The strength of gravity is proportional to the mass of the planet and inversely proportional to the square of the distance from the center of the planet's mass. The Earth's gravity field is measured as 9.82 m/s2 without anything acting on it. This means that an object dropped on Earth will increase its speed by 9.82 meters every second it falls until it hits the ground.
With the above in mind, take a look at the following simple thought experiment. How can an object that is dropped from 40,000 feet above the earth fall at the same rate of 9.82 m/s2 as an object that is dropped from 1,000 feet, when the strength of gravity is stronger near the surface of the Earth? To make this clear, the strength of gravity is weaker at 40,000 feet above the Earth than at 1,000 feet above the Earth, so each object should fall at a different rate, but this is not the case.
Since gravity is weaker at further distances from the center of the earth, then a falling object with mass must be encountering less resistance than an object that is much closer to the center of the earth while encountering a higher resistance in order for each object to have the same rate of 9.82 m/s2.
What is this resistance? This resistance strongly suggests an Aether. In the above thought experiment, we can see the Aether is more dense at the center of a mass, which offers more resistance, which overcomes the increase in the strength of gravity as you approach the center of the Earth. So, in essence, the Aether is more dense and has more resistance at 1,000 feet above the surface of the earth, and is less dense and has less resistance at 40,000 feet above the surface.
Take an object which is 1,000 feet above the Earth and add up the pressure from the Aether above it, then it is easy to see how gravity is stronger near the surface of the Earth than at 40,000 feet. At 40,000 feet, there is less pressure on an object, thus a lower strength in gravity.
How can the Aether cause an approaching object to follow a curved path? The Aether causes an object to follow a curved path in a similar way how a car is pulled in one direction when one of it's tires hit a pool of water. This is how space is curved. Time is curved due to the pressure of the Aether. At higher Aether pressures, all atoms oscillate at a slower rate, thus Time is curved. Aether does not fill the vacuum of space in large quanities, but instead is present and moves with a large mass. More to come!
GB
GB
