anyone can help?
i reversed my step down transformer (I/P 220 50hz O/P 10V 1A) , and im feeding it with a variable wall adapter 3, 4.5, 6, 9, 12V ... the transformer is 10W, and it is consuming that, and maybe more at 12V it can reach 1.5/2Amps, depends on the load... but my output, that should be the same 10W is not solid... with a neon on the load it shows 110VAC, but with my 25 W (220VAC) Lamp, it only shows 45 V across it, lightning barely the filaments!
i putted a diode to half way rectify, and measured the current with an analogic amp meter, and it shows 30miliAmps, but the DC voltage, is still 45VDC, should not be only half if compared with FULL AC?
I should put 10VDC x 1A (10W), and get 220VAC at 45miliAmps (10W) onload! but fore shore im doing something wrong!
the circuit below shows a pull-push circuit activated with 50Hz signal from timer circuit, but i cannot even put the push pull combination to work, it only works if i use just the one transistor (NPN), in standard setup... (timer output to base/ emiter to negative/ colector to primary / primary to positive)
somebody can have an idea of what probably is wrong with it? please?
EDIT: if i try to measure the output without load... my DMM get nuts! maybe wrong frequencys, but i used all the values exactly as the diagram!
i also would like to know if anyone is aware of a variable frequency generator, from mhz range to khz range, simple and easy to build circuit!
hugs
DC to AC Inverter by IC 555 and TIP41 TIP42
This entry was posted on Saturday, July 19th, 2008 at 12:03 am and is filed under 555, inverter.
This be basic AC inverter Circuit. Convenient for the initiator who have to is extremely fond of something experience. Because of use IC 555 highly popular, perform produce the frequency ,then enlarge with transistor NPN and PNP number TIP41 and TIP42 drive the coil transformer. Get by can pay Voltage output about 120V to 230V at frequency 50Hz . By have R4 perform control the frequency and should use. Voltage supply about 5V to 15V the detail sees in circuit picture sir.
hugs
