Wind Power
  • Wind Power
    The power of the wind can help in saving us loads of fossil fuel energy and the planet itself. With the world demand for fuel energy on the rise, there is a slow shift towards green energy. Green Energy is the renewable energy that does not lead to environmental hazards like global warming and greenhouse effect. The renewable sources of energy include the wind, water and the earth.
    The wind energy can be converted into electricity using a wind turbine. A wind turbine is rotated using the blowing wind, created by uneven heating of the earth surface. The blowing wind flows over the air foil blades of the turbine and drives the shaft connected to the generator. This leads to the starting up of the electric generator and production of electricity.
    The wind energy industry is growing at the rate of 28% a year. If the wind power investment, the wind capacity will double in every three or four years. Being the cleanest and cheapest source of energy, wind energy has found many takers in recent times.
    vertical turbine
    You need to install a **** load of these on houses and businesses and pay me the royalties:
    YouTube - high speed test
    The power is taken off of perimeter magnets and stator coils.
      Wind turbine is a rotary device that extracts energy from the wind. Wind turbines comes in many shapes and sizes. Normally there are two basic types pf wind turbine horizontal and vertical wind turbine. A shaft is connected to the wind turbine which rotates with the help of wind which in turn connected to the motor, energy generated is converted into electricity with the help of the motor. There are many advantages and disadvantages of using wind turbine.
      renewable energy | wind power | wind turbine | wind turbine uk | wind power uk
        I have a problem with wind energy as it is "rolled out" in the Netherlands.
        They build very expensive off-shore parks. Where we as "people" can buy green energy from.
        For me it's the same "show" with the same companies getting the government and EU subsidizing, and charging and taxing the people for their power demands.
        My problem is that it will not make energy cheaper and everyone is still depended on TPTB.
        I want personalized power (solar, wind, ???) and any excessive power could be (if you want) be transferred back to the grid.
        If there is a failure somewhere, it will influence less people and it will be cheaper at the end, you will be your own power supplier.
        I do think they do not want that, they like you to be depended and they like to be able to control the switches when they want too.
        Although it is possible, solar panels , wind turbines etc to put on your roof or garden, it is not that simple in the Netherlands. You have to get permitts for doing so and they do not grand them easily. But one or two individuals is not enough, they should design the entire national power supply to a personalized system.
        I guess government interests are not civilian interests ..
          High altitude wind power
          Howstuffworks
          a promotional video
          High altitude wind power -- amazing!!!
