SR 193 / SR193 - Study of the Device, Theories, Diagrams, Schematics & Experiments
  • Originally posted by Guntis View Post
    This was a Fake by some user Delamorto and team of some peoples, we think he wanna make a Provocation, anyway – he don't even a understand how this stuff works.
    just - bla, bla, bla...
    (when he release a first video lots of peoples send me link to its video from his side ask me about schematics and principle and they told that in next video all secret will be revieled and there are no more reason for keeping in secret, so wery foxy, sly strategy) but stupid.
    But what can i say about SR device then i believe in it about 80% because ferrite only disturb all scenario:
    you can take this for fundament:
    (this is the ground of this on what all are bouilding on)
    Static magnetics field or ionisation - called also as Dead Magnetic Field, but we can convert this field to meka a work (This Is The Point Where Need To Be Focused)
    That way it can be started from a 9volt battery easely to in final give out 5 killovatts (for example)
    Thank you, but how we create that static magnetic field?
    regards,
    scratchrobot
    • Originally posted by scratchrobot View Post
      regards,
      scratchrobot
      By ionisation, ozone field (this is the electrostatic field with magnetic properties and it has so many energy that is disordered) By converting it to magnetic field we get wery strong filed who can do work. Convering by harmonic vibrations.
        Interesting, now i get a better picture.
        Ozone field is in ferrite or between ferrite and coil?
        I did your experiment with coil on ferrite and pulse it, when i put magnet at coil it sings but with HV no more, with HV i create ozone field?
        You have already name for device
          No, i talking about Tariel's device for now (SR and Tariel has different Philosophy in constructing)
          A) in ferrite device are no ozone, but Ferrite as magnetic source.
          B) Tariel use ozone as magnetic source.
          ozone has formula O3 with field and magnetic properties – very weak magnetic properties but they are there (Nature) like our planet has ozone field who protect us from sun magnetic fields.
          Anyway, we have make this ozone field on specific coil
          Look here my example:
          Then this field are harmonised by another coil and resulting ION field are magnetic field and very strong magnetic field.
          you see, you newer get an Overunity device by powering up electricity like most peoples are doing, doing by don't knowing what to do (nothing personal) i just try to explain. so... you can make a device with COP more than 10 but you newer get an selfruning device, this is the same like powering up a light source by magnifier Glass where you put this light on loop, but when you disconnect light source, light will stop.
          we need power from outside – you need think on this very hard.
          But anyway, i will release this very soon – 21. of June
          • I know you will release soon, you are good person, i know
            You say we need power from outside, maybe you mean attract ions from air and conducting them to ground?
            For coil to create ozone you use wire with special insulation?
            The metal you use in coil is aluminum foil?
              ions are attracted by ionisation.
              this HV field are magnetised with vibrations and we get wery poverfull magnetic field "and this field are this outside power"
              i use aluminum alloy
              • are you sure about ozone ? I'm not convinced.
                • Not Up For Debate
                  Originally posted by mlurye View Post
                  It is fake
                  Whether the SR193 device is a fake or not, we don't care. It's not up for debate. When I set up this thread, I clearly stated in the first post that "In this thread, the assumption is the device functions and is not a hoax."
                  VIDBID
                    maybe. Because i`m not atomic physicist i guess that it is, but who knows
                    Maybe this helps, When device are runing after some hours, day - room smels with fresh forest air, like after thunderstorm – something like that, wery nice feeling and light for breath...
                    this is by ionisation process.
                      I think this is byproduct. Don Smith said also that it produce ozone.
                      I bet if you can do a little experiment placing a coil inside vacuum tube you will see it glowing.It works by high frequency and probably agitate air molecules around. That's my idea.
                      • Well hello there Mr. Guntis or should I say cosmo-lv?
                        I see the troll is back and is distracting people again. What hapened in these few moths? You promissed to make a small box with the device inside and make a video in a week, months have passed, where is your video? And don't post links to work others have done, show what you have done and prove that your wild theories are right, if you can't do that, don't distract others with your newly invented therms. This is just to caution other members of this forum to be aware of our friend here. You can see his other post on this topic:
                        my smith kanapadz replication
                        read them and you will see just how swallen his head is. I wouldn't trust him. Trolls never change and Messiah syndrome is incurable. If our friend thinks about deleting his "history" I have a backup, just for fun
                        Here you go:
                        This coil and setup is designed to Burn electrons, in that kind of setup all electrons are daing in Load.
                        The purpose of free energy is to make to electrons to Born and not to let to Die.
                        Lets look on one missinformation about ionisation for combustion engines.
                        The ionisation is not make sense - all sense are in High currents and these currents sinhronisation with ignition coil.
                        You say: "these both are not connected together!" yes they not, but the field where new electons are created is big and this field resonates with ignition coil and other electric parts - this is different resonanse.
                        If you not believe you can make test with spark gap and wire - if you play around with your car and HV transformer - you then MAYBE understand the fenomena of Borning electrons. More electrons Born then more the effect and more posibilities to make Free energy.
                        But if you burning these electrons in Load, then you connot reach the Low of physix.
