Pendulum generator
  • Pendulum generator
    hi all
    i have tried Pendulum to generate electric
    i used 1hp motor 1450 rpm connected to gearbox 1:16 so the output about 85 rpm......other side 1kw wind turbine with 500 rpm connected to gearbox 1:10 for increasing the speed
    test 1 with no weight attached with Pendulum ( load 1kw)
    YouTube - free electric..Test 1
    test 2 with 5 kg attached with Pendulum ( load 1 kw)
    YouTube - free electric..Test 2
    now if i tried push the Pendulum from Edge will need less torque..but what about speed? do i need more speed?
    Have you tried this guys method?
    http://www.energeticforum.com/renewa...-donation.html
      wind tuirbine
      Originally posted by egyptian inventor View Post
      hi all
      i used 1hp motor 1450 rpm connected to gearbox 1:16 so the output about 85 rpm......other side 1kw wind turbine with 500 rpm connected to gearbox 1:10 for increasing the speed............................................. ................................................[/SIZE]
      Hi egyptian inventor,
      Just erect the wind turbine-part and forget the rest. Your proposal is like running an electric motor off of a solar panel then driving a generator off of the electric motor and finally using the power from the generator.
      Assuming a 90% efficiency for the electric motor and a 90% efficiency for the generator, you will only get 81% of the solar panel's full output ! Does that make any sense ?
