Pyramid
  • This is also interesting..
    Alexandr GOLOD, et al.: Pyramid effects; bioenergetics, increased oil production, electrical effects; articles & Russian patents
    Peter GRANDICS: Pyramid convertor of electrostatic to DC electric power
    Also, interesting waveform: cones energized from secondary JT
    [IMG][/IMG]
    And not too good pic of frozen sample from one of my tests; 6V battery connected to the base wires of both cones, apex wires not connected to anything. One water sample placed on the top of one cone and second sample inside other cone. Samples were left for 8hrs.
    [IMG][/IMG]
    And reading between apexes -
    [IMG][/IMG]
    Vtech
    General D.Eisenhower
    http://www.nvtronics.org
    • Oscillating cones
      I did another test, trying to incorporate both cones in oscillating circuit. What I found interesting is that cones one inside the other resonate but not as good as connected with apexes. I set them up vertically, just as they were inside the pyramid. Base wires together to the pos. of an old 1.5V battery, 1 wire from apex to the base of 2N2222 via 25k pot and second apex to the collector. Negative to emitter. LED between E-C. Scope between E-C as well.
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      I'll try other combination to see if there is any significant difference.
      Vtech
      • Other combination
        Second test; cones connected with their bases. Base wires to the pos. just like before. See the results:
        [IMG][/IMG]
        [IMG][/IMG]
        [IMG][/IMG]
        There are two more ways; apexes to the positive and base wires to the tranny with both configurations of cones. Tried both. Again, higher voltage with bases together (actually I can keep them 5" apart and voltage remains the same, only freq. changes) and freq. reading of 3.52kHz. The reason I'm doing this is to find out most sensitive way of oscillating cones to interact with Aether. I have a feeling that I may need a cap as soon as I'll be able to rectify/convert whatever is possible. Not that I feel getting any closer to achieve that.
        Vtech
        • BC:
          Try the capacitor, yes. No cap, no detectable power, maybe pyramid size does not matter to see a small effect generation.
          I use wood, as well as metal rods to build pyramids (copper, iron, brass, stainless steal, Pine trees), etz..
          I have read through some or most of the patents that are available on pyramid devices, but I have never seen any follow up of the prototypes of those presented patents, that would show proof of the invention. I guess that that leaves it up to us, to follow up on any of it.
          I notice when working with radiant energy that it likes to escape through sharp points or peeks. That is where it most easily can be tapped, like off of a small wire placed on the very top of a pyramid. The fact that the meter won't register it does not mean that it is not present. We need new types of meters for this.
          Maybe "Bertha" can be charged by the pyramid, like a Leyden Jar can be charged by static electricity.
          I'm still trying to understand capacitors, and how to make and use them.
          Can your big cement battery light a single Led, (bright?). Most cement batteries lose their current output (mA) ability over time.
          • I might be away next few days.
            • Information
              GOLOD'S PYRAMID HAS ANGLE OF 72*
              72 Is a harmonical number. Which is 6 x 12. 6 is a harmonical nuber so is 12. 72 is an angle for the number which is both can be divided by 6 and by 12.
              72 / 6 = 12
              72 / 12 = 6
              Here is also number 3 here as if you 72 / 3 = 24.
              Alot of calculations for the shapes based on Prime Numbers.
              And also on the number 3 6 9.
              I am sorry Nick if you are dissapointed with no power from cones so far. As I As I said before primary function of this technolgy is to charge liquids for watering crop and transmutation of matter.
              The first so far had prooven to be correct - water doesn't get stuffed with shaps standing on the table. Transmutation is still to be shown.
              Transmutation is in alchemichal term changing matter. The alchemichal best known concept for it was ''lead to gold'' transmutation. This energy cando anythigh. Snd it can go to metals higher then gold or lower then Gold at will.
              Just the Vortex must have high speed and be concentrated.
              Frequency of the cone itself detemin the frequency and the speed of the Aether Flow.
              You do no need to add frequency from outside as natural frequency which the secondary wave creates once first wave is eliminated is all that is needed.
              Additionally if feed frequency from outside - speed of transmutation can be increassed.
              Some time ago another one of my former associates have built 3metres tall copper pyramid. 24 Carat gold leasf placed in king's chamber was converted to gold oil over 2 days and if not brought from pyramid this oil dryed to white powder on the end of third day. This was common pyramid not powered.
              I would rather not talk about.
