Don Smith A review...
  • The primary is resonant tank circuit working on frequency 1
    The secondary is resonant tank circuit working on frequency 2
    The secondary contains also antenna and because of that there is also 3 resonant frequency for longitudinal 1/4 wavelength so the secondary is efficient radio transmitter.
    You spark primary tank circuit not frequently, but it oscillate freely, secondary oscillate on some harmonics and the resonant LC and the length of antenna is correlated (L= 1/4 wavelength). Antenna instead of transmitting radio around is matched to the output part so all energy from ambient is stored in capacitors.
    I do not pretend it works but the essence is something like above.
      I understand what you guys are saying. That you want to store the resonant rise power in storage caps. However, both Don Smith who went through showing how to create your own device and two Zilano ciruits, where no storage caps were used and the output trafo was connected directly. Please explain how that could be possible?
      Here is the second no spark needed, or HV, HF, and NO STORAGE CAPS!:
      Originally posted by Zilano
      Aug. 10, 2011
      Zilano
      The Shortest Way To Success Easy Way No Sparks No High Tension To Mention
      hI this is zilano zane!
      A NEW BREAKTHROUGH in don
      technology.
      reduce electricity bills!
      must read
      a small scale demo setup! can be upscaled for home use!
      take a 12 v 220 or 110 volt 1 amps step down transformer with 2 wires
      primary and 2 wires secondary measure L of primary with lcr meter and
      use resonance calculator to calculate caps for 50 or 60 hz. use this cap
      across primary. then calculate L of secondary with LCR meter and use
      resonance calc to get secondary caps value for secondary 50 or 60 hz.
      now take another 12v 220 v or 12 v 110 v 1 amp transformer. feed 12 v ac
      to ur resonating transformer with caps to its primary it will make it
      oscillate in resonance with secondary of resonating secondary with caps.
      attach a 220 v or 110 v as ur trasnformer u r using attach load. measure
      input power and output power and calculate gain. use iron cored
      transformers. core is suitable for 50 hz resonance. attach caps in parallel
      across primary and secondary of the transformer.
      RESONANCE FREQUENCY IS 50 OR 60 HZ DEPENDING UR GRID
      SUPPLY FREQUENCY COUNTRY DEPENDENT. FIND CAPS
      ACCORDINGLY. VOLTAGE WILL BE 12 VOLT OR 110 OR 220
      VOLT OR CAPS.EG C=X MFD 60 HZ 12 V OR C=X MFD 120 V.
      MFD= microfarads.
      try it! circuit is below as attachment.
        The secondary is a receiver coil, there's two very important frequency, the first is the frequency of HV power source this frequency intended to give a very high reactive current ( as much as you can ) this is a reactive electric power transformed into active power in L1, L1 has its own NATURAL RESONANCE FREQUENCY it have to be a natural resonance because it's an OPEN SYSTEM the word open mean there's an internal interaction between magnetic and electric field ... when the two meet each other you have your REAL ACTIVE POWER ...
        • Originally posted by ilandtan View Post
          using two transformer in resonance mode look like a joke, the resonance don't mean you have free energy, we have the resonance almost everywhere but we don't have free energy because the resonance we use work externally not internally, in other words it's a closed system resonance not an open system resonance ..
          open system resonance you could join the electric portion with the magnetic portion , when you do that you get a very strong useful radiant energy ... it's like a massless particles, it's a very strange kind of energy, in some test i got a self charged capacitor !!!! some details can be found in my thread , the capacitor remain charged for near 30 min and after short circuit its leg several time for a long period, but when trying to recharge it the phenomena gone
          i am not interested in replicating this behavior but i am studying it, it appear there's a lots of interesting thing that can be done only when understanding , this why it's important to explain what's going on rather than giving claims !
            Med I know how you feel about the ETBC, and I believe there is got to be a resonant component , it seems that all the positive work in OU requires resonance. My thinking is that bifiler coils, even in Tesla patents are for L2 to provide that extra response, I've read that a single wound L2 provides a linear response whereas bifiler provides an exponential one. Do you maintain resonance using your ETBC?
              this is not just a felling , i published a video about the 40 W light bulb fired in each 3 second where the input is just a 3 W! the equipment used in this test is very modest ! a tv yoke , 4 ETBC managed in serial, HV power source without maintained resonance, a 1000V fast diode, plus 100 UF/400V capacitor as bank.
              after that i was looking for copper foils to work with but i can't find them easily, so the solution is to work with aluminium foils but there's a way How to Solder copper wire to aluminum foil
              https://youtu.be/_mYkM9lHMho
              the solution is easy and simple ! no need to mechanical contact, i was looking for frequency generator to help me in resonance but we already has it in our computers sound card where you could generate up to 20 KHZ for free i think it's possible to work with less 20KHZ in primary side where it's possible to put a kind of variable inductance to catch the real resonance point ..
                the ETBC is an extended Tesla Bifilar coil not a tesla bifilar coil this look like comparing a page of a book with a book ! the reason for this is the third dimension created with conducting foils ..
