Pyramid
  • beautiful image, thanks Haan and sucahyo
    • Haan:
      Thanks for reopening this thread. We had some interesting ideas here a while back.
      To answer your question about having made any electricity from a pyramid. Yes, and no. In an earlier post of this same thread I had mentioned that I would like to wrap an aluminum wire around the whole copper tube frame of my 6 foot pyramid, as a cathode, with the copper tube frame of the pyramid as the anode. This system does work, in the same way that a battery or power cell works. To further improve the voltage, each separate coil sections of the aluminum wire of the pyramid can be wire wrapped as a separate coil that when connected in series with the others, can produces several volts. This I know is possible, as I've done it using only a couple of feet of the copper tube on one part of the 6 foot pyramid. I used a wet cloth as the electrolyte between the copper pyramid frame and the aluminum wire that is wrapped onto the copper tube. But having to maintain the electrolyte cloth wet, can be a bit of a pain, and I'd like to use a dry, solid electrolyte instead.
      This essentially makes a battery out of the frame of the pyramid, which can produce several volts. Probably as much voltage can be generate as with Thomas Travoger one meter sized pyramid, but possibly not as much current.
      I had taken some pictures of that set up, but I have since deleted them.
      • 1 metre pyramid to benefit my dog's hip vs. the measurements of a Giza!
        I'am seriously extra confused about this one, why would a company design and market 1-metre and 2-metre pyramids if they aren't the measurements of a Giza pyramid?
        I'am about to spend $140 (cooper tubes) + $146.00 (base connecters) for a 1-metre pyramid (which I hope I can sit under, but it's primarily for my beagle with severe hip problems and a problem with her a loose ligament in her front leg.
        I did sit under the 2-metre pyramid and felt tension moving away, so I did feel good energy! But will a 1-metre pyramid benefit my dog's health??
        Now I'am being told by people who know that it needs to have the dimensions of 9, according to the Giza.....now if this energy healer and guy who owns a metaphysical store know I'am spending money I don't really have on a 1-metre pyramid to benefit my dogs health, why wouldn't they just tell me the truth?
        I'am so damned confused! There's no research on this I can find, and I can't contact Bill Schull!
        • I would suggest taking your dog to the vet, and not fooling with a pyramid.
          NickZ
          • Russell Coil
            In regards to some attempt to build a Russell coil, I have studied Russell's concepts of gravitation and radiation, My understanding of the step up or process of nature in relation to russells coil is that it would need a input of energy to 'STEP UP" that would also need one of these inside coils to be powered. this will be used to resist the discharge and thus increasing the charge in the windings there is no step up with out sth to push against. that is why it is called a device because it is switched on with input. just like the input of gravity from the sun, and the coinciding resistance to that pressure is what creates the step up in the coils. but most importantly it is the step down is where the energy is found in the coils. the diagram to this is found on one of sucahyo's posts on page 14 of this topic 7 post form the top, ninth picture down.
            I would love to do my own experiments based on what I have learned from Russell's books. But have relay no idea about how to wind these coils, any ideas on how to wind a cone in side another cone and at opposite directions,
            There should be at least 4 to 5 coils, and these outer and inner coils will need to intersect at 90 degrees to each other if the coils are wound at 45 degrees, this is the angle the two forces we will be dealing with intersect ( Magnetism and Electricity ) althou this device has nothing to do with induction.
            45 degrees will also dictates how fat the overall inside coils are, they must coinside to the small ends, small joining to the Apex of the following coil cone.
            Also bashar Coil is simply a piece elegantly bent wire and the explanation used to explain how it works is complexly retarded. I would totally erase that form your memory because it is just a model and looks good, but serves no practical purpose. and only has 2 coils.
            I wonder if there is any pictures of the Coils Russell Worked on.
            If anyone has any info on the Russell Coil Please share,
            Peace
            • December 21, 2012 is almost upon us. Any thoughts about the Mayan pyramids and their use during galactic alignments such as 12/21/2012?
              I would love to be physically there at one of these Mayan pyramid sites to soak up the energy.
              • The effect of
                Ulam spiral - Wikipedia, the free encyclopedia
                in the form of square spiral tunnels has not been considered.
                See the following link from 18:00 mark.
