seth suggested a new thread so i took the liberty, since there's a lot of guys interested in this device, and the concept is different from the kapanadze lets go to there discuss it and build it!
I was trying yesterday with MOT + SG only, the coil needs more turns so I've omitted I need to buy more wire.
The Ground connection on the MOT plate is highly needed because the HV seems to bring inside the MOT and this can burn at all.
My question is : Are you connected the MOT plate on the ground or a well only by putting the MOT on the Grass is sufficient?
The circuit is highly stable with ground connected on the plate. I searching for a better spark gap, my motor cycle Plug is very weak is heating so much and Bulb light is very weak'.
Bulb is a incandescent 120 Volts X 200 Watts. The MOT is 120 Volts @ 60Hz, I can not find it for 220 Volts operation is very bad because in my House 220 volts is avaible too.
this is my first post ever annywhere....from south africa.
i worship you all and wish to learn.......unfortunately i do not speak read or eat russian....
annyone have a english translation?????
Welcome!
Most of us here do not speak Russian either, try Google translate.
Hi there everyone. I'm from Ukraine, 15 years long studing Tesla's works yet. I was constructed many different devices including Kapagen, all they are not working...
So I don't know now should I drop all this **** away or to keep going on.?
i have a lot of trouble getting good matrial on what tesla did on energy generation. It seems to me that if the whole concept of the tesla coil is properly understood it will open up the way for sucsessfull replication of kapaladze.....
Was wondering though,,, is it possable that to different types of energy is generated, meaning, one: voltage: two current and the two just combined to produce usefull electricity???? or am i just a HUGE idiot?
Still, Rusian seems easier compared to physics..........
Oh,15 years ? Sad news ...
I think we should listen to people like Kapanadze.
Everywhere I see proof IT IS POSSIBLE
Keep going until you will see your back then slap a bit your ass so you can going faster but watch tornado
or liquefy air using the simplest way as Kapanadze found in some old article in internet which I can't find now
I don't know if this is relavent, but, it seems to me that the circuit by Alexander Meissner (1913) which has the abillitie to self oscilate at resonance of the l2 coil might be a great way to get to grips with what is happening in kapaladze and sr193 circuit
I ran into this circuit this afternoon, and I think it would be interesting to drive a Kapagen coil configuration using an exciter circuit. See here if you're interested:
Xeno has a point here.
This coil, has a very poor coupling factor (almost non-existent) and cannot affect main coil no matter how muh amperage is flown into it.
I think it isn't a coil - it is just a plastic support to hold the top plexiglass surface glued with hot glue. There is another identical one in another angle shot near the FLT circuit if you look carefully. The white and blue wires, which then become green and red, are the power feeding the circuit (white is + and blue is -, 12v). The pot on the circuit adjusts the driver frequency, which is what is important here (what frequency?) - but judging by the circuit origin, it wouldn't be difficult to sweep and find the sweet spot, even if it looks like he has modified it slightly.
I think Tariel, which has created is a current phase let's call it R (L1) and the other phase is the land
if this were another kind of energy, creis that could be measured with a multimeter?
both transistors as the coil so this is creating a current phase
