Pyramid
    I wonder what happen if we wrap the outer side with paper. Orac - pyramid....I was thinking about that but came across W. Reich note saying that any more than three layer orac should not be used by inexperienced people. Also, I should clarify what I said about metals; they absorb energy at first but release and reflect. Not sure if we actually need a multilayer pyramid. I'm waiting for some copper sheets. As soon as they arrive I'll be making one or two and run some tests. This theorizing only(mine) and looking for answers gives me headache
    Any idea for CW or CCW winding?
    Not yet
    I highly believe flat spiral coil will polarize energy, based from freezing them on ice test.
    Yes, I agree. Pyramid collect more energy if exposed with sun light or moon light.
    I kept thinking about spirals, ferns, fiddleheads (plants), nautilus etc. You know where I'm heading My question was WHY this is happening? Also, many of those great designs were used throughout centuries in various man made structures (Did a man stood behind a drafting board and designed each and everyone of them? - I doubt) Was this just an admiration or fascination or there was actually a purpose? We know the answer don't we
    I know and did various experiments based on the resonance. This can be very powerful effect but also, when done on very subtle level allows to interact while using even more subtle energy. I was going through fact such as estimated weight, Pi, Phi, location etc. of Great Pyramid and I believe it was designed to resonate with Aether, just like everything as we know it. Certain shapes such as spirals, cones but also 2D can "disturb" Aether and cause to flow or create 3D forms as a response. I think what we need is to find a way to create interaction within local Aether/Orgon/Zero Point Energy (whichever name we want to use it) field but in certain way so Aether will respond creating vortical flow/motion and we need to guide it onto desired path. Spirals are good, maybe conical spirals are better? Aether naturally travels on curves not a straight lines.
    I think neo is not good too. People from different community report some bad effect of neo magnet if placed on device that manipulate aether. I was thinking of employing them to magnify energy for the purpose of measuring eventual electrical potential, not for health related purposes. I think crystal can replace neo, and I believe flat spiral coil too or SBB coil: Yes, crystals may be even more powerful as long as their placement is correct.
    From my experiment, I conclude that that coil above will emit male energy to viewer direction, to you.
    I found alumunium produce male energy which currently not what I need.
    Good luck with the test .
    How about this meter:
    Experiments with the Life-Energy Field Meter Cannot afford atm.
    I think even electroscope should give some reading. I'm going through John Keely and Dr.Wilhelm Reich notes, research. Looking for more clues. I found some interesting things, probably known but I'll try to summarize them all and see if we can draw some conclusions - hints.
    Vtech
    General D.Eisenhower
    http://www.nvtronics.org
    • Originally posted by blackchisel97 View Post
      lol. I think you should try. Especially since you can detect/see energy.
      Adding layer said to absorb energy around your house, including the bad one. But isn't your pyramid doing the same thing and you already solve it?
      I come accross something simple today, called "moody coil" It is just one loop of coil that can make plants many meters away to be affected too.
      And then a way to neutralize "dirty electricity" with just few turn of insulated wire and then short it. Read Frank Moody article bellow:
      October 2004
      I read there are health problem with magnet. But some people who use magnet do observe change of energy flow with magnet. They use stack of 10 neo.
      Cannot afford atm.
      For electroscope, here is how the Correas use it:
      we do likewise with electroscopes - not just measuring the leakage rates of negatively charged electroscopes, but also the seepage rates of positively charged ones; and not just inside the accumulators, but also outside of them. We also employ identical pairs of such electroscopes to study atmospheric conditions in order to isolate the heretofore unstudied and undocumented midday phenomenon that bring about the arrest of both leakage and seepage.
      The electroscopic anomaly consists in the fact that charged electroscopes discharge more slowly inside an ORAC than outside of it. As we came to discover, this slowing down of the electroscopic discharge occurs independently from the polarity of the charged electroscope and often reaches complete arrest of the discharge.
      • Just found something interesting regarding unhealthy black line with spring bed springs.
