Steorn Document on Asymmetry with PM devices
  • Steorn Document on Asymmetry with PM devices
    This document that records Steorn test results related to their older "all permanent magnet" technology, has some interesting claims in it
    http://www.steorn.com/images/asymmet...ic-systems.pdf
    "Test #4" has a significant claim in the results: That positive net energy from magnets is possible under very specific conditions.
    There are two types, and "meanings" of "Asymmetry" discussed there:
    > The magnets' relative polarity positions ("asymmetric" in this case meaning the stator mag is at an "angle" relating to the rotor mag... the poles DO NOT line up).
    > The relative field strength of the two magnets being the other meaning. In other words, they apparently use the soft ferrite that is in contact with the rotor mag, to diffuse somewhat and over-all lessen its effective field strength. So that the stator mag has a "stronger" magnetic field opposing the rotor mag; even though they are apparently identical in size and Gauss.
    Another interesting conclusion from the test data of #4, is that from the Plot we can see that DISTANCE between the stator mag and the combo of ferrite and rotor mag, is very important ("20 mm")... Less or more by more than 3 or 4 mm's, and the positive net energy disappears completely.
    So if this data is "correct", and we wanted to use the results to design an "all-magnet motors" ourselves, imo these would be the conclusions to "try out":
    1) "Angle" the set of one magnets so the poles don't line up with the opposing set of mags (it doesn't matter which is "rotor" or "stator" as long as the formula for each is followed). You would need to try all angles to find the best (since this info is not included in the Test data).... start at "45 deg" i guess and work from there.
    2) Use a "diffusing" permeable magnetic metal or substance along with the other magnet to modify its magnetic field (again, we can make either the Rotor or the Stator mags "angled" and "stronger", as long as the other opposing ones use the ferrite and are "weaker").
    3) Use a very specific distance between the two, that is probably longer than most of us would have suspected... Again this will need to be tested as it will vary for every configuration tried.
    This kinda reminds me of the Nicolae Moraru of Romania stuff (who was said to have invented a magnet motor back in the 1980's during the Cold War days), where he was reported to state that "Iron Facing Magnet" is the way to do it, not "magnet facing magnet". Unfortunately, there was very little to go on regarding this device, only the word of the guy who claimed he used to work for their secret police and stole the info from the files after the Communists fell.
    In fact, i remember that the design was said to have small coils in the stator area, that were never explained: Electromagnet coils to put a weak field in the "iron" of the stator (the mags being in the rotor)? It's even possible, that once running, those EM coils could be "self-excited" from the rotor's mags (...and could possibly also be used to "throttle" or control it somehow).
    Interesting to think about, anyway
    Thanks mate adding to the Steorn production, we are getting a new drive circuit, they checked the E orbo for us and found it was only our drive circuit not timing properly, will update the other thread soon, thanks for this Bro.
    Ash
      Talk about digging up old threads lol...
      Was looking for this document link today at our Free Energy Facebook Group's "Wall" and realized that the link posting for it had disappeared.
      Second time that's happened now as far as i can tell (the first being the fully Conventional "jet engine-inspired wind turbine" that uses the power of Vortex http://www.alternative-energy-news.i...-jet-engines/).
        I think the distance is extremely important, and could very well be the reason for the magnetic bearings since the attraction force is too weak at that distance to overcome the friction of conventional bearings. Also, only 1 or 2 toroids are used in most replication attempts I have seen, when a minimum of 4 should be used (6 or 8 would be better). The angle between the magnets and toroids is probably a factor also.
        A homemade Dynamometer using an old usb scroll mouse would be beneficial for finding the correct parameters IMO. The software continuously plots RPM, Torque, and Power. Trying to get people to understand the importance of these parameters is like trying to beat a dead horse to rise. The ones who have performed torque measurements have done so in a linear fashion. People do a half-assed replication of a normal pulse motor, then claim there is no orbo effect. People totally disregard the "hard disk drive" tolerances that Steorn has mentioned and think they can just slap any toroid around some rotor magnets for a successful replication. Assuming the orbo effect is real, then it's more than likely inside a "small window".
        The publications by Steorn on the "Asymmetry and Energy in Magnetic Systems", and "Magnetic Torque Measurement System" isn't anything new. This information was posted over 9 months ago, but is now only being noticed since Clanzer has displayed interest in it. As you can see from that link, not 1 person replied to that thread. Why is it being noticed now, when it wasn't noticed then. Do people have a mind of their own, or are they led by others. I say it's the latter. What a shame. Another thing is people only refer to the B-H curves, while totally disregarding the M-H curves. What Clanzer is doing now, I suggested almost a year ago.
        GB
          Hi mate
          Suppose the difference is when I talk about something, I actually go out and try to replicate it. Whether the replication is good or bad, is another matter
          We can bang on about theory all day, but I aint got the brains for that, I prefer to knock something up and try the practical side to see if it works. Conventional physics tell us we are wasting our time, but hey we must be crazy I suppose
          Would of picked up on this when it was released and it has been on the TODO list for a while, but then the TODO list is so bloody long these days.
          E-Orbo was in full motion at the time, so hence why the information was not acted on.
          Also there is a lot of information given to the SKDB member years ago, that we have not been able to talk about public, so it a mixture of trying the public stuff as well as a few other bits that we cannot talk about.
          And I totaly agree with your first two paragraphs.
          Sean.
          http://www.overunity.org.uk
            Originally posted by CLaNZeR View Post
            Hi mate
            Sean.
            Clanzer,
            I'm very limited in what I can replicate or test due to various reasons, so I share ideas in the hopes someone will. It's good that someone like you is around to replicate and share their results. We truly need more people like you in this open source community. What upsets me, is there are people who are capable of replicating, but they either choose not to, or they choose not to share their results due to failures, etc. Anyways, keep up the good work and thanks for the feedback.
            [Edit:] I did do a poor-mans replication of the e-orbo. As you can see I had to resort to home-made reed switches and a "collar" I found laying around the house for a toroid. Had nothing to quench the spark or capture the BEMF either, and it was turning my webcam on/off and knocking out the tv signal, lol. Even though it was a poor-mans replication of low quality, I still learned a few things from it. I wish I could take this further and do it right (It's very frustrating not being able to, and then to see those who can, won't).
            [Edit2:] Here's an Asymmetry test I performed with PM's awhile back, where the bottom rotor magnet will escape the sticky spot moving CCW, but won't escape the sticky spot while moving CW. Even though it escaped the sticky spot, it didn't have enough momentum or energy transfer to release the other rotor from the stator magnets continuosly. I tried to get two seperate parralel rotors leap frogging over the stator magnets, one rotor pulling the other rotor out of the sticky spot. On a few occasions, there was more than a full rotation (not shown in the video), but it was never self-sustaining. I believe this setup would be self-sustaining if the full momentum of both rotors were transferred to each other where there was no "bounce" between them when they made contact (an impedance match between them). This experiment lacked the precision, lacked the parts such as magnetic bearings, rotors of the same mass, quality, etc. neccessary to obtain this, assuming of course it would be possible. There does appear to be a gain in one direction and a loss in the other direction though.
            GB
              Long day in the workshop but Steorn PM-Orbo automated Rig build has begun.
              YouTube - CLaNZeR Automated PM-Orbo Rig Part 1
                Sweet!
                GB
