yes its me
You dont have to worry about coil or magnets in this motor the underlying principal is what counts here and this will work with any pair of matched coils and any pair of matched magnets in any number of configurations or any number of pairs of matched magnets and coils.
i used a hot glue gun to stick my coils down if that helps ...makes it easy to slice them off and do it again if you get it wrong.
The magnet layout is one rotor all north pointing in and one all south creating an attraction in the center ...this is important further down the track.
I removed 6 of the original 12 coils in my motor but left the magnets at 12 because the proximity of the coils was causing induction in the following coil at the same time as the current one was firing which may not be a bad thing, though i did not ever refit them to see what it was doing after i took them out and had an understanding of what was going on in the motor.
The basis of this motor is effectively a centertap coil with one half removed and refittied the other way round this changes the direction of current flow in the half turned around so it can function as it did, this also most importantly changes the direction of induced flow in this coil which means that the 2 halves of the coil are now opposing each other in the induction or generator mode and thus they cancel each other out equally to nothing.
Since this induction is not activly fighting the incoming current ...induction or potential if you like being voltage ... the input current is free to flow longer since on switching of the input the circuit now grows around the battery instead of being captive between the 2 coils and so the end result is the voltage potential fighting against the input potential is halved thus the motor can go faster than it could in a standard configuration.
this is not OU...OU doesnt exist this is merely using sound scientific methods in a different configuration and effectively producing a better mouse trap.
There is more of course to this but until you clearly understand the effect of a magnet moving its flux field in the presence of a coil and what actually happens in the coil you wont grasp the finer details of what is going on in the flat coil scenario that is adding to the output.
i am somewhat limited for time these days i take over a coffee bar in a few days and am swamped with paperwork but i will login and help where ever i can and just in case you are still wondering yes i am Garry Stanley and there is still a pulse_motor_group out there but its pretty much dead.
Garry
Garry
