First, I have discussed posting this info with Aaron, and have permission to do so.
CermaSales - Index
This product is of special interest to those who burn Hydrogen in their engine as Hydrogen has been well documented to embrittle metal and cause Hydrogen induced stress cracking. With time the Hydrogen will penetrate the metal at various points and cause damage. By adding a ceramic layer onto the metal this problem is eliminated. STM-3 can be added to the crankcase oil and the fuel so that all parts are treated.
We also have a product approved for dentistry applications.
You can visit our website for more information: CermaSales - FAQ
CermaSales - Index
Cerma with STM-3® is a patent pending ceramic metal catalyst that has been proven to significantly improve fuel efficiency and engine performance, offering superior protection of the critical components of your engine from excess wear and tear, while reducing the emissions of harmful greenhouse gases. Cerma with STM3® is a ONE TIME application.
*A full treatment will provide benefit for 100,000 kms.
Here at Cerma Sales, we are on a mission to change the way the world looks at lubrication and the application of lubricants.
Ceramic metal treatment has a multitude of applications.
In internal combustion engines, it has been proven that a one time treatment of 2oz.
of Cerma with STM-3 poured into crankcase will provide these benefits within 500 miles.
* Increase torque
* Reduce carbon deposits
* Increase horsepower (28 hp as tested)
* Increase compression (equalizing compression across all cylinders)
* Increase fuel economy (3.4% to 24% as tested.
* Reduce emission gases (92% reduction as tested) as tested by EPA certified test facility and diesel smoke particulates (100% after 100 miles)as tested by third party
* Reduce the wear of engine and drive train
* Reduce repairs, caused by harmonic-induced wear
* Will not affect factory clearances (certified metallurgy testing)
* Reduce engine vibration and noise (harmonics) (50-90% as tested)
Understanding What STM-3 metal treatment is, & how it works
All claims are based on 7 years of independent third party,& real world testing Keep in mind these results are as tested, and your results may differ. STM-3™ (Surface Tension Modifier-Third Formulation) Ceramic Catalyst is a patent pending liquid ceramic metal treatment that has been proven to significantly improve gas and diesel fuel , 2 cycle efficiency and engine performance, offering superior protection of the critical components of your engine from excess wear and tear and a significant reduction of emissions of harmful greenhouse gases.
* Increase torque
STM-3 Based products, utilize a Ceramic Lubrication Catalyst. STM-3 is not a normal oil additive, nor a replacement for your oil. STM-3 is an advanced metal treatment that protects metal parts within your engine, transmission, gear box, anywhere there is a need for lubrication enhancement and protection. STM-3 is designed to be used on any rigid or semi-rigid surface subjected to sliding, rotating or oscillating harmonic drag/friction. STM-3 is designed to carry loads in excess of 350,000 PSI as well as lubricate at temperatures in excess of 1900° F. STM-3 is a combination of a unique ceramic resin and lubricating solids. STM-3 combines the durability of a ceramic resin with the lubricity of the ceramic lubricant. STM-3 works well in all applications, but is best at high temperatures, high loads and high speeds. STM-3 is fully capable of carrying the load where normal or synthetic lubricants and PTFE additives fail. STM-3 is 100 % solid, clear and acquires a clear Ceramic finish in use. STM-3 is formulated to provide an approximate cured film thickness of 6 microns or less of ceramic coating within the valleys of the metal surface. STM-3 contains no solvents.