        Is your bed making you ill
        I had been puzzled by some of these black lines, which seemed to enter the bedroom, pass through the bed, then abruptly turn and exit the room, almost as if the bed itself was the attraction. Some lines seemed to prefer to come in across the foot of the bed, turn at right angles and run the length of the bed, as if tuning into a line of these springs.
        Incidentally, I have already mentioned that cats prefer to sleep on these black lines, particularly where the overgrounds focus into the spirals. Recently, I read that some cats can tell when their owner has had an accident or some other severe form of trauma, and refuse to lie in their usual sleeping places. Perhaps they use these black lines to "tune in" to their owners at a distance. Since spiral bedsprings attract the noxious energies from underground fissures (and streams), then a line of them must be an obvious method of warping them away from my bed space. I made a simple 6 inch spiral of light gauge fence wire, and found that not only did it divert the black line, it actually stopped it coming in to my bedroom in its tracks.
        Now that I recall it, my bed is spring bed, and my cemenite that I currently use to help sleep contain a bunch of coil in random position .......And now my families who used to sleep easier at sponge bed now also sleep easier at spring bed....
        My intention to post this is the possibility of using simple geometry to attract energy. Something like explained in:
        THE GOLDEN MEAN AND THREE BRICKS
        Some time ago I observed that when three objects were placed in positions relative to each other that the individual energy fields of the objects interacted 'in various ways. When placed in alignment and at certain distances apart the three circular fields disappeared and instead a straight line of energy was formed with radial lines going away from each object. The energy dowsed in these lines is mainly detrimental in nature.
        I also observed that when three objects were set in a certain triangular form that interaction again took place with the individual energy lines disappearing and straight radial lines of energy coming away from the objects, but in this case it dowsed as being mainly beneficial.
        So if we want male energy we put the coil in series, and if we want female energy we put the coil in golden mean triangle. Maybe we can create extreme polarity incorporating both.
        Maybe some coil in series at 2/3 height and some coil in golden ratio geometry at 1/6 height.
          [B][COLOR="Purple"]
          Yes, certain shapes can interact with Aether better than others. Triangles will induce vortical response, spirals will amplify and guide, circles will draw energy from outside towards its center. Now, if we use a combination of those shapes.....
          • Guys:
            The guy that built the big 30 foot pyramid in his back yard, (I forget his name), gave up after he was electrocuted and thrown 20 feet. That sounds very fishy to me. Still he has been the only one that CLAIMS that the pyramid can produce ALOT of power. But, wheres the proof!
            He just walks away from it, and tears it down. Right! I would have to see it to belief it.
            Now, I can't even find his videos.
            As far some of the other experiments on pyramids are concerned, I think that you should also see this:
            YouTube - Mythbusters 3x14 Pyramid Power (2 of 2)
            Could the missing Capstone have really been a giant crystal, that can be activated to power the rest of the entire Giza pyramidal geomagnetic complex. Including some type of wireless lighting system.
            Something that important should have left some clues.What ever was going on, it was no small insignificant thing. But, their government is not showing or telling all they know.
            What is needed to tap energy from the Earths Vortex, draw in Aether and convert that to electricity? Looks like the capacitor is one of the main things. It creates the separation of charges. In order to use our present electrical appliances, we would need to separate the charges and further convert that to Ac.
            • The guy with the 30 foot pyramid is his back yard:
              YouTube - Harnesing Pyramid Energy by Les Brown
              I just found it. I couldn't find it before.
              There may be something to this...as I don't think that he is making up the story. But, why is there no follow up on any on this stuff. Makes me wonder.
              • Yes, I have those and his first book. The company videotaping this event kept original material and never released again - if I remember well. Also, I read Less saying that his second book will "blow our mind" and it was related to the pyramid research, not just crystals. He also said that this first book was necessary as a introduction for better grasp of the second one. I tried to find this book but it was either never published or Less didn't finish writing.
