Hi,
i'm trying to understand why it is that the induced voltage in a coil, by moving magnets, is sometimes more than 90° after the magnetic sinus.
Let me tell you what my setup is.
Basically it is an Adams motor with bipolar magnet setup. So, when there is a north pole facing the coils, the next magnet would show a south pole and so on.
There are 8 magnets on the rotor, currently only one 60 ohm drive coil with ferrite core and one generator coil with iron core.
So when the rotor spins at 3000 rpm, and i watch the induced voltage in the generator coil, i see that the voltage is say 15° after what it should be.
This causes the rotor to accelerate when i short the generator coil out.
Because the cemf is now 2x 15° out of phase.
If the voltage is exactly 90° after the magnetic sinus, like it should be, there would be no acceleration at SC because the cemf would accelerate the magnets the same amount it slowed them down when the magnets approached the generator coil.
I can actually accelerate the motor by feeding a transformer to get a higher voltage, which i then rectify and put back to one of the input capacitors
So my question is, why does the induced voltage lag behind at higher frequencies? It only works with iron and a lot of copper, say at least 400 turns.
