Brovin/Kacher Generator
  • #46
    my katcher
    Input: 20V at arround 1.2A (24W) at best, im lightning 240V (15W) fridge's incandescent bulbs wirelessly at small distance, by the time of the video i was with somekind of problem and my performance was decreasing i was not able to find why, but in the first tests, before i made it, i was even able to light a 25W incandescent bulb and the 15W bulbs much more brighter!
    This one goes to cosmir farmer, seth, dllabarre, luno, baroutologos, wings, abcstore, kdas, bolt!
    Enjoy! YouTube - jujusalva's Channel
    Light, I Am!
    • #47
      by the way, how r you doing with your katcher dlbarre?
      Light, I Am!
      • #48
        wireless
        Guys be aware of this device there was a guy talking about this that it can charge metal things in the vicinity with high voltage and would be lethal like door nobs etc...
        Just to warn.
        • #49
          Awesome video!
          I like the way you show the possibilities of the Kacher.
          Do you know what the frequency is of your L2 coil?
          I'm working on a slightly different set up with my Kacher.
          "We are not human beings having a conciousness experience, We are conciousness beings having a human experience!"
          That's the truth!
          Thank you,
          Don
          • #50
            cool thats the way to go!
            i have not yet measured the frequency, since im using voltages arround 20V... but im working on efficiency.. im winding a new coil!
            then i will experiment with lower voltages and for shore i will take some scopeshots!! im afraid of measuring more that 12V, thats the far i tryed with my soundcard, still searching for a simple voltage divider circuit!
            i allready felt thats what you feel to! hugs
            ps: have you seen my cold energy video? cool stuff eheh, just playing arround! cant wait to see your katcher!!
            BOOM
            Originally posted by dllabarre View Post
            Awesome video!
            That's the truth!
            Thank you,
            Light, I Am!
            • #51
              Can someone translate all the Russian in this image?
              I assume the center is split copper tube/pipe inside the Ferrite core but what is on the outside?
              Don
              • #52
                dllbarre, maybe its copper foil! i have seen a video were the guy used copper inside the ferrite core to induce energy in another iron core inside all that!
                but is that a katcher shematic?
                Light, I Am!
                • #53
                  Not a kacher schematic.
                  It's from a Russian website discussing Kapanadze.
                  I'm trying to get the Russian in the image translated.
                  Don
                  • #54
                    you r so cool luno!!
                    thank you in the name of all!
                    you dont mentioned the internal cover.. is really copper foil?
                    the 3 transistors are all the same KT819.. shouldnt be one of them PNP, in the flip flop arrangement? ...
                    Originally posted by luno
                    Hi everyone!
                    Here is the picture with translated Russian writings.
                    Light, I Am!
                    • #55
                      It's a basic multivibrator inverter circuit which uses 2 NPN's. 2 Joule thief circuits opposite each other.
                      ________
                      • #56
                        Thanks Dragon and Luno
                        There's no word on what the material is on the outside of the ferrite core?
                        Is the inside material copper tube/pipe?
                        Don
                        • #57
                          deleted today
                          Don
                          • #58
                            1/4 watt kacher circuit
                            Here is a little project I've been playing with... starting to refine it a bit to finish it off.
                            Basically a kacher circuit driving a tesla coil, running on 5 volts at 40ma... the picture tells the story.... a neon, 4 watt FL, 8 watt FL and my little LED energy detector light....
                            ________
                            • #59
                              I bet its the Slayer setup with the MPSA06 transistor, and the L1 few turns coil going to base, right?
                              I have being trying a similar also, but my power draw is monstrous higher!
                              I need to make another coil, similar than yours i guess
                              • #60
                                Why is this circuit such a buzz TODAY?
                                Hope this theory and patent helps explain just where the quantum energy is being generated and how. Seems like this mag-gen is the simplest one yet. This attachment didn't take is was the Kunel patent on a mag-gen breaking the magnetic circle collapses not only the magnetic field it makes them field "slap" back together generating lots of light speed particle movements, which in turn bump all kinds of close matter. so collecting the slap back and ringing it again will add to the primary ring which in turn cyclically pump the next slap back harder. etc... Also looks like a Grid Dip Meter would help "tune" our resonators, they sell on ebay for $100-400 bucks. There are free dipmeter circuits on the net. Take the time to read this patent KUNEL PATENT: (DE3024814) a few are committing to a build on this device on another well known site. Hope this is the golden egg! You seem to be able to start this circuit with just a magnet.
