GAP Power - Magnetic Neutralization
  • #46
    I can collect like a monopole where the ground is hooked to the hot of the run. A capacitor (100volt 10,000uf) will charge up to 100 volt within a seconds time but I have not gone past that as far as discharging the capacitor back to the run system or a separate charging bank.
    Neat stuff I wish I had some bigger magnets.
    Matt
    Hey Matt that is a lot of energy for 1 sec!! Can you explain what you mean with "where the ground is hooked to the hot of the run".
    You said that you don't get much from the fly back.
    A quick observation.
    I did a quick test today with 3 small round ceramics with a short steel piece glued on top with a quick coil turned around it. (27 awg)
    In repel mode, I can get the top moving magnets to drop down on the coil when activating the coil if they are near to the coil.
    When in attraction mode I cannot get the moving magnets to release and pulled away by hand. It will need a lot of voltage and a huge coil to do that.
    • #47
      Just like a monopole. The charge side is grounded to the hot of the run side. Then the discharge goes from the coil hookup on the collector to the hot of the charge battery.
      I have tuned it a bit better and I am now able to get the charge batts up a bit a more.
      Try Neo's they work better.
      Matt
      • #48
        Does it make any difference if the magnets attached to the core of the coil are set back away from the coil with an extended core like the Gap Power motor or can the magnets be placed directly on the core of a coil that is even with the edge of the coil spool?
        Just curious if this is important... I will give it a try both ways.....
        I think I need to get a variable/adjustable power supply to help me with these experements....
        Hopes and Dreams.....
        Tj
        • #49
          Tj
          Nope doesn't matter. I guess the big thing would be if the core is long enough the field will dissipate so you lose the advantage.
          Matt
          • #50
            Thanks Matt!
            I have several Bedini bifilar coils with cores in them so I will start with them and my 1.5 inch x .5 in neos and see how it goes....
            I think that this back and forth shaft motor with help me replicate a different version of the Kundel motor effect and get some rotation from it....
            Tj
