Radiant Energy with Piezo Electrics
  • Radiant Energy with Piezo Electrics
    So I was playing with my Piezo speaker that I picked up from mouser.com and noticed that no matter where I laid the piezo for no matter how long it seemed that I would get some type of voltage. Of course tapping the piezo would raise the voltage but it would hang for a second and slowly drop and sometimes give a rise back but just to fall again.
    I’m sure sound waves are a type of radiant energy, therefore it opens many possibilities. I’m thinking of a panel full of piezo’s just like a solar panel, to collect the radiant energy, but unlike a solar panel it can work at night. Even with the slightest breeze would shake a piezo, so I guess a piezo panel is a solar panel and wind generator in one.
    Since a voltage can always be a constant we can put the peizo next to the output of a speaker of the same size with a circuit that puts out a constant wave that hits the piezo and it should output more power then what took to get the speaker going (crazy thought ).
    Has anyone taken a dip into these idea before?
    Piezo Crystal and Earthquakes
    Piezo crystals are very cool. They release electricity when stressed.
    10 mins before the 2008 Sichuan earthquake in China, there are photo's of clouds in the area that had strange colors. Like the kind not seen before.
    One research report I read claimed that the area is rich in Piezo crystal rock and the compressions before the earthquake released energy that caused the clouds to change colors.
    Fluxite.com
    Pure Energy
      Looks like HAARP to me.
        it would be interesting if...
        What if you made a connection to the piezo that allowed it to both conduct sound and wind as well. Blades that are ultra thin would flex pretty easy and allow for both wind and sound transmutation to voltage potential.
        These blades would be permanently mounted to the piezo and will easily vibrate with just a breath of air. Since all sound is movement in the air it would do both very very efficiently.
          Fluxite.com
          Pure Energy
          you have focalized an good issue.. I'm pretty sure that energy receiver of Tesla working using GALENA.. with GALENA you can create an simple and good receiver and at the same time accumulated and released energy... I suppose that also Moray have used that crystal.. some infos here... http://peswiki.com/index.php/Directory:Tesla's_Pierce-Arrow .. You need ONLY an good source of RADIANT ENERGY .. Regards
            That web link is in italian but the images contained inside are clears and are good for your mind, Trasmettitore a spinterometro - Wikipedia
              English version : Spark-gap transmitter - Wikipedia, the free encyclopedia
                I did research some time back, into the tesla car subject. Not sure if its true or not.
                I do think tubes can be used to create a diopole. Tubes can also carry a lot of current that would be required to power a 1932 Peirce Arrow.
                Fluxite.com
                Pure Energy
                  Fluxite.com
                  Pure Energy
                  I am currently working on the power source he engineered for the Pierce arrow. Since all great inventors has a style and a flow to their inventiveness i figured I would go the same path as Tesla did. I have a plan already going and am about to start putting together a small version of it soon.
                  It should look like this:
                  http://i128.photobucket.com/albums/p...acircuit-1.jpg
                  The end of the circuit is the tough part and I think that transformer that goes to the load should be the load itself. See if that helps you...
                  The circuit has design flaws. The first transformer is a normal step up transformer. The second transformer is a special No core oil filled transformer with a bucking primary wind. The second layden jar is optional. The third transformer can be used but not in that configuration. If it is in that config then you need to have a tube chopper like Tesla most likely did between the receiving antenna and the third transformer. There is also something with static shielding from the second transformer to the antennas as well.
                  To better explain the second transformer is the key of this whole setup. This transformer in all intense and purpose is actually two devices in one. It is a layen jar in itself. the outer case is shielded with aluminum or in the case of Tesla he used zinc. inside the dielectric of oil are the transformer coils with no core. The primary is a split bucking primary with a long secondary or connected secondary. The original design of this special transformer is from here:
                  "Experiments with Alternate Currents of High Potential and High Frequency"
                  Figure 3 specifically.
                  This setup is very very unusual if you read the description. It seems that this is the method that Tesla used to power the motor in the car and I have modified the original diagram to show how to take advantage of the flow of charges that this system allows. Pay specific attantion to how the discharge is amplified as it goes from the larges surface area to the smaller when he talks about the effects of this system in action. AS you read down in the descriptions he talks about one wire transmissions of charges and how he got it to work.
                  I believe the tubes that are mentioned actually chop up the direct current so it can not short out and burn everything after the special transformer, this is also called run away mode. I believe this was a way to control the process directly instead of the traditional gas pedal. The motor probably ran all the timer and he just used the clutch to engage or disengage the system of the transmission from the running motor. I also believe he included a bypass to let the charges escape and regroup to fire on the next pulse. This bypass also included a small rod for an antenna. Since it was said he inserted two rods into the box then this would be why. I have not included the bypass yet and am still working out all the details. Of course the picture I referenced is actually my first attempt to figure this out. It is not the newest figure of the current setup that I am working on. I am waiting to complete the circuit diagram before releasing it.
                    Tesla Car
                    I don't want to hijack the thread. Do you have another open thread to discuss the Tesla car?
                    Fluxite.com
                    Pure Energy
                      There's quite a bit of info available regarding piezoelectric energy harvesting.
                      Google
                      Piezo Energy Harvesting Circuit
                      The self powered Piezo Energy Harvesting Circuit collects intermittent or continuous energy input from the piezo generator and efficiently stores their associated energy in an on-board capacitor bank. During the charging process, the capacitor voltage is continuously monitored. When it reaches 5.2V the module output is enabled to supply power to an external (user) load. At this point 55 mJ of energy are available. When generator energy input is high, the output voltage remains ON continuously. Capacitor voltage is clamped at 6.8V. If external power demand exceeds generation, the output voltage decreases. When the output voltage drops to 3.1V, power to the load is switched OFF and is not turned on again until the capacitor bank has been recharged to 5.2V. The circuit accepts input voltages from 0V to ±500V AC or DC and input currents to 400 mA.
                      A Phenomenon is anything which can be apprehended by the senses.
                        That circuit is similarry to other present on internet, no difference.. The only problem is that configuration don't produce electricity because you don't produce radiant energy!!
                        Isn't sufficient use an capacitor and one coil for produce extra energy.
                        Radiant energy is RELEASED if you force nature, only spyke do't are sufficient for produce stable and costant energy. You need an radiant energy source. Tesla create free electrons from air, Gray probably use nitrogen inside tube.. in all case all inventors use atomic energy released from nature. Im pretty sure that all use crystals like galena as natural generator and battery at the same time, probably (need to test) if irradiated with radiant energy and used in parallel with capacitor can created an large amount of electricity.
                          Radiant energy and element..
                          Radiant energy in fact is around to us.. The Sun is pure radiant energy source . Tesla project was create artificial transmitter/receiver radiant energy system.
                          Radiant energy is formed from alpha particles and is a synonym for ‘radioactive decay’. For example germanium emits electrons when is irradiated from alpha particles. That can be an simple method for convert radiant energy (radiation) directly into electrical current without create neutron reaction and probably that solution was used from Tesla, Moray, Gray, etc.... Is clear that inside Tesla patent is "lost" an component key , with one coil, one capacitor and one transformer you can't create a lot of electricity that can run an car.
                          • #14
                            Yeah...
                            Fluxite.com
                            Pure Energy
                            I am currently working on the problem in this thread. http://www.energeticforum.com/renewa...-negative.html
                            Since this has to deal with splitting the positive, it goes along the lines of that thread.
                            • #15
                              So you built the system? Nice.. What was the results? Got anything that tells me facts and not your opinion?