                As far as Mythbusters I don't trust them since infamous presentation of John Bedini SG. They screwed up some many things with constructing this simple project and busting entire operation as a result. If 11 year old girl could do it following J.B instructions why couldn't they?? Perhaps producer got a call from MIT or the entire subject was picked to diss John Bedini work in this field. Is this a product of my imagination? John Bedini is familiar with this video and I'm sure he had a good laugh at it.
                Anyway, my point is that they aren't independent and they're getting well paid for their stuff. At the same time they do what they are told to do. Unlike most of us here
                I have a same question as you Nick, why there was no follow up, replication etc. Guy just took his years of work with him and left no notes??
                Maybe he did.
                As far as a capstone goes; that's another mystery. There was an earthquake (I think it was XIII century) which could loosen and cause to fall down. Most of the limestone has been looted as a building material for mosques. Maybe capstone vanished at the same time? There were smaller pyramids with capstones made from precious metals or at least covered with gold. For some reason I don't believe that Giza pyramid had such but maybe a different one? Such capstone would weigh 50 -70T depending on the material. Obviously, builders of the pyramid wouldn't have a problem putting it on the top. Maybe it was a crystal which was "on loan" and it has been retrieved....
                Vtech
                • Blackchisel and Sucahyo:
                  I just finished watching both your videos on cement batteries, or crystal batteries. I can't wait to try it myself, just need to get some cement. I got plenty of beach sand just a few yards away. It is made of mostly quartz. There are many types and grades of beach sand also, and so some may work better than others.
                  I was thinking of making a dozen can batteries to see it I can get around 12 volts. I wonder how they will further charge up if connected to a solar panel or wall adapter. As these cans make them look more like capacitors, than batteries. If this works using just beach sand and cement, people can make them in the areas where there is no electric power, or when one can't afford to pay for it. The nice part is that they can be connected in series (like a solar cells) to make the voltage you want, or the current needed, and any one can make them, even with no experience.
                  I just got the biggest shock from one of my Joule thiefs, just now. I could not take the shock as it really hurts. The Jt only puts out about 15 volts, but must have some watts to it also. It's just a one inch toroid, with a 76 turns of 26 guage magnet wire, TIP3055 trans. The secondary wire (one wire) touched the under part of my arm, and shocked my whole body, as I was sweating and my arm had salt on it from the beach. Surprised that my device could shock the heck out of me, as it never happened like that before. Makes me think that maybe adding a bit more Salt might help to increase the voltage in the beach sand batteries.
                  • Originally posted by NickZ View Post
                    Actually, you may want to wash beach sand to get rid of salt if you want to try making battery without electrolyte. Salt will increase performance such as voltage and amperage but will eventually consume your electrodes. Nice thing about beach sand is high quartz content but also some calcium particles - sea shells. I can't get this stuff atm. I wish I could live somewhere where is no snow. I really hate that stuff
                    Your experience with JT reminded me when I was trying to secure terminal clamp on one of the batteries I was charging from one of my rejuvenators. I was touching exposed metal part when clamp lost connection with terminal for a brief moment. This charger when not shorted with battery will deliver over 700V 1kHz pulse. My arm went numb all the way to the elbow. Funniest part is that I was driving truck with 53' reefer and this incident happened when going through Bronx Expressway
                    Vtech
                    • I will do a test with adding salt to the sand on just one of the beach sand batteries, to compare with the ones without salt. I'll also wash some sand, and see how that works. All other variables will be the same.
                      I was reading more about Les Brown, trying to find his second book, or at least more information. But maybe he died before it was printed. He seamed to have a lot of insight.
                      • Mythbuster experiment on apple is interesting. But it is unfair to put the control just outside the pyramid. The control should be next to the box.
                        Very interesting story about being thrown 20 meters. But is that electricity?
                        Everyone interested in three times cooked and freezed beach sand to make bions?
