Kapagen Theories, Replications, Winding Diagrams, Circuits & Schematics. KAPAGEN ONLY
Kapagen : Smith : Tesla
Originally posted by baroutologos View PostI would not count on Don Smith theories if i were you.
They have been extensively tested by me, others and Russians and have been found a pile of BS.
There is not a speck of truth in what he says, not to mention one theory contradicts the other. Smart merchant/book seller he was...
VIDBID
Kapagen : Tesla : Disruptive Discharge Coil
Originally posted by SuperCaviTationIstic View PostI think it also has to do with the other coil Tesla showed in Figure 3 of that lecture. It states "......When both the parts are connected in series, this gives a ratio of conversion of about 1:2.7, and with the primaries in multiple, 1:5.4; but in operating with very rapidly alternating currents this ratio does not convey even an approximate idea of the ratio of the E.M.Fs. in the primary and secondary circuits.
I'm still trying to wrap my head around that idea.
Originally posted by SuperCaviTationIstic View Postin this one BOTH the primary and secondary are wound in 2 parts in opposite directions
Thank you, SuperCaviTationIstic!
VIDBID
Kapagen : Tesla : (L2-upper CW / Centertap / L2-lower CCW) with respect to L1
reference: Tesla patent #336,961, middle drawing of PDF page 1 of 4.
reference: Resonate Electrical Power System by Don L. Smith, PDF page 6 of 14.
VIDBID
Originally posted by vidbid View PostDoes that include the material he references of Tesla?
By quoting a distinguished experimenter and scientist that does not mean you make your points more valid.
Tesla never claimed he found out a method for OU even though strived for it. To gain an understanding of Tesla way of experimenting and thinking you must read at least the "The inventions, researchers and Writings of Nikola Tesla" by Thomas Commerford (that Don Smith quotes) and Colorado Spring Notes. Those are must.
Then you must experiment on your own based on basic concepts proposed by Tesla and then judge by yourself if the sayings of Don Smith are true or BS..
Originally posted by For my own personal reference.
Originally posted by SuperCaviTationIstic View PostYes Sir!
Once again, I must say it:
BUCKING MAGNETIC FIELDS
goes back to Tesla's coil shown in his 1892 lecture "EXPERIMENTS WITH ALTERNATE CURRENTS OF HIGH POTENTIAL AND HIGH FREQUENCY"
This lecture is the part of the Tesla book that Don Smith said to read, and where he got his ideas from.
Thanks for the reference on Tesla.
As far as I know, the idea to reverse coil winding directions and the purpose behind doing so comes from Tesla, according to Smith. Smith also discussed the concept in his 1996 Tesla Symposium videos. Start at 1996 Tesla Symposium, Video #1. I suggest the reader view all nineteen videos. He also referenced that concept in a Tesla patent #336,961, middle drawing of PDF page 1 of 4. You can see that he references this patent in this video: 1996 Tesla Symposium, Video #8.
Picture of Donald L. Smith, circa 2003.
In looking at EXPERIMENTS WITH ALTERNATE CURRENTS OF HIGH POTENTIAL AND HIGH FREQUENCY, I would like to cite the following by Tesla:
I have found it advantageous to reverse the usual position of the wires, and to wind, in these coils, the primaries on the top; this allowing the use of a much bigger primary, which, of course, reduces the danger of overheating and increases the output of the coil. I make the primary on each side at least one centimetre shorter than the secondary, to prevent the breaking through on the ends, which would surely occur unless the insulation on the top of the secondary be very thick, and this, of course, would be disadvantageous.
When the primary is made movable, which is necessary in some experiments, and many times convenient for the purposes of adjustment, I cover the secondary with wax, and turn it off in a lathe to a diameter slightly smaller than the inside of the primary coil. The latter I provide with a handle reaching out of the oil, which serves to shift it in any position along the secondary.
I will now venture to make, in regard to the general manipulation of induction coils, a few observations bearing upon points which have not been fully appreciated in earlier experiments with such coils, and are even now often overlooked.
