Does this "Secret Tesla Generator" really work?
  • #76
    another variation im thinking of trying is to take two strands of enameled wire about say 100ft long wind them together on a pvc pipe either 3" or 4" and suspend it 30' off the gnd and see if the voltage and current is the same as my setup now ....just thinking outloud
    • #77
      no kidding the ebook only shows references to devices which are not available.
      dr nakamats cosmic concrete not available.
      dr nakamats cosmic converter not available.
      2008 detailed discussion Cosmic Energy Machine for Real - The San Diego Alternative Energy Meetup Group (San Diego, CA) - Meetup
      followers of dr. nakamats relate to the movie the rug cop https://www.youtube.com/watch?v=im-Bi5fAyhU
      study of dr nakamatsu requires a sense of Japanese humor.
      John Hutchison's silicon wafer using pressure was disclosed.
      • #78
        Ok so i removed the toroid transformer and used a ac to dc converter circuit and ran some charging tests and i was supprised at my findings .
        i removed the spark gap switch i made and hooked my antenna set up to it without it ( as it is in most of the scematics you find around the net) the readings are as follows
        NO SPARK GAP SWITCH :
        charging the caps in the circuit to 1vdc took 37 seconds
        it slows for some reason and stops completely at 1.5vdc which took 2 minutes to reach
        WITH SPARK GAP SWITCH :
        charging to 1vdc = 8 seconds (NO KIDDING)
        and in the same 37 seconds for the first test this test reached 3vdc in that time and 1 minute = 4,20vdc and 5vdc in 1:20 6vdc in 2 minutes
        and it never stopped climbing .
        I think the spark gap approach before the circuit made a huge difference...and i also found that if it stays under a load this way (with my setup ) the voltage out is constant at .5vdc so now to figure out a way to help this end of the circuit ...
        hopefully this was worth your time to read !!
        • #79
          This might help reduce losses from your spark gap/reed switch but you'll need a vacuum pump to accomplish it.
          Use a glass jar or beaker with a stopper. Make 3 holes in the stopper. Run the leads to your spark gap through two of the holes and attach the spark gap so it will be inside the jar. Connect the vacuum pump to a tube through the stopper to the inside of the jar and evacuate the jar with the vacuum pump. You should have a valve on the tube to seal it off after evacuating the jar. The vacuum will hold the stopper in the jar.
          This would give you a crude vacuum tube and possibly lead to lower losses through the air around the spark gap.
          • #80
            thanks had not crossed my mind about using a vacuum tube .
            although i do have an old compressor pomp from an old window ac unit i could use as a make shift vacuum pump...after work today ill give that a try...thanks again
            • #81
              ok i beef`d up this dc charging circuit a little and connected a load (led) to the dc out and it stayed lit without draining the caps so this is looking promising...
              • #82
                Ok i didnt like the results from the above schematic for some reason the readings were all over the place after a few days... but i made some mods that are working good as of now and that is i built a full wave rectifier from the germanium diodes and enclosed the spark gap (as suggested in an above post) and after the switch i put a 1uf 2100 vac capacitor ( microwave) then through the rectifier into another 25uf 370v capacitor ( window ac unit motor run capacitor) and into a toroid transformers primary and an led across the secondary its staying lit up very well with 10.7 to 11.5 vdc constant across the primary...this is looking promising to say the least...
                oh i almost forgot the current is now a few milliamps so im thinking of a few of these rectifiers in parallel to boost current and/or a few more antennas and hook them up before the spark gap switch to boost current ...
                • #83
                  Well after work today i had an idea to try and it proved to work but only for a short time because i blew my germanium diodes...not sure how but they were old . salvaged from old radios and such...but i have a heck of alot of 1n4004 and 4148 and a bunch of others but anyway what i did was hook 5 rectifiers up paralleled to boost current and yes with two it doubled with three it jumped again so i went with 5 and i ended up with 300ma thats a big deal 300ma is a heck of alot of current from a one wire antenna i thought i was seeing things so i grabbed a cup of joe sat down and thought it over and went to repeat the test and wouldnt you know it ... it was a nogo i checked my diodes and i had blown almost all of them. how i do not know but imma build some from these others i have and see what i get .
                  i know the forward voltage drop will not compare to the germanium but i dont have any more to play with nor any schottky diodes at present...ill post my findings i hope i was seeing what i thought i saw...i still cant get over it 300ma dang...
                  • #84
                    Do you know if your diodes are 1N34 or 1N34a? The 1N34's haven't been produced for quite some time so I guess it would depend on how old the radios from which you pulled them are.
                    The 1N34's have an opaque ceramic package and the 1N34a's have a glass package. I'm not sure about the 1N34's but the 1N34a's have a maximum repetitive peak surge forward current of 200ma and a maximum rectified forward current of 50ma.
                    The 1N4448 will give you a lower forward voltage drop (~0.7V) than the 1N4004 or 1N4148 (~1.0V) if you can get them.
                    • #85
                      the diodes were 134a because all were glass... ive been checking some of my diodes to find the ones with the lowest forward voltage i found several (unmarked for some reason) the forward voltage was from between .455 and .600 well thats just the readings on the diode setting after it turned on to allow current to pass but anyway those .455 should be really close to what i was getting from the germanium diodes... more testing more smoke..lol
                      • #86
                        Ok so i have assembled my rectifiers to try and get close to the readings i had a few days ago.
                        But i cant a am however getting 280ua from one rectifier so im going to parallel the outputs of a few and see what readings i get i have also built a current amplifying circuit to see what i can get outta that as well .. Ill keep posting my results...
                        ok here is some of what ive done .