                        HOW TO MAKE BIONITE & BION GENERATORS - Orgonite Gifting
                        I wonder if it make stronger battery, or just make a strong cemenite lol. My crystal battery has some insulated copper coil in it ....
                        For output current of crystal battery, I wonder if it related to surface area of negative vs the positive electrode.
                        I have to shock my self with my 3V stingo whenever I want to use it as zapper, before I use it to my family, it is strong enough to freeze my arm. Don't underestimate radiant circuit .
                        • My new pyramid, coming. I'm waiting for copper sheets but this shape alone has detectable energy. I'll try to test whatever I can. Just finished mold for cone coils.
                          [IMG][/IMG]
                          and some home grown crystals - [IMG][/IMG]
                          @sucahyo interesting link Thanks
                          Vtech
                          • Nice pyramid . I will look forward for your result .
                            The crystal look beautifull.
                            I wonder if what I have now is alum or not lol, it seems that everyone use powder, and I can only find crystalize version, but not sure if it is ammonium....
                            Will plan to use it for my next one. Currently use it to fill weak gel battery.
                            • Blackchisel and Sucahyo.
                              You mentioned that your new pyramids energy is detectable. What do you mean by that?
                              Sucahyo: Les Brown was thrown 20 feet through the air. Whatever that force is, we need to know about it. Too bad he's dead now. His death may have been caused by the negative energy that you spoke of, producing cancer.
                              He did mention that it can drain the life out of you. He left his video for us. I trust that what he was saying is true, and that he was a true Light, and very inspired, like Tesla. And that they were both Lighting the way, for us.
                              Strips of sheepskin is what Les used to connect the pancake coil to the antenna coil on the top. No additional power or components were used. Can that effect be reproduced to any degree?
                              Tesla had been seen in fotos showing him sitting next to the big vertical pancake coil, possibly absorbing the energy therefrom.
                              Anyone know more about that?
                              I am interested in Electromedicine, also a new science called Astromedicine, as well as the anti-aging aspect.
                              It seams to me that although Tesla was naturally smart, he may have been further influenced by absorbing the additional radiant energy that was surrounding him at times. He did live to be quite old. If we could only talk to him now. Maybe someone can still do that, telepathecally.
                              I feel that healing or energy balancing is in part a matter of first adjusting the body's etheric field, so that the physical body can it can heal itself. As that can sometimes be the cause of many but not all of the physical problems. As some people can sometimes make themselves physically, mentally, entirely sick, by just a single negative thought or emotion. Possibly a medical instrument or electromagnetic machine or sorts can help. But do they really work? Not like some devices.
                              What we call miracles, are things we just don't understand, yet.
                              Aether, or etheric. Same thing. Not detectable by normal instruments and meters? Like the energy in the pyramid. It is not electrical or magnetic. What is it? Both, or neither? Or something else?
                              The question is:
                              What is Aether, or etheric?
                              Energy creates matter, and matter is subject to its laws, not the other way around.
                              The story of "Merlin the Magician" has always fascinated me. Making flowers out of thin air, etz..
                              • Blackchisel:
                                If you connect your frame pyramid to a Tv antenna wire and then to the antenna input on a Tv, you'll find that it does work as an antenna to a degree. And it can be tuned in by turning it around.
                                I was just reading on another forum that when a coil is pulsed with the right frequency, it will act as an antenna. Both transmitting and receiving signals at the same time. While transmitting at the same resonant frequency as the earths pulse, it will at the same time be caused to receive an additional input that will amplify the original wave sent out, while providing more power back than the original voltage sent or used.
                                So, it looks like coils are antennas, also. And if pulsed with the right frequency, can act like an Tv antenna boaster, that will amplify the weak earths pulse and cause it to be amplified back much stronger. It is done by transmitting at the same resonant frequency that you want to receive.
                                Pyramids may work as resonant Aether antennas.
                                I don't know if that makes sense as I've put it, I've tried to explain it as best as I could. Although not my ideas, they make some sense to me.
                                We'll see if it works...