                • Adam Tromble Mantra
                  About OU...
                  "All we have to do: Is in a resonant domain, introduce an heterodyning wave or standing wave properly, and it increases the effective field density in a given electromagnet circuit. It increases the density of that field by orders of magnitude" Adam Trombly Who brought the Closed Path Homopolar Generator to the UN, by his account he was well received, so much so "they" took all his ****, and told him to not touch it again.
                  If you don't have resonance don't you just have induction?
                    About OU...
                    when Don Smith asked about the name of his system he said resonance induction system ! it's like you have a resonating coil since the induction is primarily related with coils, the resonance just put your system in optimal condition so you have a huge amount of power ! but be prepared since you need a good hardware !
                      Med have you ever gotten your ETBC to run in resonance, self or between your exciter coil (L1)?
                        ilandtan,
                        i am sorry about the disconcertion i may do when i correct something i did, it's normal to make mistakes especially when you work alone , until now i didn't achieved the resonance in ETBC , the concept of L0 ( i think this is what you mean by the exciter coil ) seem to be important but it will affect the resonance of the system due to the high inductance caused by this coil .
                        there's a strong connection between the ETBC and all Don Smith descriptions about his resonance energy device, but we have to use a ferrite core or anything ferromagnetic material just to help the magnetic side to resonate stronger,
                        there's a very interesting animated GIF found in the archived Don Smith website :
                        if you analyse this photo you see the electromagnetic flux generated from a working ETBC ! you see two spinning field locations , the right is the magnetic side , the left is the electric side , in the middle you see the useful radiant energy , the system resonate in a mono direction behavior and this is very strange , the same thing seen in the ETBC , the system give the positive pulse in one direction !!
                        • Hi Med,
                          That is an interesting photo, though I don't want to be hypnotized. I'm not sure what I'm looking at, and for that reason I can't speak for or against the validity. I don't want to pretend I can describe the mechanics much less explain the parameters. I am interested in one thing and that's how to prove an effect resulting in significant excess power.
                          Right now I am trying to sift through all the commonalities of what may work. I do believe that opposing coils and resonance seem to be included. One thing that keeps me away from the ETBC is that I read that Tesla in his Colorado Springs experiment had a hard time arriving at the proper tuning because of the capacitance inherent in the coils. I know I want to have the system resonant and the ETBC seems untune-able as an L2 coil ( I couldn't easily expand or contract the windings to change the induction) . I think if someone found a way to build resonant ETBC, for example uniform construction techniques with formulas to build them consistently close to a designed resonant functionality in the RF spectrum I would be very interested. However, adding to the capacitance may not be all that desirable if you can't make it ring in the circuit. Please correct me if I am wrong (and I am OK with that).
                            Hi Med,
                            Hi ilandtan,
                            Colorado Springs experiment is another subject if you mean his wireless power transmitter system since it's the most complex machine Tesla ever made.. which device Tesla used to power this wireless mechanism i don't know! the earth ground Tesla used had a complex construction , it seem the capacitance inherent in the coils affect the secondary not the primary , the capacitance isn't a problem if managed properly .. in the ETBC we don't have the displacement current that charge the capacitor because we take those charges in t=0 instantly, the rotating electric field do that because it present all the time as another face of the magnetic field present , because of that you have a magnetic resonance system, the electric side is hidden but it's there as electrons spin mechanism !
                            in the animated GIF you see in the right a magnetic wave come from the deep space , this is why Don Smith said that waves can travel unrestricted to the deep space !!
                            another quotes from Don will show some interesting facts :
                            the key to unlimited energy is Magnetic Resonance. In order to understand this requires putting a stake through the Heart of Antique Physics. Nonlinear and Open Systems are universally available in Magnetic Resonance System
                            Don has the same problem i am facing now but the solution isn't impossible , with some patience we could solve this problem ! another quote will show this :
                            Resonance. An important factor in circuits aimed at tapping external energy is resonance. It can be hard
                            to see where this comes in when it is an electronic circuit which is being considered. However, everything
                            has it's own resonant frequency, whether it is a coil or any other electronic component. When components
                            are connected together to form a circuit, the circuit has an overall resonant frequency.
                            focus in the words overall resonant frequency ! again focus in the word COIL ! it's a simple coil ring naturally in a resonant system offer a good amount of reactive current as an image of high voltage so your ETBC will ring at higher level ! i hope you understand something from this :-)
                              there's a proof about the ability of ETBC to be an excellent over unity device , the following photo show the oscillation of ETBC under certain condition where there's an increase in oscillation and after that it decrease but it start over again without any external power !!! and it decrease and so on ...
                              the photo was published in my thread a long time ago but it's resized and zoomed so it will be clear it's an over unity device .
                              • Hi Med,
                                I understand some of what you said, but not sure when you got to the you can ignore the capacitance because of the t=0 thing.
                                I wondering have you tried making the ETBC two 1/4L (grounded center) and excited it with a 4L primary sparked with series Diode?