                        i used my multimeter and went through a batch of 1n4004 and 1n4001 diodes i had each lot was from the same batch each so thats a plus but anyway i checked each till i found 4 with the lowest reading for the full wave rectifier i did this for 4 rectifiers each diode had readings of .500 to .507 thats pretty low not as low as id like but they will do...
                        now on my single antenna setup i hooked up the rectifiers ac inputs to the antenna and earth then i ran each rectifier through its own high voltage cap and the potential current on each was around 180ua to 240ua with a voltage of 125 vdc or better the voltage climbs very fast, if left without a load its just keeps climbing. ( ive been having some issues with my spark gap ) that might account for the odd readings...but anyway i paralleled the circuits and the current shot up and under a load it maintained a potential voltage of 35vdc at 257ua thats pretty good in my opinion...this is just two circuits paralleled im planning on seeing how much current i can actually get out of only one wire .... i have several hv caps to play with so we shall see what happens....
                        Ill fix my spark gap problems and hopefully it will be better ...
                        • #87
                          Well i just thought i would post some of my progress "again" im probably boring you guys with this because most of you have probably already experimented with it and know the outcome but anyway ill post some of my findings ...
                          i fixed my spark gap somehow it was leaking for lack of a better term but i have it stable now i did how ever find that if you construct a crude current boost circuit with a few hv caps a rectifier and a bleeder resistor you can put a fairly large load on this antenna setup...i have an led strip from a broken 55" led screen as my load all the leds light up on that strip now that may not be much but the current is staying constant now and the voltage is stable at 7.5vdc
                          Im thinking of trying to see how much of a load i can add to see where the current boost circuit will top out so to speak.
                          Then i have a question im proposing when i find the "top end" to try and before the rectification when the current is at its peek to try and add a stepdown transformer to see if it will work the way im hoping which is sense the current is high enough (hopefully) that when the voltage is stepped down the current will jump again ...i hope you understand what im trying to say here...
                          It would be like taking power again from the same source like a wall outlet sorta ...leaving the load on one end to keep the current and voltage as high as possible and on the back end incorporating the step-down transformer to see if it will do as im hoping...
                          Any thoughts ?
                          • #88
                            Originally posted by nlw View Post
                            I live in sunny south Texas and have approximately 10,000 sf of metal interlocking roofing panels on my house and shop. Can this roof be used as a large antannae on any of Tesla's works?
                            The short answer is probably not. The longer answer follows.
                            One of the requirements for Tesla's radiant energy collector is that the elevated plate be insulated with a dielectric material. I doubt your roofing is insulated in such a manner. If it is not insulated but is then connected to an earth ground you are turning your roof into a Franklin style lightning rod. The way that works is that the point of the lightning rod ionizes the air around the point which makes it more conductive than the non-ionized air. So when there is a lightning bolt it takes the easier path to ground through the ionized air around that point to the point and then through the rod and connected wire to ground. That prevents the lightning from striking a less desirable part of the structure that might catch fire.
                            If your metal roof has any burrs or sharp points from being cut or at the corners it would do the same thing and actually attract lightning bolts like a Franklin lightning rod so you don't want to do that.
                            The insulating dielectric material around the elevated plate in Tesla's device serves two purposes. The first is explained above. The second is charge separation which prevents the collected charge from neutralizing with charges in the air on its way to whatever device is attached. Without that charge separation very little, if any, charge will reach the attached device.
                            Another aspect is the height above ground and the height above sea level. In both cases higher is better. The distance above ground apparently needs to a minimum of 30 feet but higher is better. I never saw anything stating this but I think Tesla was thinking of the insulated elevated plate being much higher - in the realm of thousands of feet above sea level. His wireless transmission patent states that we was considering transmitting between balloons maintained at 30,000 feet. We have to remember that heavier than air did not exist in 1897. The rarefied air and very cold temperatures at that altitude would both have made it easier to transmit electricity.
                            So in the valley your altitude above sea level will also be detrimental to a radiant energy collector working.
                            • #89
                              i had some very interesting readings last night because of an electrical storm that moved through my area ...my origional 370vac jumped to over 1000vac at times which was interesting in itself however the current was fluctuating from a couple hundred ua (normal) to the ma range and once to 3 a wow!!! that was fun...
                              but on a different note i modded my circuit again by moving my spark gap ( found a few better ones in old pc monitors) after the hv cap in series with the antenna then to an air coil transformer with 100 turns on primary and 15 turns on secondary then to a modded rectifier ( nonpolar caps across the dc out of the bridge) then a electrolytic cap across the output to the load...( load being incandescent bulbs) tried one from an old flashlight worked well but blew ofter letting the cap build too high ... then went to a 12vdc test light bulb its working as of now but only if i let the cap charge first then it drains to 5vdc and the light goes out...
                              its comming along it seems...
                              i repeated these results 3 times im going to do it again after work if no storms move in...
                              • #90
                                Ive modded my circuit again and went with and air core transformer i wound myself as of now. i tuned it before i hooked up the rectifiers as to get the max current by removing windings from primary or adding them and the same for the secondary after i squeezed as much current as possible through it i hooked up the second part of the circuit which is a modded version of what ive been using ... i can now run an led array of 24 leds at full brightness continuously ... no extra power source just the antennas but ive been trying to pull a larger load like incandescent bulbs but they drain the capacitor to 0 the only way i know of as of now is maybe another type of low voltage spark switch across the cap to the bulb with maybe some type of transistor or thyristor maybe...dunno yet but ive attached a rough copy of my setup check it out let me know what u think...and any suggestions will be greatly appreciated ...