                        i personaly dont need such of tests, i just see how its happening and i dont go deep to Esoteric things, but this is the way how its happening.
                        When Tesla makes he FE device for car, then he say: "Energy comes from air"
                        Now i can explain what he mean by words "Energy comes from air"
                        Only what you nead is little HV to make Born new electrons and therse and lots of electrons forming around the wires, the second thing is to activate these electrons...
                        Think about it. And good bye!
                        it not make sense.
                        i told, i help those who want to build it and want to work with this.
                        i'm not giving this for free!
                        i told before, i spend lot of years to find the right way! if you don't listen then this is your problem, but all what i can say - soner or later you get on this. and then you remember what i'm saying! You don't even a try to understend, think little bit - how this and how that can be. try to do something and not waiting for somebody who does it for you!
                        And last...
                        there are 3 things who driving FE Device - all those are importand, and without all 3 factors together - you connot get anything!
                        And last...
                        there are 3 things who driving FE Device - all those are important, and without all 3 factors together - you cannot get anything!
                        See Kapanadze videos, search, learn, try and experiment - i just want to put on different direction, while i see everybody going in deep hell with wrong information.
                        AND DON'T TAKE ENERGY DIRECTLY FROM THE COIL - Don smith is layer- bedini and bearden talking about Energy From The Vacuum - but all what they are doing is converting one type energy to other and burning Electrons!
                        I'm sick of this to see this misinformation and garbage who claims about free energy devices.
                        There only Two Guys who successful build it Kapanadze (Georgia) and SR (Russia) and many others who don't want popularity!
                        Free i mean not money!
                        i have sucessful replicated it - but this is not the thing with who i'm going to make popularity, i don't need that!
                        Please delete my profile somebody!
                        i'm in wrong place
                        vrand and what it gives to you? i better stay in your eyes as idiot, because if somebody don't understand me, then what i doing here?
                        keep listening Don Smith and others who showing NOTHING - but he showing and everybody fall on that!
                        This is the same thing as McDonnalds - ewrybody know that this is garbage and deadly for imun system, but keep eating and dont understand why he is sick.
                        This device not helps to make world better - no way, it only destroys the Monopolysts.
                        Wars are over the world and its only increasing, and war is not for oils but to push somebodys EGO on other nations WAR FOR NOTHING, WAR FOR EGO
                        Think what you want. This is your and other choice!
                        Thats way i'm not giving anything to those who don't have a head! and anly waiting for sometning - those who only can copy and paste schematics - i guess i know you
                        1. i don't showing a think and it newre happens Here!
                        2. i know what i'm saying - if you can bouild FE device by using ONLY Tesla patents, then good luck to you - but where are these supersmart guys like you who make no sense and showing only patents
                        This is the same wrong direction who goes nowhere - think, why it is so hard to make it?
                        And why that device kan make usual peoples like Tariel Kapanadze, who dont understand Electronics and Physics?
                        Originally Posted by tutanka View Post
                        Triac60, an italian developer, wrote on italian forum that spark is the key.. and I add .. spark is only one key. Important thing is method for absorb properly the energy released from process.. very important is understand what is radiant energy and as is propagated from process..
                        Yes it is the key - i don't know mutch about radiant energy - i just throw out this fact to learn what it is. (but at least this is not only key) but this is wery important)
                        The way i get to this secret i just plajing with hunderts of diferent types of coil setups, diferent types of sparkgaps, providing High currents throught transformer and then to sparkgap and other crazy things - i just doing lots of tons of experiments.
                        i sleep 3 hours in a day along last two months - i make wery hard work on that.
                        i konnot imagine the work of kapagen - i don't see here an selffeding oportunities.
                        Anyway, i have too much respect to Tariel Kapanadze to give for that crapy device a name of Tariel - caling it a Kapagen.!
                        Naudin has no Respect to him...!
                        Seems the key is always something different. How many keys are there? LOL
                        Sorry for the offtopic, but don't let him mess up also this topic.
                        I wont post anymore, I am here mostly at read only mode. Great forum. I have learned much in these past months. Thank you everyone for your work!
                        Jay
                        • Jay2008
                          Yes, you can call me Guntis or cosmoLV, Guntis is my real name - nice to meet you!
                          But i don't know about you very mutch, so i keep myself gentle and wish you luck
                          (all what i'm saying is true, sorry for that, that you not understand my explainings, but revealing it now is not in my plans, it be released as i told earlier on my Home Page: Umbrella
                          see countdown!
                          why we connot be more friendly? why peoples always try make conflicts and make a war?
                          smile
                            Jay2008
                            see countdown!
                            smile
                            Guntis,
                            Greetings! We can be more friendly when we change this world . Help me help you...
                              Jay2008
                              smile
                              I think we need more negative ions
                              The nature of the chemical bond and the structure of molecules and crystals
                                vidbid, if you would check what I was talking about, then you wouldn't start this debate.
                                P.S. It was in regards of Delamorto claim that he replicated the device and following second movie showing the trick with hidden wire.
                                Mike
