This thread is about implementation of stingo spesifically for brushless motor.
Stingo can be use to run brushless motor by using available wire terminal. There is no rule of which terminal should connect to which part in the circuit. But some wire combination may not run or only run to spesific direction. Some wire combination will allow the motor run to both direction.
The motor may need to be pushed before it can run.
Video:
Youtube - Running harddisk motor with stingo
YouTube - Stingo Bedini stepper
While previous video show that it can run stepper, it is not the best operation for stingo. The best implementation for stingo is for bipolar motor like computer fan.
Edit: What this video show is not standard Bedini Fan circuit. While Stingo provide 6 times improvement over joule thief like Fan, it give similar performance to Standard Bedini Fan.
YouTube - Bedini fan, Joule thief vs Stingo
The top one is the one being used to run the harddisk and stepper motor. For Bedini fan application, you may need to reverse the second winding in case you converting from standard bedini fan circuit. If you start fresh, you may not need to create additional terminal. Try stingo with available terminal first.
Video:
