Stingo Solid State Battery Charger
  • Hi Guy's, Here is a pic of a rough tower coil I whipped up last night. It has three joins. I made it from an old quadfilar coil. If it works good i'll wind a much better one.
    http://9xhe3g.bay.livefilestore.com/...001.JPG?psid=1
    It's 450 turns .5 mm wire The primary is 13 turns 1 mm wire I have two of those if I need them.
    I plan to use a stingo with it's transistors mounted on this heat sink- And pulse a car coil, then put the HV through the 13 turn primary around the base of the tower.Bottom wire from the tower will go to ground the top one should be hot. For lights. I hope.
    Hope to build the Stingo tonight.
      Plenty .
      That make me reminded to previous question about sine wave and square wave output. What kind of electric appliance require sine wave? Have you try it on electric iron yet?
      sine wave/square wave...Sucahyo dont you know i do not have oscilloscope ?
      electric iron ? no, i thought i should try it on my solder iron since i use
      the most often 15 W solder iron, and 15 W is also value of that testing
      bulb in my pictures...
      But i suppose electric iron is a big consumer, what do you expect of that
      specific experiment ?
      Farmhand i am anxious about the results of your announced experiment !
      Inform us about it as soon as you find out some usable infos !
      Good luck with stingo assembling ! It should be easy and quick job since it
      is very simple circuit !
      Cheers !
      "There is no love without prayer - there is no prayer without forgiveness because love is prayer - forgiveness is love." Virgin Marry - Immaculate Conception ...The geologists say it's not in the ground, the airforce says it's not in the air, the astronomers say it's not from space, so we are running out of options...
        Hi guys JT is said that it emits RF does Stingo emits these frequencies? cause certain persons feels headaches with these.
        I and Godfrey had attached stingo on our bed everynight for the last few months now. For sleeping aid.
        I am certain that I can use stingo to produce headache too. It change with how you connect the secondary, or where you connect terminal . If you seen my last stingo motor video, that is also an attempt to produce extreme headache, and it did if I turn it clock wise. Not for free energy research though.
        I agree with 7imix about coil can change result. For the past few weeks I have been trying various coil to try to get the result I first get for sleeping aid use. Then I give up using toroid and use my first coil. A 12V-0V-12V/240V transformer. with the 240V part shorted. My soon sleep in minutes lol.
        Originally posted by sniky View Post
        Now that you mention that, with the stingo slayer exciter I felt some headache, but a couple hours after "I left the building" so I didn't thought they are related....
        The way you connect the HV part really concern me:
        "one end of the L2 coil to the base of the NPN transistor."
        I consider that connection may produce headache. I will prefer to connect on end of L2 coil to the positive of source battery. This is my feeling when I did experiment with car coil as corona maker.
        While I still had 12V battery, I run stingo on my office as long as the battery last for two weeks. 4 of my friend mention good smeel, good feeling. There are mass flues infection that time. Seems to not infect my part . If the corona maker was durable, I would keep using it.
        Stingo or any other electronic circuit can produce good and bad effect, please be carefull.
        That is nice . Will look forward for your result .
        I know, my point is I read that some UPS manufacturer boasting that their line up produce better sine wave. I forget why that is necessary.
        electric iron ? no, i thought i should try it on my solder iron since i use the most often 15 W solder iron, and 15 W is also value of that testing bulb in my pictures...
        I read that heater work best with AC. Maybe inverter with square wave will produce much greater heat than sine wave. your solder is better test I guess, because there is no thermostat there.
        See if you can compare the heat too... thanks .
          So what is the best for health on circuits including stingo and JT to make it to lower frequency? But when doing this it gives less BEMF I noticed. Although it's true I experienced that in low frequency batteries charge better.
            Not frequency, but signal sharpness, abrupt switching, fast signal fall time. I believe joule thief produce headache because of dull switching.
            My corona maker run under 1000Hz, my sleeping aid run between 2KHz to above audible, it still produce nice feeling...
            Adding connection to a bucket of water also help. Must not connected to ground. Connect it to output positive. This will not only produce more good effect for health, this also increase circuit output.
            I don't know what you mean by less BEMF, I found that there is sweet spot, where the circuit have the best COP. So I always tweak potentimeter to get max output. Is not always at the minimum or maximum, it is usually in between.
            • Stingo
              Sucahyo what exactly do you mean connect it to output postive?
                I run stingo on my office as long as the battery last for two weeks. 4 of my friend mention good smeel, good feeling. Stingo or any other electronic circuit can produce good and bad effect, please be carefull.
                I feel exactly the same way about American Beer!
                • sucahyo
                  The cap dump technique also dump the charge at "slow" rate of 2 seconds each.
                  What is this "cap dump technique" you are talking about ? Sorry I am to lazy to look for it in past posts right now.
                  FRC
                    Here:
                    Try it and see if you can notice current or voltage increase.
                    Although on stingo you may observe some voltage or frequency change too if you touch other part....
                    Lol, I do believe that we can even use stingo to make beer tastier, never try though ........
                    It is not mentioned here, it is method of charging battery by storing the radiant charge to a big capacitor first. After the capacitor is full, it then charged to a battery via SCR or mechanical switch.
                    • Hi Guys, I got mixed results with my tower coil experiment, it worked fairly good for wireless lighting a 280mm tube and a cfl no problem up close but no fantastic or spectacular output or anything, yet. Lights neons ok from a short distance and such.
                      Nothing overly exciting to report except that my Stingo worked first go. And performed very well.
                      Surprising. But not Amazing .
                        Lol, I guess that is what happen if you get too much very good result on your previous one.
                        Isn't you already get the expected result? or there is something you don't achieve?
                        What do you see as amazing now?
                        I have been trying to get Joule Ringer COP, with stingo, lighting LED with only capacitor. Maybe you can achieve it with tower coil?
                        • Haha, i'm always surprised when things work first go for me sucahyo.
                          But I wasn't amazed because it was Stingo.
                          I might set up the tower coil thing again tonight, if I do I will take some video.
                          I did get a better result for lights thats for sure. I still need that HV cap for
                          real good effect I think, a small spark gap and a HV cap. But I don't have
                          the cap. I think i'll try to make a variable parallel plate capacitor from some
                          1.2mm aluminium plate. Later on some time.
                            Great, I will look forward for your result .
                            Agree that it may be better to make our own HV caps.
                              The disposable cameras used in the Joule Ringer have some nice high voltage caps in them. They probably have a nice Q as well (fast discharge) because they power the flash.
                              But making our own capacitors would rule. I want to try.
                              • Originally posted by 7imix View Post
                                Thanks i'll see if i've got one.
                                If you have a look at Figure 4 of Tesla Pat. 568 178 , I think that would be the easiest best way to do it. I'm thinking glueing a plastic bolt or something to the back of one plate for adjustment, that drawing Fig 4. Shows the cap plate's on the secondary as a regulating arrangement I think. But since i'm using a car coil output on the primary thats kinda what I think I need, but smaller and closer together. I think I need to try it, see what happens.
                                http://www.pat2pdf.org/patents/pat568178.pdf
                                Or if you try it first, make sure your video is taping, so if you get zapped when you wake up you will be able to find out what happened.
