I've obtained a few things already for this; the driveshaft
and PVC motor housing, bearings. Its a brass bar 1/4in diameter,
and the tube is 4 3/4 inside, 5in diameter outside and 1/4in thick.
The confusion I'm running into is in regards to the method by
which a set of magnets will be attached to the driveshaft.
The things I've been considering are as follows:
- Grind off a flat area from the center of the bar, and cast
an epoxy resin flywheel with the magnets permanently embedded
onto it.
- Have someone cut me a square aluminum (or brass) block, and
attach it at the center position on the driveshaft so I may
fashion a proper hardwood flywheel with cutouts for the magnets
to be glued in.
- Cut the brass shaft in two, then have plates attached to the
opposing ends to be used to bolt them onto a center flywheel.
The magnets would be 1in wide x 3/4in long cylinder blocks, and
I'm going to wrap the coils with 2lbs of 25g wire total for
approximately 13 one-inch layers per side.
onto it.
to be glued in.
![](http://www.frontiernet.net/~gopatrope/pics/energetic-forum/pvc-tube-brass-bar.jpg)
