Sucahyo, i do not know why two 32 circuit does not work, but i tried
today different combinations with two tip 32 with bingo too, and
it does not work too...I tried that cascade (base of first 32 to collector
of second, emitters on positive, but the problem is where to connect
collector of one of the 32)...
If both collectors(or even one collector and
one emitter) go to base of tip 31 it does not work at all, and if i put
one of the collector/emitter to the negative than i got some result, but
bad result, and if i connect it to the collector of tip 31 that is the only
combination that works, but with less efficiency than in normal combination...
So, i really dont know how you do it...
Concerning your stingo motor, it seems to me that your motor just
drains too much, since my three Bedini window motors drain from 35 to
80 mAmps, and your stingo-hard disc drains 350/700 mAmps, and two
of mine bedini window motors are much bigger and heavier than one
little hard disc rotor, and they still drain 5 to 10 times less current than
this stingo hard disc motor...
So i do not know what is the advantage of this stingo motor in
comparison with bedini window motor for example ?
You did not recognize not single one transformer on that UPSs ?
Cheers !
Cheers !