              Another person who built pyramid 3.6 metres tall was able to convert ORMUS/M-STATE precipitated from sea water ot dead sea salt solution to Gold dust using this pyramid. I been teaching him how tyo created powered vortex. That is last I head if him. He wished me to ''drop dead as soon as possible'' and walked away. Those were very sad time as project after project collapsed and were over run by human greed.
              Common unpowered pyramid can transmute at will and super charge ONCE it's size is past a certain point
              To do the same with a small cone it's frequency must be rised high using magnet osiliation alone or with an input of power from out side to energise the vortex further
              A CAPASITOR MAY BE USED TO ENERGISE AND STORE THE CHARGE - BUT THIS CAPASITOR MUST BE A LIQUID FOR THE MEDIUM EFFECT
              For the maximum effect the liquid capasitor must be in state of a constant motion - MEANING the liquid mediummust SPIN withing the charging field CLOCK WISE towards the side of the field's flow*
              * meaning that if you got a cup of water let's say 500gramms. IF WATER IS STANDING STILL - you would requesre quaite a long time to fully charge it as naturally mollecvulas are moving slow.
              but if your water is MOVING at certain speed yowards the same side where the flow is moving you can super charge it quickly due too the fact that water moleculas are now in motion - once in motion moleculas pass the charging area fast and every time they collect a charge.
              Common tap water or bottled/still water can never gain the same chaqrge as distilled water can. Distilled water is a dialectric. In essence a liquid capasitor. The chaqrge it can gain and keep is very very high compared yo normal tap water.
              However almost as soon as water stops moving it will begin to loose the charge. After about 5h once it has been away from charhing field and motionless it will only retain about 60% of it's original charge.
              Why you might ask?
              It is simple while moving contstantly it creates a vortex in itself. Which creates it's own energy. 2 vortexes interact with each other and transfer power from one to another. In form of a vortex water can accumulate and retain as much as 5x charge it normally would retain as stationary liquid. So after about 12h after moving and charging had stopped only 20% of the original charge would remain.
              If water is spinned in form of a cone using specially angled blades it creates a water cone which is close to the geometrichal shape the blades are of.
              This ''watery cone'' would generate it's own Aether or Orgone fields and itsef would charge it. But to super charge another Aether Field must be added which is LARGER then the field created by moving water.
              I belive I have explained everything here.
              Any question ask and I do my best to answer.
              • robur:
                Thanks for the explanation. I was wondering how the "water vortex" created by the spinning blades is going to be tapped, and become usable power?
                That has been my question all along, that is: how to tap a vortex?
                @ Blackchisel: Your tests look great, and it seams that you may be close to something...
                Your cone setup reminds me of double ended P.A speakers horns. Only they are not using sound frequency. Did you try the round speaker magnet between the cones when they are placed together by the small end?
                I've heard that a coil is also a transmitting and receiving antenna, and that when transmitting at the same wave length as "Earth Frequency", it will cause a resonant boasting effect to happen, which will produce a gain in total power. Just like how a high gain Tv antenna boaster functions, to produce a stronger output signal.
                Yet, again, I'm still waiting for somebody to show proof of that, as well.
                I thought that I'd pass that idea along...
                I see some kind of induction going on in my cement batteries, and Leyden jar type of capacitors as there is no direct connection between polarities. The way that that works is still amazing to me. They might be of use inside the pyramid to separate and store electricity.
                Full moon today, no big earth changes here yet.
                Things are nice, warm, and calm... so far. (Picture).
                • [QUOTE=NickZ;134819]robur:
                  As I said countless times the primary use of this technology is transmutation of matter and charging liquids. I am trying to convert this to one that gives power, but If I don't receive further info from my source about this which is not very much interested about addiction to electricity that people got I cannot answer that.
                  Please answer my PM to you I sent you a few but you never answered.
                  I offered to talk to you privately if you like, but since you don't answer PMs I cannot do that.
                  • Originally posted by NickZ View Post
                    robur:
                    I might be totally wrong but the way I feel is similar in concept to the Van der Graaf generator with belt carrying static charge to the upper sphere. Now, if we replace the belt with vortical water flow . We know that water can be charged while moving and can charge v.well while moving in such pattern. Water can also retain a charge for a while
                    Even if we can energize water to be used in plant growing process and find significant change wouldn't that be great? Beside, those results (if confirmed) can be replicated/measurable by anyone, not just sensitive people
                    Your cone setup reminds me of double ended P.A speakers horns. Only they are not using sound frequency. Did you try the round speaker magnet between the cones when they are placed together by the small end? Yes, there is one you can see in previous pictures. nothing significant observed or measured. I also ran test with different magnet placement, neo rings etc.