                LEXXTEX - 293 - THE HIDDEN SECRET OF THE GREAT PYRAMID"S CONSTRUCTION UNCOVERED - YouTube
                Al
                • Simple calculation
                  The great pyramid was built using aprox. 2.5 million blocks of stone. Each weight between 2 and 5 tons. Accordingly with official egiptologists, the pyramid was built in 20 years. This means 7300 days. 2500000/7300 = 342 block/day. Working totally 24 hours means 14 blocks per hour or 1 block at aprox. 4 min.. Everyday, everynight 20 years non-stop. And after this gigantic work you don't put a sign or other mark to celebrate this creation. Don't tell the story about this. Strange.
                  • Calories
                    valibb,
                    Good stuff. You could probably estimate how many Joules or
                    Calories it took to do the job, ignoring TIME.
                    It takes about 2.34 calories to lift 1kg 1 meter. 907.185kg in a ton.
                    For 2 tons being lift 1 meter, that works out to be
                    4245.6258 calories to lift 1 2 ton block 1 meter.
                    Lifting 2.5million 2 ton blocks 1 meter is 10.614 x 10^9 calories.
                    One kt of TNT is approx 10^12 calories.
                    The "Little Boy and Fat Man" were 10 kt of TNT (10^13 calories).
                    Hence, the power expended in calories to create the pyramid
                    far exceeds a small nuclear explosion since each stone was lifted
                    many meters.
                    Therefore, the energy requirements are similar ...
                    Great Pyramid vs Nuclear Bomb.
                    It is recommend that people consume 2000 calories per day.
                    Dividing all those calories by 20 years of days, we end up
                    with at least 6.8 million people working NON-STOP w/o resting,
                    or eating, or taking bathroom breaks. More if people get time off.
                    • Originally posted by aljhoa View Post
                      The effect of
                      One man can move huge blocks 300 feet per hour.
                      Man Moves Huge Blocks! - YouTube
                      In 9 weeks (40 hr/wk) he could move a huge block 20 mi.
                      6.8 million people-working NON-STOP w/o resting could move
                      2.5 million blocks of stone in 2 weeks.
                      Al
                      • @ Mark 24:00 - 29:00 Dr. Semir talks about the 28kHz energy beam.
                        Dr. Semir Osmanagić the discoverer of the Bosnian pyramids is elaborating on his discovery and it's implications on science, history and our entire understanding of nature and who we are. Below the Bosnian valley of the pyramids is a huge network of tunnels and chambers which has been confirmed artificial by several scientific institutions.
                        Some of the research and studies, done by a couple of different universities, are suggesting that the site was constructed over 30.000 years ago.
                        pyramids, and rewriting history - YouTube
                        Al
                        • Originally posted by J.L. View Post
                          ..if this energy healer and guy who owns a metaphysical store know I'am spending money I don't really have on a 1-metre pyramid to benefit my dogs health, why wouldn't they just tell me the truth?
                          Because he understands the placebo affect. Oops, sorry for the spoiler.
                            Al
                            Mainstream Academics say its just a pile of rocks but if this statement is true;
                            "A team of physicists detected an energy beam coming through the top of the Bosnian Pyramid of the Sun. The radius of the beam is 4.5 meters with a frequency of 28kHz. The beam is continuous and its strength grows as it moves up and away from the top of the pyramid. This phenomenon contradicts our known physical laws and technology. This is the first proof of non-Hertzian technology on the Planet. It seems that the pyramid-builders created the perpetual mobile a long time ago and this "energy machine" is still working."
                            it might just change a few ideas.
                            • Alien vs. Predator - Official Movie Trailer - YouTube
                              Power Beam/Generator @Mark 12:30-13:30 and 17:45-20:00
                              Ancient Underground Alaska Dark Pyramid inside Alaska Bermuda Triangle that powers Pentagon exposed - YouTube
                              2 Pyramids right next to a research facility 9/22/2012. Google Earth / 71° 56' 55.29" S 23° 20' 42.94" E. The terrain at this site is Granite. The facility was built on top of the Granite, next to the pyramid structure, which, Granite was used (not entirely) in their construction by the Ancients.
                              Ancient Pyramids in Antarctica? - (HD) - YouTube
                              Al
                              • Originally posted by sturgeon View Post
                                I would dare to disagree with perpetual term here. In my opinion they're transmitters or converters if you will, rather than generators per se.
                                On the subject of "known" laws governing physics for the past couple centuries I will remain silent.
                                Thanks for posting this info.
                                Vtech
                                General D.Eisenhower
                                http://www.nvtronics.org
