This is my version of a motor that reduce its current consumption on load. It is easy and do not require custom part for the motor. You can use available brushed dc motor. I use brushed dc motor in place of my stingo coil.
The circuit:
In this configuration, the motor behave the opposite of what it normally does. Input current will increase the faster the motor goes. At lower rpm it barely have power / torque, so I have to forcefully rotate it up to speed.
Youtube - Brushed motor as coil, slower = less torque...
Youtube - stingo with brushed dc as coil
If we add load in the radiant recovery part, the battery will see it as load in series and reduce the power transfered to the motor and reduce its speed. Raising the current by changing potentiometer allow motor to run faster.
However, there is side effect. The maximum current reduce in half, halfing the motor speed. To reach original speed, more voltage is needed.
The circuit:
