@ Sucahyo and All:
The rods do react to crystals. Crystals can interact with mind energies, also. I use them mainly for healing purposes. I have not seen any negative effects from pyramids or crystals in all my years of being around them. That does not mean that there are no negative effects from them, but I personally have not experienced any negative effects. There are different opinions as to what is Negative, also. Energy is neither good nor bad. Is lightning bad because it can kill you?
or Sunlight bad because it can burn you?
The picture of the pyramid with the crystal capstone is very interesting. The real capstone was stolen off of the Great Pyramid, it may have been made from quarts also. But the Great Pyramids purpose was not the make electricity.
The trick is to tap the vortex, and get some power in return. But HOW???
My crystals are not just laying around collecting dust, they are pointed towards me... and are also in the direct Aether field of my 6 foot pyramid, redirecting the energy towards me, as I sleep under them nightly. I can tune in directly to them, as they seam to help in my visualizations. I wish that they would also help me figure out how the make electricity, but for some reason that information is not being made available to us. I feel that it is being BLOCKED.
There are people all over the world trying to figure out a way to produce electric power but so far, nothing... this is no coinsidense....
Adams -Bedini type of electric production, (passing magnets by coils), has been around for many, many, years.
Although I was just kidding, I would love to see the water in the pyramid glow green...
So, if water is swirled around by a motor to make a vortex in the water, how it this going to
help to produce electricity?
I wish that they would also help me figure out how the make electricity, but for some reason that information is not being made available to us. I feel that it is being BLOCKED. I will say how you can make electricity, but again it depends of the pyramid and how it is made.
About crystal negative effect, I found that my wife is not compatible with crystal. So I try not to have crystal with power in my house. I put them in my office.
I beleive that crystal is the one responsible for "frequency adjusting" effect of orgonite. Where some people would actually get worse after using orgonite for few days. I think this happen because of compatibility problem, for various reason.
For health use, I believe there are life and sleep crystal. I believe I have both and I can observe the disadvantage and advantage of the live one. But in my current knowledge, I can't neutralize the disadvantage. The sleep one having no direct effect but still seems able to manifest thought.
I consider swirling water, or water, or crystal, or pyramid as the source of orgone energy. I highly believe that there is a way to convert orgone energy to electricity. Many orgone device give jolt to people like the effect of high voltage. It is possible, but no clue how.
Here is photos from friend who swirl water and observe strong energy, which can be calm or energetic depend on rotation, very simple, replication by Tony Geron, bucket with hole at bottom:
Electricity will be produced if the energy can be converted with something.
Very very interesting . Have you tried sleeping over the pyramid?
I held a gold ring on top of a 12 volt battery terminals, with my left hand, and held the rod in the right hand. Although I do feel the rod reacts to the polarity between the + and - terminals, the rod will spin (strongly at times), in a complete circle counter clock wise, in the same direction on both terminals.
Some possibility:
- energy greater than battery exist on your house, or your floor
- the rod produce influence your gold ring dowsing
- you are highly charged so the battery pole always seen as one polarity for you
I experience that kind of thing when:
- I put the battery on the floor and the floor emit energy (marble)
- I use ring that has crystal, and the crystal happen to has spirit
small battery is weak. Higher capacity battery would produce stronger reaction.
Sucahyo and robur:
Thank your for your replies. Subtle energies are often hard to pin down and understand. I think this happens with crystals, and also with the energy from pyramids. Most people would not notice either as having anything to do with energy. And some like your wife may not be compatible with them, while others can really get a lot of enjoyment having them around. I am surrounded by them at home, and have not noticed any negative effect from them yet, but on the contrary they inspire me.
It is one spirit that reads those subtle energies, but most people can't read them at all.
@ robur- If you know how to obtain energy from a pyramid, please let us know. We are all ears... that is what this thread is about.
I'd like to ask you how do you "know" that it will work if you have not tried it, as most attempts at this have not really worked. At least not in producing more than just a couple of volts.
Conventional science says you cannot generate anything at all. Are you expecting KILOWATTS from a pyramid?
It seems so to me. It seems to me that ''a few volts'' is not an option.
I am sorry I cannot tell you you can run yoour house tomorrow from a pyramid or arrangement of cones because it won't happen tomorrow.
I am not a sort of person who would mislead people who want to run their houses on it. I am here to share information I have and I am sorry if this information won't create a kilowatt of power for a few dollars of parts. This is a lie which free energy SCAMers spin to people to sell them worthless plans for hundreds of dollars.
When you say energy from pyramid you mean electrichal power to run your home or Aether energy to charge water plants or heal?
Please would you clarify what are your expectations from it?
Thank you
Thank you
I'd be pleased to get enough electrical power to simply run a small light continously ~ simply powered by the pyramid.
robur:
Thank you for your reply. Whatever you would like to share with us, is fine.
I personally tend to evaluate the easy electric output that can be obtained by using solar panels, compared to anything else. I have not found anything that will even come close to supplying the electricity that can be had by solar panels. The problem with them is that they also require a battery bank. All in all they are still an expensive way to go. I would like to see a device like the TPU, or the Mitts Dome device that can even start a car. Both are small portable devices. Voltage Only devices are not practical.
We have been playing with devices that don't produce much of anything, and I feel that time is running out. Less than two years left.
Look at how many record number of earthquakes there have been just in the last month of two, world wide. And also the biggest solar flare in a long time.
robur- as I mentioned before, anything you'd like to share with us, is welcome. Maybe we can even help to make your device produce even better.
My friend Otto from Zagreb died, taking his TPU device information with him, even though he left some of his notes, so did Tesla. But notes are one thing, and a working device is something else.
In case you are wondering, my pyramid is made from 3/4 inch copper tube, 2 meter base, with welded corner joints.
Both Sucahyo and I as well as others have been working on alternative electrical devices for some time now. I worked in the electronics assembly and production business for several years.
I have been sleeping inside the pyramid (this small 2 meter one) for almost 30 years. I have also made pyramids of up the 8 meter bases as houses, green houses, or tents, etz...
So, I have been at this for a long time, close to 40 years... and yes I am looking for something that will produce enough juice to run my house's electrical needs. But a couple of free volts is still better than no volts at all...
robur:
I guess you mean the ''doom and gloom''theorys about 2012. I do not want to think we go down the drain in 2 years time. I don't think we will.
Anyway, if anythng nasty happens here isn't time anyway to create several kilowatt power generator.
I BEEN trying for 2 years with this and a lot of years before that.
I prefere to ignore the ''end of the world'' theorys because this can make person very ill and I ill enought already.
robur:
I prefer to prepare for what is already happening, as we barely made it through this year here. It would be a lot to ignore when the lights go out. But, I know what you mean... that is one option, but not mine. I am seriously concerned about becoming energy self-sufficient, and working 100% towards that end. That does not mean that whatever device you have in mind is not important, even though you have not mentioned much about it, yet.
Maybe most people think that nothing will happen, look around.... the warnings are all around us, most will chose to ignore them. Not me. I am worried sick already, and wondering why we can't come up with a device that WORKS.
In anycase, time will tell...
NickZ
Thanks NickZ, it is possible that the crystal enhance your ability.
I wonder if creating extreme energy polarity is possible. How much the water in the pyramid increase energy? Have you tried to dowse the electrode at different height but not connecting to the pyramid? So you dowse from outside pyramid to see if the energy from the inside the pyramid can be transfered to the outside?
Maybe we need something round on top of the pyramid, just like video bellow? notice the snow fall, shared by friend. YouTube - BRONZESMITH NEW ART PIECE
Sucahyo:
Interesting links... you found.
I will devote more time to the subject of polarity. I think there lies the secret of tapping the vortex energies. It may be simpler than we think, although still hard to understand, and harder yet to implement.
I will continue with the test on the pyramid, with the rods as well as the voltmeter.
I appreciate your attension, and your input...
robur:
I also appreciate your point of view, and hope to hear more of your ideas.
Sucahyo, yes, maybe crystals and pyramids have something to do with it. Maybe that's just what happens when one is around them...
Quickening...
Originally posted by Maybe we need something round on top of the pyramid, just like video bellow? notice the snow fall, shared by friend.
[url=http://www.youtube.com/watch?v=9Ao3iNL8q_0
YouTube - BRONZESMITH NEW ART PIECE[/url]]
Main area of Aether is at King's Chamber. Amplifications should be applyed here. When Aether is very active it gives off portion of it's energy in form of beam which passes thought apex. It depends how you arrange it. If you place your power up in the king's chamber then apex would have the most pwer as balance of power shifts towards apex.
If you got something slike Naudin's TEP from 1997 It area of power is AT GROUND LEVEL and slowly diminishes towards Apex. In other Russian pyramids the point of power is strongest BELOW GROUND in the area called lower chamber. Not queen's chamber - LOWER CHAMBER.
Originally posted by Maybe adding this:
[url=http://www.8ung.at/mhotwagner/researchforum/forum/viewtopic.php?f=37&t=67
Etheric Research Forum • View topic - Double Vortex[/url]
This is interesting. Even a little funny. No offence to the creator but egg isn' the best shape. I consider Cone to be the best. No offence, please to anyone who doesn't like it. Kirlian photograph excise me if I misspelled it which shows 2 beams spiralling from a pyramid where tesla coil stands as power in this pyramid centre of power would be apex.
You can get DC/AC from a pyramid, but it wont be a lot. I mean comon pyramid like you use to make. To get more you need to input some to accelerate Aether flow.
Thank you
I wonder what method they use to get that picture. Also with picture where many small pyramid produce vertical smoke . Because no other kirlian photos I see is 3D like on pyramids photo with vortex.
Hello everyone i saw this post and remembered that a friend of mine had done some extensive research on the pyramids at Giza. After spending some time talking with him he let me post his patents and personal papers of his.For the longest time no one person could make sense of these structures until had talked with him for about 11 hours of his findings the Pyramid finally made some sense to me without having to wade through all the previous beliefs. His name is Gamal Elfouly and the Great Pyramid at Giza was his playground as a child in Egypt he has pictures and insights to the structure that has been closed to the public for many years now. His work can be viewed here Pyramidal Generator - Alternative Energy Show and Tell
His work is continuing his own expense and his desire is that others may view what he has a firm knowledge of. Cheers Spodie Odie
Guys:
There is an opposite charge in the area 1/3 the distance from the base, under the pyramid.
Like a negative polarity kings chamber area. Since there is a vortex spinning one way on top, while the vortex is spinning in the opposite direction, below. The manipulation of those two charges, may be the key. And as Robur mentioned, may take additional input, to control, or accelerate the magnetic flux lines.
There is lot more to this... the whole Giza area, is only the tops of a huge underground complex to be discovered still. Watch what happens there in the next two years. Don't say that it is all a coinsedence when these discoveries are made. I'll still be around to remind you when it happens. On the other hand if I'm wrong, I'll be the first to admit it.
Pyramids and crystals do resonate according to the fields that they are subject to. Resonance will make up to any loses.
The vortex in the kings chamber can alter the time-space factor, like a multidimensional Stargate bridge, and that was what the priest-scientist then in charge were after. The power of the vortex also kept their bodies from decomposing when they went into the Death Trance. Several days later (up to as many as 40 days) they would then reactivate their bodies, and walk out the door.
You will most likely not hear about this from ANY OTHER SOURCE, and, is not my imagination...
The only way to travel in time and space is to dematerialize the human body form, and convert it to an energy form. But still maintaining the personal DNA code intact. That DNA code is then sent out like a lazer beam, through wormholes in the fabric of space. The energy forms DNA is then reconstituted to reform and resemble the original physical body, by the absortion of Aether, and a new body is made from the surrounding Aether solution from that area.
We have seen something like this on Tv... Stargate, Contact, Alien verses Predator, etz...
I think that something similar to this is what happens with space travel. Demodulation, and remodulation. Just like a radio signal can be sent, and received on the Moon or Mars.
Tesla was thought to have sent a human body through space here on Earth. That was said to have later reappeared about one mile away. But died.
I think that in a similar way anything and everything can be produced, out of thin air.
If we were to be shown just how to do this, imagine!!!
Sorry for my rantings...
