Brovin/Kacher Generator
  • #31
    i suggest you buy some tip31C they are cheap and i like ther performance, dont burn easily!
    tip42C is also NPN? maybe its better that the 31C, dont know...
    EDIT: ups, forget that! TIP42 is PNP, the one in abcstore circuit!
    Originally posted by seth View Post
    Hi guys!
    Im buying some...
    TIP3055
    TIP42C
    and..
    MJE13009
    Light, I Am!
    • #32
      Cheers!
      TIP31C will also be on order...gotta get above 20 pounds!!!
      Any other winning transistors?
      • #33
        @Juju
        I love "The Gift"!!
        Way cool idea.
        Don
        • #34
          hi bolt
          how do i indentify wich one is the TV line o/p transistor?
          i have to old tv's damaged in my garage...
          hugs
          Follow the HT cable down to the transformer. Beside it will be a big heatsink covered in fluff on there is the HT transistor. Unsolder it complete with heatsink if you can.
          The TIP31 etc are only rated at about 40 volts 30 watts so they will blow easy if your coil returns too many volts. A TV transistor typical 100 watts 1500 volts rating and only cost about 1 eur/usd/quid more.
          • #35
            dont now if i get it well, but is the transistor connected to the flyback transformer? i will look up!!
            thanks
            Light, I Am!
            • #36
              I tried four more transistors that i found in an old abandoned tv in the woods - still no success!!! just sparks and smoke from blown transistors.
              I have a 2N 3904 sitting in a joule thief......i kinda like it where it is (i have no other 2n3904s....i blew them all in flyback experiments). Nonetheless, if you guys reckon it just might work, ill give it a try. If its highly unlikely, then i'll wait till the transistors ive ordered arrive, and try and find some others in old electrical equipment.
              • #37
                hello, one question, are you able to light 220V bulbs with your 19V input katcher?
                Originally posted by ABCStore View Post
                1. The higher current rating of the transistor, the better.
                2. The circuit works when transistor is closed most of the time
                ABC
                Light, I Am!
                • #38
                  thank you dllabarre, its greatfull to read that great words from someone great like you!
                  hugs
                  Originally posted by dllabarre View Post
                  @Juju
                  I love "The Gift"!!
                  Way cool idea.
                  Light, I Am!
                  • #39
                    you guys can light incandescent bulbs with the katcher at small distance using copper plate at lamp, and powering it with 20/30W ??? , if so...
                    how?
                    BOOM
                    Light, I Am!
                    • #40
                      Kacher
                      Hi guys but is this same as Kapandze device?Can this perform like his?
                      • #41
                        Yes
                        , if so...
                        how?
                        Efficiently...
                        ABC
                        • #42
                          No, it is not. In fact, it's so far away from Kapanadze device, I'm not sure how you could see any similarities.
                          ABC
                          • #43
                            so you can light incandescent bulbs at distance with your 19v input katcher, with the schematic that you showed?
                            ABC
                            Light, I Am!
                            • #44
                              220V incandescent bulbs?
                              Light, I Am!
                              • #45
                                110v
                                My version is low-power but I've burned a few 4W light bulbs already...
                                ABC
