Hi Gyula
No i did not change any thing other than the coil number.
I enclose a pix where you see the magnet sandwitch arrangement.
the 2 disc magnet are glued on a soft steel plate. there is a N and S pole on each plate. And the upper and lower plate are inverted. So a N pole sees a S pole. The small square magnet on the upper disc is glued there because a further test with reed switch. The upper surface of this small magnet is N for info.
@ All
yes i wounded the 4 th coil, and i retuned everything more precisely, And now with 4 coils in serie (22.7 ohm and 8.1 mh) i can get 880 rpm with only 0.105 watts.
So in comparison with test 2 where one single coil needed 0.324 watt to spin the fan at 880 rpm, i need almost 67 % less power with the 4 coils in serie whowww !
For info i enclose the traces of the coil while pulsing and without pulsing. Very small difference indeed (remaind me of Ossie motor). It seems that the pulse is almost completely enclosed in the generative action.
Have you some idea of what is going on here ?
thanks
Laurent
@ All
thanks
Laurent