                    I will try some ideas as soon as I can outside the house, with good ground/ less environmental interference. I will also test those batteries I've made buried in the ground. I'm still thinking about two patents from late 1800' where battery had coils which were modulated. I have those patents saved, one was Cerpaux's.
                    Can your big cement battery light a single Led, (bright?) Yes, all of them (except the one I messed up and pipe with Al silicate - rad seal. Identical with Cu seal works.) with oscillator to step up voltage. I used the same oscillator circuit to test cones. This is neat because I can tune with base pot for best resonant point.
                    What you have in those caps is h. dielectric substance between h. conductive layers where the "charge" is stored in the first one. I was thinking of materials used with pyramid such as outer layer - h. dielectric and pink granite - slightly radioactive. There are also "similarities" in dimensions of granite box (cover missing) and the Ark. Maybe wrong trail but who knows?
                    Just got back home. Both cones were connected past 2 days to the oscillator with LED and I read over 4V across the LED still.
                    I also tried another test, (more related to JT idea than pyramid). I've made 2" dia, 12 point bifilar starship coil, encapsulated in resin to keep it safe since the wire is < #30. I was able to oscillate those coils and get over 5.5V vs 4V with cones. There is no secondary winding. Coils oscillate at 33.33kHz and the wave is nice and sharp at its peak. Will try to get short vid or at least a pic. It takes very short time to wind them and there is no need for a core or ferrite toroid.
                    @robur There was no transmutation observed with salt/sugar experiment. Water didn't change. I had no other reading (field/ color).
                    Vtech
                    • Starship Oscillator
                      This is my test of small (1.75" - 45mm) starship coil where two windings were used in the self oscillating circuit. No toroid, no core. Powered by well used 1.5V alkaline AA
                      [IMG][/IMG]
                      And wave across LED
                      [IMG][/IMG]
                      Close up. Frequency reading 33.33kHz
                      [IMG][/IMG]
                      Vtech
                      • Guys:
                        Thanks for your replies.
                        I just connected a Jtc to a Leyden Jar, that I made out of my coffee cup, with foil outside and a copper wire inside the very center.
                        The voltage from a secondary coil of a Jtc has never been much over 15 volts, at best. When I first connected the Jtc to the coffee cup capacitor (water inside- without salt) it read about 18 volts. But, when salt was added, it now raised the voltage up to where I have never seen it go before, to about 250+ volts, and climbing still. It's an interesting effect to see the voltage climb like that from a 1 volt Jt as input.
                        But if I disconnect the input, the voltage drops to 0... so, the Leyden jar is not holding much charge, But it does build up a charge to 250 volts Ac, or 60 volts Dc, or so. Upon reconnecting it up, it's immediatly back up to 250 volt, or more, without a delay in recharging time from 0 volts.
                        It is hard to tell on my analog meter, but the pointer is nailed all the way to the right, for a reason. Even on the 500 volts scale it detects 265+ volts. Anyways, I'm still working with it.
                        Thanks to all for sharing your results.
                        @ Bc: Good to see your small star coil putting out 5 volts. Nice work!
                        Sucahyo- anything to report from your side of the world? No news is good news?...
                        robur:Check your PMs. I finally replied to yours.
                          Guys:
                          Thank you. I'm thinking of another circuit based on the first one with either a third wire (trifilar) or couple steps separated with collecting caps. Few ideas. actually. Will update if there is something useful.
                          I tried to make capacitors for Tesla Coil using apple cider. It may work here too.
                          • Thanks for the link and experiment report Vtech . Nice result . I forget if you already try to put your crystal battery at 1/3 or 2/3 or at apex?
                            Robur, how do we power up vortex? and how do we reduce frequency?
                            NickZ, there are a couple of magnitude >4 quake around the south line of Indonesia, for the last two days. With one is too near to someone who had orgonite. If pyramid can ease earth quake, I wonder if opposite energy magnify it. Hopefully not.
                              No, I figure out that shape only may be too weak to produce anything measurable. I'll wait until I can cover pyramid with copper. For now I did focus on cones and ways to interact with Aether, somehow.
                              Vtech
                              • Originally posted by blackchisel97 View Post
                                Vtech
                                Ok, thanks .
