Pyramid
Originally posted by Crono View PostAlso anyone think that Aether and the Higgs field are not necessarily the same thing but at least related in some way?
Davidson is a good read.
Vtech'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
General D.Eisenhower
http://www.nvtronics.org
Blackchisel and All:
I finally was able to get some output from my beach sand cement batteries.
They are now putting out about 1.3 volts each. Two beer cans will light an Led about 60 % brightness. I'm making a Jtc (with no resistor) for each can battery now, so that each can battery will light an Led. They are also taking and holding a charge to some degree. I cut a slit on one side of the cans so that the plastic coating wouldn't affect it as before. Now when they are shorted out they just bounce right back, so I know they are working.
It's been about one month after they were made, and the are bone dry now.
I just used beach sand, a straight 1/4 inch copper tube, beer can and cement.
Lidmotors beach sand idea works! And this is my first free lighting led. Although it not the brightest led, it's on 24/7. I'll be adding more cans to increase the brightness, soon.
Bc- I would probably have given up if you had not mentioned that you've got all of yours still working. Thanks.
Bc- I would probably have given up if you had not mentioned that you've got all of yours still working. Thanks.Try slightly different oscillator, look in the "Earth Light" thread (first post). Use 20 -50k pot instead of fixed resistor. Coils is 35 bifilar #30 or close on piece of iron (welding rod). You can also do aircoil but increase wire length approx. 10 ft more. You'll see it on my vid's. It will light LED fully bright at 4 - 4.5mA and 0.75V. You'll notice that lowest resistance doesn't mean brightest LED. Each battery may have different resonant spot. 2N222 or similar.
Darn thing wont let me edit, look at one of John Bedini youtube's about iron pyrite batteries. There is a circuit.
V'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
Treyeangle
IMG02033.jpg I've read some weird stuff in this thread.....just finished painting this....thought it somehow applied....
@142857 This is very niceThank you for sharing
Bc:
Thanks for the ideas. I am far from civilization, as well as any stores like Radio Stack etz.. The beach sand batteries do work, so I will improve the next ones by adding baking power, and making the copper wire spiral though itself and up. I think that will help. I'll let you know how it goes.
Thanks again for the support.
I was watching Tomata's latest video on the Tesla Patent of drawing energy from the air by using a metal sheet 1 by 2 meters, placed 12 meters high and another sheet of 1 by 1 mt. buried in the ground. He has some amazing results. Suggest everyone check that out. 800 to 1000 volts radiant energy.
The Bashar's space- time antenna has also finally made it to this forum, great. I've also been counting on that one...
Below is a picture of where I access my beach sand.Last edited by NickZ; 07-23-2011, 03:43 PM.
Below is a picture of where I access my beach sand.Wish to be in such place. Check latest posts in Bedini Earth Light thread and idea of making semiconductor for those cells (and not only for those cells). I don't know if you had a chance to watch JB Energy From Vacuum 18 video as well as petrovoltaics. This is related to work of Russell and transmutation. I did one battery with baking soda. Strong during first couple weeks and now very weak.
The beach sand cement batteries will take a charge, of several volts, but, hardly any mAs. They seam to work better if charged first.
If a bunch of cement batteries are connected in series, (100 of them), 120 volt will be obtained. Few watts, But,.... you don't need the sun.
They can also be connected to a solar panel and will act as additional storage. I'm charging them off of a 12 volt dc wall adapter, for now.
Try to charge them. Mine seam to hold the charge. I don't think that what is going on here is as simple as it looks. Once they are activated by charging them, it seams like juice just flows through them, to some degree.
Could you post a link to that video?
@ all,
Thank you for this thread, wish I could contribute something of value but at the
moment it's just a big clutter of random ideas. keep up the good work.
spiralout.
Thanks for the page Vtech. The Russel way look interesting, do he mention how to tap it?
Thanks for the info NickZ, I am thinking more to use the space time antenna as the coil instead of the charging target, it should has inductance isn't it? And if it provide resonant, then a bridge recovery of radiant circuit might capture it. Don't know if it provide longer ring that usual coil though.
Congratulation on the cement battery.
Crono, for energy source, psychic believe two source, from the earth and from the sky. They form different "grid".
However, the method you mention use different method. Either:
- an earth battery
- an earth voltage potential capture
Both are different because the first one is chemical and the second one is the physical effect of the above two source.
There are links to my online library -
Walter Russell - The Universal One.pdf
And some more interesting reading.
Guys:
My sand-cement batteries are working but they won't light a Jt.
They have enough voltage, but not enough current. I even took the resistor off of the Jtc, but still no cigar. Anyways two or three of them do light a couple of leds connected direct to the bulbs, but also seam to drop in voltage and get dimmer after a while. Next ones I'll use some baking power (not soda), and spiral the copper tube through itself, to see what happens... So far a 1/2 inch by 2.5 inch calculator solar cell puts out more power, than three of these can batteries. But not at night.
@ Spiralout: I don't know what to think about the 800 volt Energy from the air video. He did mention that he would update more info soon.
Here is a link. Let me know what you think. I like the way they light the incandescent bulbs with radiant power. Would love to be able to do that myself.
YouTube - Radiant Energy
There are more of his videos, you just have to look for them when you get to YouTube.
Concerning the space antenna: I also think that Russel's inverted coils design were possibly working on the same principal. Which gives us more hope of getting some good results.
I wonder how many feet of copper wire will it take to make the minimum size 2 foot high by 1.2 foot antenna coil? Insulated copper cable is not cheap now, so knowing the exact amount of feet needed would help keep the costs down. If AC is needed to jump start it, maybe an AC dimmer switch might help to lower the 120 volt wall outlet voltage, so it won't fry the connections at start up. Batteries are not AC, but who knows if that matters, probably. I love surprises, don't you?
Thanks Bashar, I know you your listening in...
Good day!
Thanks for link NickZ, that's a realvideo!
The guy posted another video showing there is no battery inside the bulb... cool stuff.
YouTube - Radiant energy 2
Maybe organic matter can somehow transform radiant/aether/orgone/prana/whatever energy into electricity...
like in the case of Les Brown and the wool thread he used in his pyramid...
cheers, spiralout.
