SR 193 / SR193 - Study of the Device, Theories, Diagrams, Schematics & Experiments
    I was reading a post by the admin of Next Energy forum (reportedly SR193) who talks about what he calls the "explosive" source. I'll need to look into that aspect more closely.
    Somewhere I read in his forum that the frequency should be between 16 KHz and 35 kHz, but that seems way too high. I was thinking between 2.4 kHz and 6 kHz. At this point, on SR really knows.
    It makes sense to me that the flyback is modulated.
    Though, there is no mention of the the small white vertical coil.
    And the diagram shows no air gap in between two ferrite cores.
    The flyback is here, and is modulated IN SYNCH with the main oscillator, becuase it's easier to do the two separately with a small battery powered device like this, but they work together as if 1.... If you were to use a neon sign trasformer as your oscillator for example, you would not need a separate high voltage. That's what the 'Kapagen' strives to do, but it doesn't look like the windings are designed so well, and a MOT doesn't make quite high enough voltage to work as well as it should.
    • Staying With SR193 Device
      Originally posted by SuperCaviTationIstic View Post
      The flyback is here, and is modulated IN SYNC with the main oscillator, because it's easier to do the two separately with a small battery powered device like this, but they work together as if 1.... If you were to use a neon sign transformer as your oscillator for example, you would not need a separate high voltage. That's what the 'Kapagen' strives to do, but it doesn't look like the windings are designed so well, and a MOT doesn't make quite high enough voltage to work as well as it should.
      Originally, I made many posts about the SR193 on the "my smith kapanadze replication" thread. I came to the solid conclusion that the device used a frequency generator to drive a push-pull amplifier. I was aware of the high voltage module, but I didn't have any reason to believe that the HV module was linked to the frequency generator.
      I got as far as I could get with the SR193, and so I started a Kapagen thread. Basically, I gave up on the Kapagen because I found that it will only deliver about 96% efficiency.
      I went back to the SR193 design, started this thread, and started studying the Russian forums and found that they knew more about it than we did.
      I plan to stay close to the SR193 design, which incorporates a flyback. Smith used a neon tube transformer in his design, but Smith never actually did a live demonstration where you could also observe the circuitry of his device while the device was operating. At least, SR has done this type of demonstration.
      I believe that the elements involved with the SR193, among others, are high voltage, high frequency, radiant events, and energy propagation.
      VIDBID
      • Vertical Pickup Coil?
        I'm trying to determine the function of this vertical coil. I'm thinking it may be a vertical pickup coil. Maybe it picks up the frequency coming off of the output coil. Then again who really knows except SR, and he's not saying.
        VIDBID
        • Found New SR Video
          This YouTube video looks like it might be an earlier video by SR. It looks like he is charging a capacitor to turn on the device and then discharging a capacitor to turn off the device.
          VIDBID
          • Forum Ran by SR193 who is the Admin
            I found this forum. I am being advised that the admin is SR193.
            Energy for Tomorrow forum
            VIDBID
            • SR used relay and this is important info : device cannot be loaded from start but once it become self-sustained load is attached by relay and power source is disconnected (maybe by the same relay).
              • Clearly Laid-out Kapanadze-like Setup
                This is a YouTube video showing a more clear view of a Kapanadze-like setup.
                VIDBID
                • SR193 replication ?
                  YouTube - РЕПЛИКА СР.wmv
                  Can someone please give us a translation of this working SR193 replication.
                  • Originally posted by retrod View Post
                    YouTube - *ЕПЛИК� С*.wmv
                    It is fake
                    Mike
                    • Originally posted by mlurye View Post
                      It is fake
                      How do you know that?
                      • Originally posted by Joit View Post
                        Watch second movie YouTube - Репликация СР_Разоблачение.wmv
                        Mike
                        • Thank you.
                          • So, is this one fake, or disinfo ?
                            YouTube - Some Explaining
                            • Kacher
                              Vidbid,
                              Thank you for all your hard work - it is most helpful.
                              Question: What does a kacher coil do or what does that translate to?
                              I tend to agree with you that the sine wave is modulated but possibly a different way. I found a video that was made for Tiger by someone that may have been a mentor to him that shows a circuit with changing phase of two square waves. There are several ways to accomplish that using things like a NE566 or some OP Amps doing level triggering. That part of the circuit is just simple puzzle solving and no problem. The part I am am having trouble with is the actual coil magnetics / winding.
                              The early SR coil did not have that second layer that ran the full length and stated and ended in the middle. That seems to make no sense to me.
                              I also agree with you on the gapped core. Utkin described a "apartheid capacitor" separation capacitor which is what a gap in a core basically does - store energy. regardless, Utkin stated a counter wound coil is needed and I don't see anyone doing that. Any thoughts on the counter wound coil?
                              Me thinks there is a cold electricity part of this that we are missing and that SR device may be misleading or not fully understood. One thing is for sure, lots of people are working overtime to suppress this.
                                This was a Fake by some user Delamorto and team of some peoples, we think he wanna make a Provocation, anyway he don't even a understand how this stuff works.
                                just - bla, bla, bla...
                                (when he release a first video lots of peoples send me link to its video from his side ask me about schematics and principle and they told that in next video all secret will be revieled and there are no more reason for keeping in secret, so wery foxy, sly strategy) but stupid.
                                But what can i say about SR device then i believe in it about 80% because ferrite only disturb all scenario:
                                you can take this for fundament:
                                (this is the ground of this on what all are bouilding on)
                                Static magnetics field or ionisation - called also as Dead Magnetic Field, but we can convert this field to meka a work (This Is The Point Where Need To Be Focused)
                                That way it can be started from a 9volt battery easely to in final give out 5 killovatts (for example)
