Originally posted by boguslaw
Kapagen Systems - 12v Input Only
Originally posted by vidbid View PostI did.I think you are better off with
but i think it was much more fun and educational to build one myself, for free, using wire, sewer pipe, and a couple of bolts i found in the boiler room, following the setup of Naudins kapagen. Much more A team
anyway...what can an inverter do that my kapagen cant??
and where's your kapagen??? show me a joule thief youve built and at least that would be a start!!!
Originally posted by seth View PostI spose i could have just bought an inverter...
Why don't you use a 12VDC deep-cycle battery and a 12VDC-input NST or a Flyback Transformer to power your Kapagen's output coil? You might have better results powering one incandescent lamp. According to J. L. Naudin's Kapagen Replication Page, Dragon was able to successfully power one incandescent lamp with his 120VAC-input NST. You could replicate his work and substitute a 12VDC-input NST instead of a 120VAC-input NST and probably get the same results.
However, if you are only going to power one incandescent lamp with your 12VDC-input Kapagen, you might as well obtain an inverter and power the three CFLs instead.
VIDBID
Originally posted by seth View PostSounds good to me mate! 8000 kv NST.....could be fireworks....
I ho, i ho, its off to work we go.......
Wow, 80000000v nst. That's some serious deep fried neonLast edited by ren; 06-29-2010, 11:23 PM."Once you've come to the conclusion that what what you know already is all you need to know, then you have a degree in disinterest." - John Dobson
i dont know about his kapagen setup...
but he allready powered his NST with a 12V battery in his toroid kind of setup!
i think there's no need for the inverter, because will take efficience, i have one that running without load will eat 0.5amps!
Originally posted by vidbid View PostWhy don't you use a 12VDC deep-cycle battery and a 12VDC-input NST or a Flyback Transformer to power your Kapagen's output coil? You might have better results powering one incandescent lamp. According to J. L. Naudin's Kapagen Replication Page, Dragon was able to successfully power one incandescent lamp with his 120VAC-input NST. You could replicate his work and substitute a 12VDC-input NST instead of a 120VAC-input NST and probably get the same results.
Light, I Am!
12VDC-Input Kapagen Or 12VDC-Input Inverter
Originally posted by TanTric View Posti think there's no need for the inverter, because will take efficience, i have one that running without load will eat 0.5amps!
VIDBID
this thread is for the guys that are working with the kapagen, but with 12V input only! and to discuss ther ideas and share the setups!
just like everyother thread! hugs
Originally posted by wrench76 View PostI have read all 22 posts, and I dont see any information here about this system.What is the point of this thread anyway?Light, I Am!
12VDC-Input Kapagen : Request for Substance
VIDBID
Fun stuff !
________Last edited by dragon; 01-19-2012, 04:24 AM.
Kapagen : Dragon Replication
Originally posted by dragon View PostThat actually worked quite well using a 70 watt inverter to power the NST, still only used 7-8 watts to drive the 40 watt bulb. It took a little more work to get it there but once it was dialed in did quite well. With a grid input, a variac and an adjustable spark gap, the tuning was quite easy in comparison. I like the low voltage input as it could be driven by a single solar panel....
Fun stuff !You did good!
VIDBID
@dragon so you were really using an inverter in the toroid setup?
@vidbid: romerouk as warn us that the HF/RF will probably kill the inverter, but he refered using the MOT!
so its safe to drive an NST or FLYBACK transformer, with an inverter near this setup?Light, I Am!
