the output voltage get to that certain high value again, and the relay trips again, and the process starts over again, cycling over and over again, until interrupted.
                          Approximate Process Steps (my theory)
                          1. [9v battery] ---> [start-up caps]
                          2. [start-up caps] --> voltage is low
                          3. [relay] --> relay not tripped yet
                          4. [output coil] --> outputs voltage
                          5. [relay] --> relay trips
                          5. [output coil] --> voltage starts to increase
                          6. [output coil] --> outputs voltage at high level
                          7 [relay] --> relay shuts off
                          8. [start-up caps] --> process cycles again at #2
                          VIDBID
                          • Sr 193 Sr193 : Elements
                            VIDBID
                            • Sr 193 / Sr193 : New Thread Exclusively For Sr 193 / Sr193 Device
                              I have started a new thread exclusively for discussion on the SR 193 Device. The thread is entitled SR 193 / SR193 - Study of the Device, Theories, Diagrams, Schematics & Experiments
                              VIDBID
                              • Russian Video
                                Interesting YouTube Video about Tesla/Kapanadze type-of-cirucit.
                                YouTube - Эксперимент (Эффект качера)
                                We need a Russian translation.
                                VIDBID
