Originally posted by vidbid
Kapagen Theories, Replications, Winding Diagrams, Circuits & Schematics. KAPAGEN ONLY
Originally posted by tutanka View PostGood photos.. but you casn send me real informations ? IN /OUT ENERGY? Not number of ignited light bulb but REAL power wattage IN / power wattage OUT. Regards
But i can show you my 12V kapagen rep - im very pleased with how many bulbs its lighting. Dont know about ''free energy'' - will have to do some more tests
Do you have any results you wish to share?
YouTube - 12V-kapagen.flv
@ren
I agree with you, but look is possible use a rated fuse to proof. if is burned then the power input is higher or not?Your time is limited, so don't waste it living someone else's life. Don't be trapped by dogma — which is living with the results of other people's thinking. Don't let the noise of others' opinions drown out your own inner voice. And most important, have the courage to follow your heart and intuition. They somehow already know what you truly want to become. Everything else is secondary.
Steve Jobs. Apple CEO
And the semantics continue.
Being that the output devices are all in series and most of these replications are using resistance lamps, all we need is a high current shunt installed at the end of the line between the devices and the ground connection. Before powering the system, get a resistance reading of the entire string of lights and the shunt (it will be necessary to use lamps with elements; not lamps that ionize gas for conduction). Once the system is powered, use an oscilloscope to get a voltage and frequency reading across the shunt (measured on the end of the shunt closest to the lamps). Being that it's a series circuit, the voltage at the head of the shunt will have been divided down to a level the oscope should be able to handle. Once you have the voltage, you can calculate the current across the shunt which is the same current for the entire string of lamps. Once you have current, you can get your power out.
Now can we get back to the main topic?
my circuit is the same as J L Naudins circuit. But with the following exceptions:
a) 24/80/6 turn coil.
b) No MOT (or steel plate under it). No NST. No Mains. Just a 12V (7ah) battery powering a 25kv power supply. Im guessing its drawing about half an amp at 12V....6W...but maybe less. Any ideas on how i measure consumption....spark gap plays havoc with my multimetre
c) I use an iron rod which goes through the centre of my PVC (Naudin uses thick strands of wire)
see photos below....
Sorry about the poor quality of my video! I certainly do get shocks...look at 1.05 in the video. That packed quite a punch!Last edited by seth; 10-03-2010, 05:17 PM.
Originally posted by seth View Postmy circuit is the same as J L Naudins circuit. But with the following exceptions:
Sorry about the poor quality of my video! I certainly do get shocks...look at 1.05 in the video. That packed quite a punch!There is no important work, there are only a series of moments to demonstrate your mastery and impeccability. Quote from Almine
Kapagen : JLN v3.3 : PlasmaCloud Spark Gap
JLN is using different spark gap points. The one on the left looks like it is made of iron. The one on the right appears to be copper.
After about 15 seconds, the tip of iron point to the left of the plasma field appears to be starting to change color from heating.
Also, JLN notes that his input power input requirement has decreased to about 150 Watts in order to operate fourteen 150 Watt halogen bulbs.
VIDBID
Originally posted by ewizard View PostI like the power supply you have and I think people need to work toward that to power this type of setup but is it lighting much wattage in tungsten filament lighting or is it primarily being used on the CFL's I see in the pic? As we know it doesn't take much to light some CFL's since Joule thief circuits have been doing that quite well. Are you using the two grounds for this also?
Yes - 2 grounds. It doesnt work with only 1.
I tried first with my NST and got 3 filament bulbs well lit. Ill be doing some more NST work at some point, but for the moment i wanna try and keep at it with the 12V battery. I agree that without getting at least one 40 W bulb lit it looks like a fun experiment, but not much more. But im gonna get that 40W bulb lit by trying the following changes
a) Spark gap. I think JL Naudin is using carbon and copper. I want to try the same, and perhaps some other variations....maybe even a bit of quenching and cooling...well see.
b) Various ground locations and ground materials.....might even be worth trying a few buried coils.....again, well see.
Good luck everyone
Good luck everyone
Method for determinating Kapagen Power Input
@everybody
This gadget uses a 2100 volts X 1.1uf capacitor then:
Maybe hooking up a scope on the output WITH HV VOLTAGE CLIPS., is possible determinate the frequency.
J=VxVxC
J=2100x2100x0,0000011
J= 4,851 Watts / second
If the input can be adjusted at 50 hz for example:
Input = 242,55 Watts.
OK this is the worst scenario, because the cap need to be discharged totally and this is not possible by the GAP so I think Naudins measurements are correct this gadget is OU. Juju experiment shows a frequency near to be equal to 50 hertz because his FAN tried to spin well.Your time is limited, so don't waste it living someone else's life. Don't be trapped by dogma — which is living with the results of other people's thinking. Don't let the noise of others' opinions drown out your own inner voice. And most important, have the courage to follow your heart and intuition. They somehow already know what you truly want to become. Everything else is secondary.
VIDBID
