1.5V Stingo Lights Neon!
Here are my latest test results.
So, I swapped out the transistors in my Stingo. And I tested my old TIP2955 and TIP3055 transistors on my multimeter with the hFE function:
The NPN test made sense. I got an hFE reading of 062, which fits the spec, but the PNP measured 125, which doesn’t make sense spec-wise, given that the DC current gain should fall between 20 and 70. But the readings I got for brand new ones were very close to the readings I got, measuring 069 for the NPN and 129 for the PNP. So I’m concluding they are ok, and not about to blow.
Based on what Sucahyo has been recommending lately, I also decided to pair a TIP32C with a TIP3055 for the replacement transistors.
My 12V tests with Toroid coil and Car Coil yielded results identical to my previous ones. It just helped clarify things. I think that the toroid coil would make a respectable 12V battery charger, given it lights a neon brightly.
Inspired by JiffyCoil’s and Skaght’s 1.5V results, I decided to run a 1.5V battery test with the toroid and was pleasantly surprised to see it oscillate well and light a neon bulb:
Here is a scope shot sampled from the PNP base, which shows oscillation of about 1KC:
Here is a scope shot sampled at the output, showing very sharp, 90+V spikes. The duty cycle is about 1.2 %:
Now to catch up on what has thankfully become a very lively thread!...
- Godfrey
- Godfrey
