Shauberger, the Bell, fantasy?
  • Shauberger, the Bell, fantasy?
    Surfing around i came across a remarkable post on ATS, although its about UFO's he does has some very detailed (fantasy?) descriptions of the propulsion derived from Viktor Schauberger as well as advanced battery technics.
    I do not have a clue about the merits, but some here might find it interesting.
    Here is the full story: UFO Truth Revealed, page 1
    Here a quote:
    I hope, I am making myself as clear as I can possibly be; these crafts although very real in nature are not other worldly in the least, on the contrary they are designed by us. This is an example of the standard propulsion core used on-board these crafts.
    Propulsion System
    Fluid Substance
    Xerum 525
    Thorium Hydroxide (Th(OH)4)
    Beryllium Fluoride
    Cinnabar Mercury (mercury (II) sulfide (HgS)
    Iridium-192
    Silicone Dielectric Gel
    Lithium Fluoride
    Deuterium Oxide
    The above materials have changed over the years, this is not the original formula of the mixture first conceived by Dr. Kammler and his research team; however these substances when combined show the highest potential of particle energetics and is the current mixture of the substance. The mixture above when tuned to the proper fermionic field; creates three major outputs, (.1 Mass amounts of Kinetic Energy, .2 An outer-core Spinor Field equal to 0, .3 A Flux Inverse Quantum Magnetic Field) this fluid however has to be extremely shielded during operation, because of the massive amount of radiation that is emitted from the core generator.
    Inner Core Structure
    The inner-core structure is comprised of an alloy mixture of, magnesium, beryllium, and barium. It can range in sizes from very small (diameter of .5’) to very large, the biggest of which I have personally seen (diameter of 18’)or; this is an estimated guess on my part as I was not given the chance to physically measure the device. The inner-core contains the fluid solution as described above.
    Outer-Core Structure
    The outer-core is comprised of a strontium phosphate glass insulator with a vacuum space in between the inner-core and outer-core; depending on the application of the core this can vary in thickness; the propulsion cores insulator is several inches thick; with maximum vacuum gap in between. This outer shell is impregnated with (NMR) Nuclear Magnetic Lasers; which are utilized as the tuning forks for the inner core. The intensity level (resonance) of the NMR regulates not only the amount of kinetic and magnetic energy released but, depending on which NMR’s are fired in specific sequences gives you direction as well.
    Power Source
    The power source for the unit is a specially designed battery system comprised of finely made lattice silicon sheets riddled with pits 40 microns thick; they are then cutout and constructed into hollow dodecahedrons and coated with iridium-192. You then stack them on-top of each other placed inside a hermetically sealed cylinder. The cylinder is then filled with radioactive tritium gas; this is the equivalent of taking several hundred solar panels and dropping the sun into to the center of them. The number of battery cells needed depends on the size of the core generator you are using.
    I came across this whole Stuff too, but i think, that some do mix Things up,
    how they wanna see it.
    There are 2 Persons mostly involved, Shauberger and Coler, where some claim,
    Shauberger made the Planes and Coler the Engine, but i dont think its true.
    The last i ve heared from Shaubergers grandson was, that he was 2004 on the Track from his Grandpa. What he reported there was, that V. Shauberger did go 1954 to US with a Us citizen, what lived in Germany, and was the Investor from his Projects, or more, he was interested in it.
    But after some Drafts and prototypes they disband her connection, because this Investor was a very strange Person, maybe very ruling, so Shauberger and his Son did stop her Visit at the USA and did go back, where Shauberger died after 5 Days. He did may work during the War at some Prototypes at his Repulsine and i think they used it for some Planebodys, but never saw a done Plane from it.
    Could be, that there been some other Prototypes also, but i doubt, the worked only after the Shauberger Principle.
    The other Peson was Coler with his Device, but there are no Tracks too, that he really did build bigger Devices from or, or used it as Source for flying Soucers.
    I did see other Plans from Soucers, but they did need a Powersource,
    and it did deplet, so i think, it was an other Technique.
    The other Reports from this Saucers was, that they been hard to control,
    you could only stear them at a 125° 90° and 45°, so that dont looks for me,
    that they did fly trough the Air, but more electromagnetically, even if.
    I did do some research about this Saucers here too, but seems
    noone knows anything about it, even not from the older Peoples.
    If there are any flying Soucers out there, then it seems they use something else as Shauberger and Coler Principles.
    What i have heared, that someone mentioned, that the US Army did leave 1960 a Emergency-Generator back, what was selfsustaining at a certain Rpm. So the Tecnology should be known at the Army.
      Astronout Buzz Aldrin telling they did see an mysterious Bell shaped object outside the Apollo.
      YouTube - UFO Astronaut Confession - part 1 of 3
      Fragment at 4:35
