Plasma propulsion / Lifter / EM Antigravity Mini AirCraft
  • #16
    Originally posted by sucahyo View Post
    Why this video show only momentary acceleration and not continuous like serfer5?
    Considering the circuit mentioned is pulse triggered I wonder why it only produce momentary acceleration? My experiment also show continuous thrust?
    I don't know, perhaps ask Mr. Gilles
    • #17
      Originally posted by Harvey View Post
      Very Nice
      thanks .... posted a few more vids last night, i was just wondering if the slayer exciter as a power supply would make a difference, being that it runs at a higher frequency
      • #18
        hmmm
        can you explain that better?
        Light, I Am!
        • #19
          if you are talking about the frequency I mentioned then it has to do with these devices are basically like capacitors and react to different frequencies. the power supplies used on lifters was a computer monitor running at around 16 Kilo Hz and the slayer circuit runs much faster, it might not make a difference but then again it might
          • #20
            hmmm
            so you are planning to output kilovolts from a slayer exiter tower, to power a lifter?
            Light, I Am!
            • #21
              the output is all ready in kilovolts, to get to higher kilovolts i would add a voltage multiplyer to L1
              • #22
                Onboard KV
                Somewhere in my junk box I have an ignition coil pack from a 2000 Mercury. It is relatively light weight and has an output to drive spark plugs directly.
                Now, I was thinking, a lightweight lithium battery or the like could be used with that (and maybe a voltage multiplier)to feed the inside of a sphere. In a very short period of time the exterior of the sphere will reach dielectric break down voltage of the surrounding air.
                Now - what would be required, to put this on a lifter to supply the on board power for the thrusters?
                Or is there a lot more power going on here than just the ES field stress?
                • #23
                  harvey dont know if i understanded well..
                  you want to drive small thruster that will be coupled to the lifter, to propel it?
                  thats a very good idea!
                  @serfer can you point me simple schematics to make a small thruster similar to yours? you power it just like you power a lifter?
                  hugs
                  Light, I Am!
                  • #24
                    Can we really use voltage multiplier in the kilovolts output part? Won't it reduce power?
                    By L1 do you mean the primary? I think on a very efficient switching circuit, voltage multiplier might end up reduce the secondary voltage.
                    • #25
                      Why sphere? A static potential do not provide continuous thrust.
                      • #26
                        hugs
                        Yes, did you see Charles Gilles video at the very end (2:42) where he attached his to a regular lifter?
                        I'm trying to see if there is a way to put the power on board so it will be mobile.
                        • #27
                          The inside of a sphere is always zero volts potential, so it will keep taking new charge indefinitely from the coil-pack. The outside of the sphere will grow in charge accordingly, so it becomes a very high voltage source.
                          Look carefully at Charles Gilles thruster, it is using high voltage to operate.
                          It is a direct conversion between an Electric Field and Kinetic Energy. But there must be power involved - how much weight and how much lift acceleration determines the power needed.
                          At the very least, I think we can fly a helium balloon around with it.
                          (In Fact, the Helium Balloon can be our sphere)
                          • #28
                            I mean, can we produce pulsed very high voltage with that?
                            TT Brown mention that static high voltage produce dampened acceleration. It will accelerate for 5 second and then reverse a little. Forget where I read it, sorry.
                            Maybe 50KV produce bigger thrust, but without pulsing, we only get momentary acceleration.
                            • #29
                              The Sphere is a capacitor to store the charge and gives us a way to use lower voltage charging systems to get a very high voltage potential.
                              Serfer has a rotational thruster of some type there that runs for quite a while, about 27 seconds by my count, and looks as if it would just keep rotating as long as power is applied.
                              I don't have any practical experience with lifters, but I do have a lot of experience with Horizontal Flyback Transformers and HV systems among other things. So I'm learning here along with the rest =)
                              • #30
                                hugs
                                the JNL site that you took the lifter pictures from has all the info you need, i was part of that project in 2000 2002 and the building material used was balsa wood or foam with aluminum foil. I used foam, if you need more info then i will try to help