The secondary of the coil possesses usually such a high self-induction that the current through the wire is inappreciable, and may be so even when the terminals are joined by a conductor of small resistance. If capacity is added to the terminals, the self-induction is counteracted, and a stronger current is made to flow through the secondary, though its terminals are insulated from each other. To one entirely unacquainted with the properties of alternating currents nothing will look more puzzling. This feature was illustrated in the experiment performed at the beginning with the top plates of wire gauze attached to the terminals and the rubber plate. When the plates of wire gauze were close together, and a small arc passed between them, the arc prevented a strong current from passing through the secondary, because it did away with the capacity on the terminals; when the rubber plate was inserted between, the capacity of the condenser formed counteracted the self-induction of the secondary, a stronger current passed now, the coil performed more work, and the discharge was by far more powerful.
See following reference: Resonate Electrical Power System by Don L. Smith, PDF page 6 of 14.
Smith's Energy (Short) Guide
Smith's Res. Guide
Smith's Res. Methods - This is a large file and takes about 30 seconds to load.
Tesla Patent Referenced by Smith - Smith states this is how to wind a coil for voltage with more amperage.
Donald L. Smith 1996 Tesla Symposium Part 1
Donald L. Smith 1996 Tesla Symposium Part 2
Donald L. Smith 1996 Tesla Symposium Part 3
Donald L. Smith 1996 Tesla Symposium Part 4
Donald L. Smith 1996 Tesla Symposium Part 5
Donald L. Smith 1996 Tesla Symposium Part 6
Donald L. Smith 1996 Tesla Symposium Part 7
Donald L. Smith 1996 Tesla Symposium Part 8
Donald L. Smith 1996 Tesla Symposium Part 9
Donald L. Smith 1996 Tesla Symposium Part 10
Donald L. Smith 1996 Tesla Symposium Part 11
Donald L. Smith 1996 Tesla Symposium Part 12
Donald L. Smith 1996 Tesla Symposium Part 13
Donald L. Smith 1996 Tesla Symposium Part 14
Donald L. Smith 1996 Tesla Symposium Part 15
Donald L. Smith 1996 Tesla Symposium Part 16
Donald L. Smith 1996 Tesla Symposium Part 17
Donald L. Smith 1996 Tesla Symposium Part 18
Donald L. Smith 1996 Tesla Symposium Part 19Originally posted by baroutologos View PostI would not count on Don Smith theories if i were you.
There is not a speck of truth in what he says, not to mention one theory contradicts the other. Smart merchant/book seller he was...Originally posted by vidbid View PostDoes that include the material he references of Tesla?
Originally posted by baroutologos View PostTesla was a genius and pioneer for his age. I read and experiment with delight from Tesla writings.
I have learned a lot from Smith. I consider him a great teacher and have a lot of respect for him.
VIDBID
Kapagen : Reference : Thomas Commerford Martin & Tesla's Colorado Springs Notes
The Inventions, Researches, and Writings of Nikola Tesla by Thomas Commerford Martin
VIDBID
Smith
Originally posted by boguslaw View PostAll true.Respect for Don Smith. It's sad he couldn't tell all and had to fake devices.My humble opinion...
VIDBID
JLN Update Testing With Luxmeter : KAPAGEN Power Output Measurements
Originally posted by Xenomorph View PostA simple luxmeter measurement comparison test series as suggested on overunity would wipe away all doubt or someone closing the loop.Originally posted by retrod View Post
VIDBID
finnaly some kind of evidence...
but yet, dont prove OU, this method of driving lamps is so efficient that will maybe make seem the brightness will be at full power, but not at is rated power.
i suggest JNaudin make the same test but compare the lux meter values of the load from the grid, with the luxmeter values drived only with the MOT with same input power, and then with the kapagen so we will see whats the difference between them.
and also if the SG/TC and grounds are doing some magic here,
i will only believe when he shows amp draw and voltage in the load, i hope, in a near future!
before he loops the system he must know what values of output are involded here, and the frequency also, so he can correct the frequency to 50Hz and then divide the energy needed to sustain the device from the energy in exess and send only that amount to the load!
i continue to believe that this luxmeter test is only a "mirage"... it only read brightness, not real power passing the lamp!
hope not...
